Old 04-19-2013, 11:39 AM   #55
Focus_Sh1ft
Focus_Sh1ft's Avatar
Also digging the gauge pod. That's a pretty decent fit.
Give us more pics!
Old 04-19-2013, 12:29 PM   #56
Yoda
Yoda's Avatar
Drives: 2008 Black Sedan
And so it begins.....
Old 04-19-2013, 02:42 PM   #57
yariSB86
yariSB86's Avatar
Drives: 07 Bayou Blue Yaris LB
Thanks guys! burning and turning hard with this install.
have a couple questions regarding the boomslang pnp harness.
first question is where does this inline fuse go(it is a 10amp fuse)? does it replace the 7.5 fuse labeled ECU-B?
next question is, these two wires look kinda important and I just want to make sure if I need them or not. one is white with a blue strip, the other is brown with black stripe.
yariSB86 is offline   Reply With Quote
Old 04-19-2013, 04:44 PM   #58
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
iirc I used a spare slot for my BSlang...I can try and see if I can get you better info...I currently have mine disco'ed. Yes, I am running without management, but have dropped my MV-S spring to the 3.5psi one until I upgrade my management. All I can say as well is be really careful with the lock arms as mine broke after only a year and removing/installing the harness a half dozen times.
Old 04-19-2013, 05:28 PM   #59
fnkngrv
fnkngrv's Avatar
^ Nope...can't recall where I plugged it in. Perhaps Focus or CTScott can chime in if they can recollect. Sorry.
Old 04-19-2013, 05:47 PM   #60
yariSB86
yariSB86's Avatar
Alright next question.
For the oil return, if I am not using the zage oil pan, what is the best way for doing this return line? (drilling a hole in my engine is almost out of the question)
Old 04-19-2013, 06:46 PM   #61
If you aren't using the Zage pan, drilling a hole and installing some fittings is the ONLY other option. Very nice pictures on our forums (and probably on here too).
Old 04-19-2013, 08:06 PM   #62
yariSB86
yariSB86's Avatar
Damnit Garm :( I was afraid of that.
pm sent to you btw.
Old 04-19-2013, 09:34 PM   #63
yariSB86
yariSB86's Avatar
so back to this:
its a wired in 10amp fuse pre wired on the AEM F/IC harness. where does it go?
Old 04-19-2013, 11:28 PM   #64
yariSB86
yariSB86's Avatar
Turbo kit is installed.
Still need to:
Cut some plastic around intercooler piping
Tap the block for oil return...
Add oil
(Man my brain is fried, been working on this from 10am through 11pm.) can't think right now...going to bed.
Old 04-20-2013, 01:47 AM   #65
Focus_Sh1ft
Originally Posted by yariSB86 View Post
so back to this:
My FIC harness didn't have that prewired. However, AEM likely revised their harness in the last few years to include it because people were probably hooking up their FICs unfused. Thus, if wired incorrectly - the unit gets fried, and AEM is left having to replace it.
As for where it goes, you have quite a few options at the fuse box in the engine bay. Ideally, you'll want to hook it up in place of another 10 amp fuse that only receives power on ACC or IGN. I'd check ECTS and EFI2 to see if they have voltage on key off, I can't remember.
Even if you have a constant 12v, the FIC has very little parasitic drain (pretty sure I actually have mine hooked up to a constant 12v).
Also, drilling the block - not as daunting as it sounds. Use the fittings I have in my guide, seal it up with some permatex, and you'll be fine.
Keep it up! It's worth it in the end
Old 04-20-2013, 07:11 AM   #66
yariSB86
yariSB86's Avatar
Thanks focus. The fuse went to efi.
Gotta go shopping today, don't have the right drill for this.
Old 04-20-2013, 08:23 AM   #67
thefalls
Drives: Axio GT
The TRD option for the oil return is a banjo bolt into the oil drain plug.
Let me run get a pic.
thefalls is offline   Reply With Quote
Old 04-20-2013, 10:06 AM   #68
yariSB86
yariSB86's Avatar
so I don't have to tap the block?
Old 04-20-2013, 11:19 AM   #69
fnkngrv
fnkngrv's Avatar
Here is a photo and yes I flipped it upside down to make it easier orientation-wise...haha
I thought we have been over this already? You are not tapping the block. It is the Upper Oil Pan Sub-assembly.
You will want to tap the upper pan to prevent possible smoking in the future.
Old 04-20-2013, 03:46 PM   #70
yariSB86
yariSB86's Avatar
Yes, I understand where the tap goes. Just seems like getting couple different answers about this.
I bought a small angle drill, tap set, some jbweld, silicone sealant, loctite, Teflon paste, and the fittings I am going I use. (Not sure what sealant is better)
Already have the hose(came with the zage kit) and clamps.
Now when I drill this hole, I'm going 1/2", what is the best way of making sure there are no metal shavings in my oil resevoir? Pour my used oil in and let it drain (do that a couple times)?
Old 04-20-2013, 04:23 PM   #71
I don't give a hoot what people call it. Pan, or block, makes no difference -- you will drill a hole and install a fitting. You can reach it easily from underneath with the pan off.
You'll have the pan off, so I don't understand this question, sorry.
Old 04-20-2013, 04:25 PM   #72
^ You just have to be careful not to have a low spot or a kink in your return line. You are correct, the Zage pan is being used by some customers. I'd say it's about 50/50 from the kits we've sold.
List of Boosted Yarisworld Members - Redux CTScott Forced Induction Forum 40 06-29-2025 08:42 PM
List of Boosted Yarisworld Members whooppee777 Forced Induction Forum 262 11-23-2022 05:49 AM
Boosted Yaris Quarter Mile Times 1.5 Forced Induction Forum 0 01-03-2010 05:49 PM
Going Boosted FryGuy Forced Induction Forum 53 03-01-2009 10:01 PM
PE Boosted Yaris Video jinxor Forced Induction Forum 16 02-06-2009 02:33 AM
