#1 | |
![]() ![]() ![]() ![]() Drives: 2010 Yaris Sedan Join Date: Feb 2010
On the tire pressure thing, I don't believe in going over the max sidewall pressure in any situation. Realize that the mfg rating is a compromise between handling and comfort. The softer tire rides better , but rolls over when handling. The higher pressure handles good but rides real stiff and is harder on the suspension. You may or may not know that the softer (32psi) actually runs hotter and more prone to blow outs than a higher pressure due to increased rolling resistance. An under inflated tire is as much if not more un-safe than than a slightly over inflated tire due to that. I run 38 because for me, going higher just gets too rough. As it is, people still comment on how good it rides for a small car! I have gotten over 40 twice on a 99% highway trip at 70-75 with ac, so it is possible without trying very hard. I wonder if, since you are in New Mexico, that your altitude is much higher and that's why yours is lower? I'm at like 700 ft above. but the humidity here sucks big time!!! I don't care if it is better on mileage,I'd give up 3-4 mpg to have the Colorado humidity back. Oh yeah, mine is a 2010 sedan w/automatic |
#2 | |
Drives: 07 sedan Join Date: Mar 2010
Safe/Sane the yaris won't break 40 mpg in MOST conditions. Breaking laws and driving unsafely, its easy to get most 4 cylinder light cars above 40 mpg. And I never said I don't like reading the FE/fantasy threads. I enjoy it thoroughly. |
#3 |
Crazy Oil Sniffer
Drives: MM 09 Yaris 5 Dr LB "Click" Join Date: May 2009
Well I calculate at the pump the old fashioned way and my last two tanks were 46.2 mpg and 45.4 mpg respectively. With a granny tranny, almost constant AC use, mostly 10 mile trips in very hilly rural/in town/city driving. I do not "pad my numbers".
The "stupid" stuff I do includes 60 psi in tires, moderate acceleration, speed limit or slightly less, timing traffic lights, minimize idle time, and maximize effective DFCO use. Gotta love the mentality where one hasn't done it so others who have must be lying. Does it take effort? Yes. More than most would deem feasible I'm afraid. I still can't hold a candle to some here in terms of FE but I'm trying and steadily improving. Oh, and for those that don't like people posting about their FE here's a tip-don't read FE threads! R2 |
#4 | |
--[ FORUM RULES ]--[ SEARCHING TIPS ]--[ EYELIDS PICS ]--[ RBK SPOILER ]--[ BEST/WORST INVESTMENTS ]--
#5 |
'07 to '12:2 wipers to 1?
Drives: '12 5-door LE & '14 5-door LE Join Date: Apr 2007
my wife' yaris has a roughly 5 mile one way trip to work. lots of stop and go. Her tank gets filled around 270 miles. Her avg mpg is 26-28; she puts in 10 gallons give or take a few ounces. The yaris is a 2007 with around 18,000
My honda civic has a 26 mile one way trip to work. mix of stop and go and over 2 mile cruising areas.I fill up anywhere between 320-390 miles. I put between 11-12 gallons; I avg 30-33 mpg. my civic is 10 years old now with 115,000 miles its more than driving habits when it comes to mpg. |
#6 |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 08 Yaris sedan auto / Fit auto Join Date: Oct 2009
wonder how much fuel saving tires could help bump up the gas mileage ? 2 > 4 ? Anyone actually put these on their YARIS with better m.p.g.s ?
#7 | |
I had Michelin HydroEdge tires on my 95 Civic. It's hard to say how much of an improvement there was since my commute changed a few months after the install from 60 miles (no traffic) to 130 miles (moderate to heavy traffic). I was also driving 70+ MPH. If you want to check out the gaslog it's available at http://www.gassavers.org/garage/viewgaslog/1277 Last edited by KrazyDawg; 07-21-2010 at 04:19 PM. |
#8 |
School'er of hard knocks
Drives: Silver Yaris 4dr. HB Join Date: Oct 2008
I actually managed to crack 41mpg with my automatic. Ran about 60mph for 98% of a trip to Ottawa, with only very minor (under five minutes) stops, once for gas, another for food, then parked once overnight and returned home the next day.
This was in the full-tilt heat of the summer (a scorching 30 degrees celcius at a minimum all day long). I ran with my front windows down, and the rears cracked open a bit. To note: I carry lots of "extra" junk in my car, blow-out first aid kit, rescue and recovery tools, survival equipment, work briefcase and suitcase, car-washing stuff, etc. Basically, I'm always towing around an extra couple hundred pounds of gear. My A/C generally only gets used when I have passengers in the vehicle. I also don't do any serious hypermiling, minus shutting down the engine at a train-crossing in use, DFCO'ing downhill, running my tires at 42PSI in the front, 40PSI in the rear, and maintaining a steady speed below 65mph (and obeying posted limits in-town). I seem to average 36mpg with modest driving nowadays, and an average of 38mpg when I take it on a trip with 95%+ highway rolling. Those MPG's, of course, began after I thought I had heard the engine shear itself to death... ![]() And yep, ain't ever giving up my slushbox. The manual box is hoots of fun, until you get caught in a traffic-jam.
#9 |
![]() ![]() ![]() Drives: 07 liftback Join Date: Nov 2008
i do mostly city driving now, and I get 36 in the city, with ac, in a 5speed, and I drive as firemachine69 put it, like an ass hat some days....
when it was listed at 36/40 backin 07, i would only go slightly over that mark some times, but at 29/36... that's ridiculous
#10 | |
Nothing beats a Toyota!
Drives: 2013 Yaris 5 dr liftback Join Date: Jan 2009
The Yaris, with some very simple changes, i.e., smaller engine and diesel engine, could get 40+ MPG on the EPA tests.
Big Dave Indianapolis, IN Synthetic Oil....its in my car.....for at least 10,000 miles! ![]()
#11 | |
#12 | |
It's a weak analogy you present, but I'm sure many people would answer yes and yes.
#13 |
resident senior
I'm with Garm on the restaurant thingy . You get what you pay for and you only get one life .
I avg 27 mpg on track days . With speeds ranging from 5 mph to 110 mph . But I will say there is a 100 lb difference in my "track" weight versus my "street" weight . I usually avg 40 mpg in street form . My high being 49 mpg and my low being 36 mpg (first tank) . Yes I coast , draft , and don't brake for turns . My tire pressures are 32 psi for street , 34 psi for The Dragon , and 36 psi for the track .
#14 |
Only Happy When it Rains
To me 5% sounds like nothing, and I would probably use that much fuel annoying some eco freak with a burnout or two just because I could.
If you do use enough fuel though, it could add up. However, at 15,000 miles per year at 40 mpg is 375 gallons. At 42 it is 357. that is 18 gallons. At $3 a gallon for gas that is $54 a year. Not a big deal to even me. Now if the difference was 35 mpg to 45 mpg, @ 45 mpg it is 333 gallons, while 35 it is 429. That is a $288 difference, and could be worth it, even to me.
Colin Chapman disciple |
#15 |
love to drive
Drives: 2010 yaris sedan Join Date: Sep 2009
![]() with our 2010 4dr auto a/c on part of the way.we were able to get 50mpg on our last two roadtrips (HWY)and in the city 34-36 mpg. love it
#16 |
Best thing you can ever do for your gas mileage, is to take it easy. Don't speed excessively, stomp on the gas pedal, or mash the brake pedal (without reason). Nice and smooth is the way to go (and get traffic flowing well).
#17 | ||
If you are going the posted speed limit, you are never the problem. Sorry, but just because everyone decides they can ignore a law doesn't mean the law is not valid. I don't let people bully me in person, and I certainly wouldn't on the road. Brake checking people is fun, especially morons on motorcycles. ![]() And btw, it is a speed limit, not a speed suggestion, meaning you are able to go slower if you choose, and that is a-ok. And that bs about a dangerous situation is just that, bs. Sorry but if someone else does something stupid around me it is not my fault. It is theirs, and I hope it gets them killed so they don't go and injure someone else with their stupidity. If you are a safe driver, then no one will be able to cut you off to the extent where you are forced off the road. That is idiocy at the highest level to think that. And if someone chooses to tailgate you, slowing down and brake checking cures that really really fast. And now with most police arresting people for agressive driving, people will think twice about doing something stupid. So sorry, you couldn't be more wrong in what you said.
#18 | |
![]() ![]() Drives: Yaris, duh Join Date: Jun 2010
I have to agree with you on the slowing down, but please don't brake check people. It might cause an accident. |
| NEWS: TOYOTA REVEALS ALL-NEW YARIS SEDAN AT 2006 LOS ANGELES AUTO SHOW | VitzBoy | General Yaris / Vitz Discussion | 7 | 09-20-2023 08:50 AM |
| News : 2007 Toyota Yaris - the little Euro's official arrival | VitzBoy | General Yaris / Vitz Discussion | 9 | 06-06-2017 01:51 AM |
| Yaris In Forza 3 | whooppee777 | Off-topic / Other Cars / Everything else Discussions | 61 | 04-03-2010 05:36 PM |
| New Toyota Yaris | jaspie | Australia | 6 | 11-05-2008 10:23 PM |
