Old 04-18-2009, 10:08 PM   #55
TinyGiant
Tiny Giant Clothing
TinyGiant's Avatar
there will be 2 holes in the back where the big emblem was if you totally debadge
Old 06-09-2009, 09:33 AM   #56
eht13
Drives: .
Quick question: For rebadging, has anyone used "3M Plastic Emblem & Trim Adhesive", instead of the "3M Body Molding Tape" that seems to be used pretty often?
Thanks.
eht13 is offline   Reply With Quote
Old 06-09-2009, 12:47 PM   #57
id3379
§†ęĄ¶‡Ћ-NCP96
id3379's Avatar
A+
id3379 is offline   Reply With Quote
Old 07-20-2009, 01:52 AM   #58
bibi-
Drives: yaris
yes . i did the same way . but,unluckily,my car got scratch from that .
because i was careless during shaving the emblem :D
bibi- is offline   Reply With Quote
Old 09-09-2009, 03:04 PM   #59
zestia
zestia's Avatar
Drives: 07' yaris
I used a hair dryer to warm them up and then used fishing line to remove. It took a little while to get the excess glue off of the car, but now it looks great.
zestia is offline   Reply With Quote
Old 10-21-2009, 03:51 AM   #60
DrB
Drives: 2008 Yaris
hey guys
greetings from the other side of the pond
i recently debadged my yaris but now i changed my mind and want to put the badges back.
the thing is though that i dont know their exact position.
do you know where can i find it?
the guys in the dealership are ridiculous enough to admit that they dont know the exact position of the badges; they will just put them "where it looks ok"...
so, i dont want to starting wandering in the streets in search of another yaris, just to measure it, and having people thinking i m a weirdo, thief etc...
DrB is offline   Reply With Quote
Old 11-30-2009, 02:34 PM   #61
HTM Yaris
resident senior
HTM Yaris's Avatar
Drives: 07 Yaris
I would like to add a couple of steps to the painting process .
1. Add a few coats of clear to the newly painted badges .
2. After letting the paint dry/cure for a few days , apply a couple of coats of wax .
Old 05-06-2010, 03:54 AM   #62
hexengon
Drives: yaris
how to remove front badge
the instructions are unclear as to how to remove the front emblem , i try sticking my fingers under the grill for the tabs but im not sure what i am looking for as I dont find or feel anything.. can I just use a screwdriver and pry it out by force , if so, am i able to put it back on afterwards
can someone give me clear instructions on how to remove the front emblem, thanks
hexengon is offline   Reply With Quote
Old 06-11-2010, 02:28 PM   #63
RedHatch08
Canadetroiter
RedHatch08's Avatar
Drives: 2008 3DR 5M
Great FREE Modification
Whoo! My first post at YarisWorld...
Anyways, I just did this mod the other day. Pretty easy and essentially free if you already have fishing line, WD-40, and ... the sun.
Looks much cleaner without the badges. Plus it will confuse people even more now. Here in Michigan, lots of people don't know what to make of this car. If it doesn't have a GM/FORD/CHRYSLER badge on it, they think it's a spaceship or something.
I've had multiple people approach me in parking lots and ask me what it is. Even with the badges still on it.
In any case, I think it's time well spent to do this. I just used the "sun method" (no hair dryer or heat gun), so the hardest part was getting the foam/tape stuff off because it wasn't super hot that day.
I just used Goo Gone to help loosen the adhesive. Took a while to get it all off using just my finger nails, but it was worth it.
RedHatch08 is offline   Reply With Quote
Old 06-11-2010, 04:27 PM   #64
TinyGiant
Tiny Giant Clothing
TinyGiant's Avatar
looks great.
its amazing what a difference it makes :)
Old 06-11-2010, 07:16 PM   #65
CtrlAltDefeat
I ♥ Yaris
CtrlAltDefeat's Avatar
debadging was the first mod i did.. looks a lot cleaner
Old 06-12-2010, 05:45 PM   #66
RedHatch08
Canadetroiter
RedHatch08's Avatar
Drives: 2008 3DR 5M
It was actually my second mod.
First thing I did was get a K&N filter since the paper one that came with the car needed replacing anyways (since I got my Yaris used).
K&N Air Filter . Rear Debadge
Old 06-18-2010, 03:49 AM   #67
suprajoey
Drives: 08' Yaris
O' Nice, that little red Yaris looks Sexy..!!
-Also Quick question? Did you remove the rear badge to paint it? Or did you mask taped it, and papper it all around to paint it??
-Also how do i remove it to paint it off the car not on it??
Thanks
suprajoey is offline   Reply With Quote
Old 06-18-2010, 08:06 AM   #68
TinyGiant
Tiny Giant Clothing
TinyGiant's Avatar
lol .. read the first post. dont be lazy :)
Old 06-20-2010, 06:06 AM   #69
suprajoey
Drives: 08' Yaris
Hahaha, i read the damm post three time, before i went out side to remove the front and paint it black, but the rear, you say it will leave two holes? so does this mean that the badge is held together by 2 small clips? or is it held together by 2 clips (+) Plus 3M tape?? Dammit, im just thinking of masking everything around it, and sanding/paint the badge on the car, just dont want to mess up my OEM Paint.
Thanks on the Awsome Thread
BTW: Heres mine.
-Not to worry, my little truck is getting lowered this Upcoming week as well..!!
Old 06-20-2010, 07:33 AM   #70
TinyGiant
Tiny Giant Clothing
TinyGiant's Avatar
the two holes are actually just so the badge is straight. they dont clip in or anything. and its only on the center emblem.
the emblem has two little nubs that fit in the holes. its just for alignment. you wont have to fill anything in or do anything crazy .. just pop it off. you'll see what i mean.
Old 06-20-2010, 06:50 PM   #71
suprajoey
Drives: 08' Yaris
LOL, not to sound dumb, but does it also have the sticky 3M tape on it, just like the Yaris, and Toyota Badge? so i would also have to use the heat gun to remove just like the other badges, right??
-Thanks so much for your responce, and patience.
Old 06-20-2010, 06:54 PM   #72
TinyGiant
Tiny Giant Clothing
TinyGiant's Avatar
Yeah same deal :)
DIY (08' USDM LB): Interior Light Color Change revnull DIY / Maintenance / Service 37 05-21-2016 12:59 PM
DIY Change Your Interior Light Grey Panels to Black KCALB SIRAY DIY / Maintenance / Service 64 01-22-2015 01:25 PM
DIY: LED side mirror installation eTiMaGo DIY / Maintenance / Service 85 06-24-2011 11:48 AM
revamping the DIY section supmet Suggestions - Feedback - Questions 7 03-23-2009 02:01 AM
