Old 05-12-2009, 01:35 PM   #55
d1nzfe
Drives: 1NZ-FE
i tried,it will NEVER get full. NEVER...
a teaspoon and that is it!
d1nzfe is offline   Reply With Quote
Old 05-16-2009, 02:15 AM   #56
MGargano
Drives: 2009 Yaris Hatchback
I'm looking to do this mod but I'm wondering if anyone knows the correct hose diameter for the tubing on the 09. I think it's 3/8" but not positive and I want to be sure before I buy the filter.
MGargano is offline   Reply With Quote
Old 05-16-2009, 02:02 PM   #57
marcus
toyota
marcus's Avatar
Drives: 2007 Yaris RS Blazed
i read that this air filter will drop pressure by 5 psi would that effect the engine performance? ANYONE!!!!!!!!!!!!!
Old 05-16-2009, 02:22 PM   #58
1stToyota
1stToyota's Avatar
Always heard that this was a popular and necessary mod when forced induction is added or boost is increased above stock levels. I'll just stick with injector cleaner once every 5k miles and 3m throttle plate cleaner, should the need ever arise.
1997 Lincoln Town Car - SOLD
2008 Scion xD
(w/ automatic) - SOLD
2008 Yaris HB - SOLD
Old 06-11-2009, 01:54 PM   #59
marcus
toyota
marcus's Avatar
well ...would a 5psi drop affects the engine performance when using the oil catch can. im ready to do this..
Old 07-06-2009, 03:36 AM   #60
yarisugi
やりすぎだ~
yarisugi's Avatar
Drives: Me: Nuts:
Thank you Ogredude. I was able to complete this using your DIY.
Looks a little different, but same thing. Cost me about $25 :)
Old 07-06-2009, 11:44 AM   #61
marcus
toyota
marcus's Avatar
NICELY DONE..what size tube did you use..
Old 07-06-2009, 10:59 PM   #62
yarisugi
やりすぎだ~
yarisugi's Avatar
Drives: Me: Nuts:
I don't remember but the inside diameter was fitted for 3/8". It was from a left over hose.
Old 08-31-2009, 05:29 PM   #63
GMKing
Drives: 2007 toyota Yaris sedan
After reading this whole thread I'm still left confused.
from factory ALL manufacturers have a very tiny amount of oil fed to the intake system.
and you guys are trying to collect it before it gets there?
I understand the idea of preventing extra oil from burning in your combustion process, and keeping this extra oil off of your valves, particularly if it's about time to change your oil and it's got an amount of junk in it that you'd prefer not to get into your intake or on your valves.
but has anyone honestly considered WHY the manufacturer's ALL do this? they want your engine to be reliable (nearly) as much as you do, as well as FE. They must have some reason for creating this line and doing this. The only reasons I can think of is the air intake is metal right? metal corrodes. Corrosion prevents airflow, and airflow over corrosion passes right into your engine. now your engine is steadily eating rust (or oxidation, which the engine would eat to a much lessor degree).
also I can imagine that this oil many of you are deciding to prevent from going into your engine is lubricating your valve and valve seats, so that they create a decent seal when closed and last longer then bare metal hitting metal. It's very possible I'm wrong, and I'd love to believe that this awesomely cheap mod is good for my engine and it's longevity, however I cannot do so without having the above statements properly debunked.
GMKing is offline   Reply With Quote
Old 11-22-2010, 09:02 PM   #64
Judas Iscariot
Drives: 2008 Yaris HB
+1
bumpity
Judas Iscariot is offline   Reply With Quote
Old 11-23-2010, 06:39 AM   #65
Midnight Drifter
Going Retro
Drives: '09 Tacoma | '90 Tercel
On my Supra, I just vented the PCV to atmosphere. What's the point in spending money on a catch can?
Midnight Drifter is offline   Reply With Quote
Old 11-23-2010, 07:42 AM   #66
anexrx7
Drives: 08 MM HB
You let your Supra get all grimy from blow by? After an hour of running the RX7, that crap is everywhere when I have a leak on the vent hose.
anexrx7 is offline   Reply With Quote
Old 11-23-2010, 07:56 AM   #67
Midnight Drifter
Going Retro
Well I had a metal braided hose running from the vents down to the oil drain plug, I never had problems with leaks. I thought it looked kinda cool like that.
Friend of mine did the same thing with his Corolla SR5, still working great on his car.
Old 11-23-2010, 11:45 AM   #68
ilikerice
ilikerice's Avatar
Drives: 2010 black yaris
^^^i admit... on my budget crx and first time doing a piece by piece turbo setup i ran a hose off my valve cover running under the car.. ran great for two years.. til i got into autocross and turbo+street tires=zero grip.. took it off and sold it. im sorry mother nature.. i was a dumbass..
i remember the first time i ran my crx full boost without a hose on the valve cover just to test drive it.. when i hit about 6k rpm oil shot under my hood and all over passenger side windshield.. my ass was so tight when that happend..
Old 12-19-2010, 11:42 PM   #69
darkMINI
Drives: 08 hatch
Found this sick little tank on e-bay last night. It's perfect.
http://cgi.ebay.com/ebaymotors/ws/eB...=STRK:MEWAX:IT
'08 3dr HB, Black Sand, AEM, 16x6.6 Mini-Cooper wheels, DynoMax, Cruise, de-TPMS'ed.
darkMINI is offline   Reply With Quote
Old 05-06-2011, 01:54 PM   #70
goliath1812
goliath1812's Avatar
Drives: 2010 Prius, 2007 Yaris Sedan
Sorry for the resurrection of an old thread, but has anyone ever thrown any codes with a catch can? I just did this, I used the Husky filter from Home Depot, and just got a P0171 code. The only difference is I used another short section of hose from the PCV valve to the Husky filter, instead of cutting the stock hose. Could that be the problem? I'm sure all of the fitting are tight, and there are no leaks....
Sorry about the pic quality, it's taken from my phone.
goliath1812 is offline   Reply With Quote
Old 05-06-2011, 02:09 PM   #71
mario98c
mario98c's Avatar
P0171 System Too Lean (Bank #1)
Old 05-07-2011, 08:43 AM   #72
JTDBT903
JTDBT903's Avatar
Drives: '08 SEDAN 5 SPD.
I would say that the hose is collapsing under hard throttle, setting off the code. Check the hose under part/full throttle to verify this.
I have a Mazda MPV van that has a notorious problem with a inferior pcv hose connection and throws a similar code!
JTDBT903 is offline   Reply With Quote
best synthetic oil and m/t oil?? doodoo DIY / Maintenance / Service 122 04-03-2017 08:43 PM
Synthetic Oil Kaotic Lazagna DIY / Maintenance / Service 122 09-20-2007 03:40 PM
metal particles in oil 007 hatch DIY / Maintenance / Service 9 06-22-2007 02:56 AM
DIY Oil Change Bassmonkey DIY / Maintenance / Service 42 02-19-2007 08:37 PM
