Old 04-01-2009, 10:24 AM   #55
changchewsoon
Drives: Vios Turbo
Send a message via MSN to changchewsoon Send a message via Yahoo to changchewsoon
Would like to share this model of coilover:
Hot Bits DT2 Series:
- Oversized 52mm shock bodies for SUVs and 4WDs and 58mm struts for cars
- High-pressure mono-tube shock design
- 46mm shock piston diameter
- 22mm shock piston on 4WD products for enhanced durability
- Motorcross grade seals
- 40-step rebound adjustment (up to 80% change) and 30-step compression adjustment (up to 50% change)
- A superior grade, interchangeable 60mm CNC cold wound silicone steel coil springs
http://www.hotbits.org/new/dt2.php
454 whp, 1.7 bar boost, pump gas, water/meth.
501 whp, 2.2 bar boost, pump gas + avgas, no water/meth.
www.viosturbo.com - World's first 500 WHP 1NZ-FE
changchewsoon is offline   Reply With Quote
Old 04-01-2009, 10:57 AM   #56
hatchbackkid82
Drives: .
$2K..umm...no thanks i'm ok
Old 04-01-2009, 11:06 AM   #57
changchewsoon
Drives: Vios Turbo
yah it might be pricey to certain people, but you get what you pay for though.
Old 04-01-2009, 11:09 AM   #58
hatchbackkid82
Drives: .
yeah i'd rather pay 1300 for a decent set. not track racing the car. If i was track racin gthe car then yeah i could see it.
Old 04-01-2009, 11:19 AM   #59
changchewsoon
Drives: Vios Turbo
the thing i like about them is the cheap cost for servicing the shocks, to re-oil and re-valve the whole thing costs only about 20 USD per shocks.
Old 05-11-2009, 12:40 PM   #60
Sabretooth
37HSSV
Sabretooth's Avatar
Drives: '11 Mazdaspeed 3
Found these:
HKS S-Compact
Front 5k Rear 8k
30 Way Adjustable
Link- http://www.bulletproofautomotive.com...il.php?ID=5266
Old 05-28-2009, 03:18 PM   #61
scape
scape's Avatar
Drives: 2007 Yaris Hatchback
Originally Posted by yarstar View Post
After a year I wanted more power and better cornering. I first went with lighter wheels (Enkei RPF1s) with 195/50/R15 tires. Then I got some coilovers.
D-A-M-N!!!
I appreciate all the input found here. I've never even heard of coilovers before, and I'm glad I found you guys. I am also really glad I invested my money in the "good stuff."
Where'd the TRD springs go? ;D
I also was looking at getting the 195/50 tires in 15's, and saving up for those same rims, ;D
how is the gearing now that you're at that profile of tire, I was thinking of going 195/55 personally to try and keep things similar to my 185/60's
would you say the coilovers are heavier than regular spring/shock combo?
Old 05-28-2009, 04:13 PM   #62
yarstar
Drives: 2008 Absolute Red HB
Sold the TRDs to another member here.
Gearing is fine. The only difference I notice is my speedo reads 80 mph and the GPS shows actually I'm going 75. Not a big deal to me. The real difference is the handling. The 195/50s have a stiffer sidewall so there is not alot of tire roll in turns. The S Drives really stick too.
Save your money up. the RPF1s are worth every penny. I've had Konigs and cheaper wheels, and you really get what you pay for. The finish on these is fantastic, and the weight advantage you really see in acceleration. Save up and get them. You will not be disappointed.
There is no weight difference that I noticed from stock springs/struts to coilovers. Again, just like I said to begin with, I am amazed at how well my car takes turns with them on. It carves like an expensive sports car. I live in the Mountains and drive twisty roads daily. I have so much fun, I sometimes take the long route just to enjoy my car.
AEM CAI, NST Pulleys/SSK, WR 4-2-1 Header, TRD axelback, R1 Concept Rotors, TRD Sway Bar, Nitto Rear Strut Bar, Cusco GT-Zero Coilovers, 1ZZ-FE 1.8L TB
yarstar is offline   Reply With Quote
Old 05-28-2009, 09:30 PM   #63
m911gt
Carless in Chicago
m911gt's Avatar
Drives: 08 Blk LB
Anyone have experience with the BC Racing Coilovers? Impressions?
http://www.eracingworks.com/BC-Racin...g-p-44254.html
Wanted: Forced Induction
Old 06-12-2009, 02:28 AM   #64
CDavis7M
Drives: 1990 Supra Turbo
I have not bought the HKS S Compact coilovers. But, the site lists them at 5kg/mm in the front and 4.6kg/mm in the back. So, roughly (F/R) 280/260 lb/in.
http://www.hks-power.co.jp/products/...0120at008.html
CDavis7M is offline   Reply With Quote
Old 06-12-2009, 03:00 PM   #65
darthbauer
Not really here...
darthbauer's Avatar
Are there any coilover's that can retain the stock height of the car?
Liberate Tutemet Ex Infernis.
Old 06-17-2009, 01:41 AM   #66
darthbauer
Not really here...
darthbauer's Avatar
Anyone?? Anyone??
Old 06-17-2009, 02:20 AM   #67
Thirty-Nine
Small cars are a big deal
Thirty-Nine's Avatar
Anyone?? Anyone??
None that I know of ...
Old 08-18-2009, 10:52 AM   #68
markitect
I'd be interested in some too, does anyone know what set can give you the smallest drop?
markitect is offline   Reply With Quote
Old 08-18-2009, 05:44 PM   #69
rob323
Don't drive it, RALLY it!
Drives: 1999 echo PRC rally car
I'm getting coilovers which will slightly raise my car (for rallying). Anything can be made if you go custom instead of big name off the shelf crap.
rob323 is offline   Reply With Quote
Old 08-18-2009, 05:48 PM   #70
megans and silk roads can be set at stock height, don't know other brands.
Rob, it's about time for a picture update of your project!
Old 08-18-2009, 05:51 PM   #71
rob323
I'll put up a pic of my new front rally shocks with custom strut tops (to allow more shock travel) when they arrive. Will that keep you happy?
Old 08-18-2009, 05:56 PM   #72
+ a few of the cage again? It's like a story -- someone can read it to you over and over again...
OFFICIAL Yaris SEDAN thread SimmZ Photo-Video-Media Gallery 1706 06-22-2025 05:33 AM
Shift lever thread size Chaad32 Cosmetic Modifications (Exterior/Interior) 16 01-30-2015 02:16 PM
Shift Knob Thread Patter? eight_heads General Yaris / Vitz Discussion 6 10-21-2009 10:25 AM
Post Whores-aka Yaris chat thread Black Yaris Off-topic / Other Cars / Everything else Discussions 21 07-12-2007 05:37 PM
Thread request - Yaris is new in the US makaluch Cosmetic Modifications (Exterior/Interior) 1 08-13-2006 12:16 AM
