Old 05-28-2014, 11:58 AM   #1
lambros
lambros's Avatar
Drives: TOYOTA YARIS S 2009
The European Yaris fog light relay is: 90080-87021
The Tyco VFM-11F41-Z16 is an aftermarket equivalent, which is less than $10 US.
That relay I use to my friend yaris...18€....dealer price 90€...the same job..
lambros is offline   Reply With Quote
Old 10-06-2014, 03:39 PM   #2
ucsmfu
Drives: yaris le
where can I buy 2012 Yaris hatchback fog light kit ?
Thanks
ucsmfu is offline   Reply With Quote
Old 01-13-2016, 06:23 AM   #3
That connector diagram is showing it from the pin side, so imagine flipping that diagram to the left, like flipping a page, then you are looking into pins 3 and 4 where the green and violet wires are.
If you wanted to test without crimping, you just stick a paperclip or piece of stripped wire into the back of those two wire holes to make contact with the pins.
To turn the fogs on you can splice those two wires in place - you do not need to cut them, as the OEM fog light switch would simply complete the connection between the two wires.
If you wanted to use a switch you could tap a wire separately to each and go from the wire to one of the switch contacts. You only need a single pole switch, so just two contacts are used.
Old 01-13-2016, 10:04 AM   #4
Eforno
Drives: Toyota Yaris 2014 LE
I didn't know a t-tap/scotch lock can just combine 2 wires together without one end of a wire cut off. Or did you mean like stripping the middle of each wire and that twisting them together? And if I were to wire my fog lights this way, the fogs likes will be on & off with respect to my DRL, Low Beam, and Hi-Beam being on & off?
I was actually planning to just use the four wire switch that comes with the fog light kit. So should the install be something like what I thought of before:
Originally Posted by Eforno View Post
And as for the fog light switch, can I just tap any of the two of the four switch wires to the purple or green pin wires? What do I do with the remaining two wires from the fog light switch? Fuse tap one of the wire to dash illumination, and ground the other wire?
Thanks once again for the prompt reply! And I'm really sorry if it seems like I'm sounding too dense, I just want to make sure everything is correct before I start the install.
Eforno is offline   Reply With Quote
Old 01-13-2016, 08:33 PM   #5
Some are capped on one end for one wire, but most are open on both ends allowing tapping of two wires without cutting either.
If the kit was aftermarket you will likely not be able to use the switch, as the aftermarket foglight kits have internal circuitry which bridges the switching and illumination circuits. The OEM switch does not do this, so you would either need to modify the aftermarket switch or use a generic switch.
Old 01-13-2016, 09:58 PM   #6
Eforno
Ooo, I thought that all scotch locks had a sealed end on one side; thanks for letting me know. As for the a generic switch, would this one do?
Also I tried removed the lower switch panel with some prying toolstoday, but it just wouldn't budge. Can I just pry it open enough and than just apply controlled force to pull it off?
Old 01-13-2016, 10:13 PM   #7
I am not sure on the switch. Not enough info to tell.
I believe only the switch blank removes, not the whole panel. I personally have not taken apart a 3rd gen.
2012 Fog Light Kits TimmyTwo2 Third Gen Yaris General Discussion 4 10-06-2014 03:41 PM
2012 Fog lights FIY Absolutely Red 12 Third Gen Yaris General Discussion 1 09-17-2012 10:31 PM
2012 Yaris LB Fog Lights TimmyTwo2 Cosmetic Modifications (Exterior/Interior) 6 03-21-2012 04:54 PM
Need fog light switch and relay Jrilla DIY / Maintenance / Service 23 07-01-2011 11:12 AM
