Old 09-03-2012, 02:27 AM   #1
kinda hope the group buy won't be for a while since I won't have that kind of money until a (long) while.
Old 09-06-2012, 05:02 PM   #2
yarisugi
やりすぎだ~
yarisugi's Avatar
Drives: Me: Nuts:
Think of the airbag as an accordion-style balloon with really thick walls. The "balloon" is attached at the top and bottom perches where the spring would normally sit. Put air into it and the bag expands vertically. Remove air from it and it compresses. Since the air in the bag doesn't escape on its own, your car will always remain at the same ride height depending on amount of air inside. As for going over bumps, you do not need to refill them because the air inside the bag does not go anywhere when the bag compresses over bumps. Like a balloon, the airbag will expand outward slightly under compression, but return to its normal state after going over the bump.
@CTScott - I could measure it this weekend if you want. What part do you want me to measure?
Old 09-06-2012, 05:16 PM   #3
Any measurement that I can compare to stock would be great. Perhaps raise it up all the way and measure from the top strut bolt to the bottom of the strut tower?
Old 09-06-2012, 05:17 PM   #4
1.5
Form>Function
1.5's Avatar
Drives: 07 Flint Sedan
I see perfect thanks.
I was aware of their shape and how they sat in the unit thats why I was unsure of how they react to bumps. It would be brutal if you filled them and they sat like big rocks and didnt move lol. Thats pretty cushy I imagine must be nice for a daily. Under extreme pressure can the bags rupture? Assuming you would probably have to do Dukes of Hazard stunts to put that much pressure on them lol
Old 09-06-2012, 05:22 PM   #5
yarisugi
やりすぎだ~
yarisugi's Avatar
Drives: Me: Nuts:
Rupture? Definitely.
That's why a warning is given for any bag install - NEVER drive when bag is maxed out or when bag has no air at all.
Airbag like virginity, one prick all gone.
Old 09-06-2012, 05:23 PM   #6
1.5
Form>Function
1.5's Avatar
Wow thats good to know what about debris? Can it gouge/pop bags?
Old 09-06-2012, 05:29 PM   #7
yarisugi
やりすぎだ~
yarisugi's Avatar
Drives: Me: Nuts:
Well, actually the wall of the bag is pretty tough and able to withstand any road debris. You would have to deliberately puncture it to make a hole.
@CTScott - I'll see what I can do.
Old 09-06-2012, 05:48 PM   #8
1.5
Form>Function
1.5's Avatar
Good info. Thanks
Old 09-08-2012, 11:54 AM   #9
DINOeggxo
DINOeggxo's Avatar
Drives: white yaris hatchback.
sorry havent been checking much the past few days. been busy
my kit has a beveled rear bag (like posted above) and the fronts have a slimmer sleeve like bag. like the bag on the front strurts seen on this scion kit http://bagriders.com/modlab/products...ANAGEMENT.html
as far as bag material: like already said its pretty heavy duty, much like the bags you would see on semi trucks or city buses. only they are much smaller, and those bags go for 100's of thousands of miles normally without problems. i really feel like that if i ever have a leak in my system it wont be from one of the bags. *knock on wood*
@CTScott: for my max ride height the fronts probably put the car at the same height it was on Micro Image springs. the rear when maxed out probably has almost 2 feet of lift above the wheel haha. but like has been said it is NOT suggested to drive around for long periods of time with the bags maxed out. the ride is VERY VERY hard and could cause ruptured bags.
thanks yarisugi for chiming in also with his bagged knowledge and experience. thanks for answering the question about how the bags act as the springs.
http://www.facebook.com/events/409623035736058/ i will be at this event in the cleveland, OH area. if anyone wants to check it out in person
DINOeggxo is offline   Reply With Quote
Old 09-10-2012, 01:52 AM   #10
yarisugi
やりすぎだ~
yarisugi's Avatar
Drives: Me: Nuts:
@CTScott - Sorry, I couldn't measure from strut bolt to tower. Why? Because the
aigbags are filled with air, blocking my tape measure. So I measure it another way.
I measured vertically from hub center to fender edge. I suppose this would be a good
reference point regardless of tire/wheel size. Front measured 16 inches and rear was
17-1/2 inches. Hope this helps. The picture is of the suspension at its highest point.
Old 09-10-2012, 06:58 AM   #11
^ Actually that is perfect. I am trying to figure out for Crashy 2 if I can use airbags to allow me to transition between plowing height and driving height.
Old 09-10-2012, 09:42 PM   #12
jerome
Toyota
Drives: '11 5dr/5spd yaris
oh wow, it's nice to see this stickied.
jerome is offline   Reply With Quote
Old 09-10-2012, 10:07 PM   #13
vten
im torn between getting this airride kit or do an upgrade to a better coilover set :P
Old 09-11-2012, 02:25 PM   #14
sasquatch
Drives: 04.:R32, 87 Scirocco, 07 yaris
Depending on what you're doing with the car air is awesome!! But if you want all out performance real good coilovers can't be beat (at least not yet in the yaris market: Air Lift has a track car sti running it's air ride). If you want awesome looks then air all the way
The adjustability and looks when slammed is awesome. I love dinoeggs car, driving it is real fun too.
sasquatch is offline   Reply With Quote
Old 09-12-2012, 01:25 AM   #15
vten
Yeah ... I'm liking the idea that you can slam the car all the way down when parking :)
Any update on the price Sasquatch ?
Old 09-13-2012, 10:28 AM   #16
sasquatch
Psh I wish. Our friend is still working.
The problem is that the manufacturer that made dinoeggs doesn't really want to sell Just struts as they make some kits too. But the rest of the kit is expensive and kinda crappy for how much you pay. So our dealer is tryin to get them to sell just the struts because he would be able to supply a wider variety of management options amd make a better kit for less money and be able to give you great after sale customer service if needed.
I'm either case the struts will likely remain as "built to order" because most companies see no market in the yaris scene. He'll air lift is one of the largest companies in the game and they don't even make mk1 VW front struts for the same reason.
Hopefully we will hear soon
Old 09-20-2012, 10:30 PM   #17
J.A.R.V.I.S.
war machine
Drives: 2012 yaris LE
I would be down for a group buy
J.A.R.V.I.S. is offline   Reply With Quote
Old 09-20-2012, 10:39 PM   #18
1.5
Form>Function
1.5's Avatar
Drive it like you park it.
DIY Cabin Air Filter BailOut DIY / Maintenance / Service 105 06-20-2019 12:59 PM
DIY - Cabin air filter location (Belta, Vios, Yaris sedan) Murtaza_murti DIY / Maintenance / Service 5 04-05-2012 11:03 AM
Tata Motors to introduce Air Car - Is it the next big thing? *MAD DOG* Off-topic / Other Cars / Everything else Discussions 24 09-29-2010 11:42 AM
Autoloc Air Bag Suspension System Malaya1221 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 9 04-24-2009 10:53 AM
$7 Ram air intake pictorial turbodiesel Performance Modifications 19 10-27-2008 05:46 PM
