Old 06-13-2011, 12:02 PM   #775
duke_afterdeath
duke_afterdeath's Avatar
Drives: 2008 Yaris Sedan
Originally Posted by rosco View Post
after sex daw siya pupunta....este six pala..pagkatapos ng work
baka makadaan din dun.....may dadaan pa kasi akong clip ..nakalimutan ibigay sa akin ng REDLINE.
Yaris X: The Largest Most Organized Pinoy Yaris Owners Group In The Middle East (Central Region Chapter)
Disclaimer: Not Connected to Toyota A.Lathif Jameel ME In Any Way
If everything seems under control, you`re just not going fast enough...
duke_afterdeath is offline   Reply With Quote
Old 06-13-2011, 01:51 PM   #776
rosco
rosco's Avatar
Drives: YaRis ka!--Y?2011
Originally Posted by duke_afterdeath View Post
y tol may lukot ba?
oo tol may lukot ...nasa kanan sa lower part ng foglight
rosco is offline   Reply With Quote
Old 06-13-2011, 02:19 PM   #777
gosuyaris
gosuyaris's Avatar
Drives: Yaris 2010
Send a message via Yahoo to gosuyaris
Originally Posted by armando View Post
gosu an don na ang pipe kila ka bong, kong hindi ako maka dating mamaya ingat lng pag kakabit kc sensetibo yan kahit maliit lng na bahagi ang pumasok dyan e mag luluko yan.
Tnx ng marami tol... Tom ko n lng kunin after opis.. My biglaan na lakad lng knina c she... Btw, knina pguwi nmin galing OMC mdyo ok n ung takbo ni gosu.. Ng 91 na ulit ako kc bka isa pa sa cause is ung pgshift ko sa 95 nung minimeet ntin.. Kutob ko kc my effect din un so mas mabuti na ung sumunod sa tamang spec ng gas pra sa yaris natin which is 91..
gosuyaris@0558478124
gosuyaris is offline   Reply With Quote
Old 06-14-2011, 01:56 AM   #778
rye7jen
rye7jen's Avatar
Drives: 2nz-fe '10
y tol may lukot ba?
Daming "lukots" tol. Wala kasi heatgun nung time na yun. Pero trial and error pa lang naman, try lang kung hindi matutunaw which is positive, hindi pa lumalabo yung yellow film. Hayaan ko muna siya tutal hindi naman ganun ka-obvious mga lukots niya.
rye7jen is offline   Reply With Quote
Old 06-14-2011, 06:56 AM   #779
syntax
syntax's Avatar
kung meron ka pa tint na ganun pre' pwede mo gamitin ang hairdrier para kapag nilagay mo mabanat mo ng mabuti, hindi pa rin ba natutunaw or lumalabo?
Old 06-14-2011, 06:57 AM   #780
syntax
syntax's Avatar
ano na lagay ni gosu pre? ok pa rin ba ang takbo ni gosu?
Old 06-14-2011, 07:13 AM   #781
rosco
rosco's Avatar
pre ok na back to normal na si gosu..kesa dati nag balik loob siya sa gas na 91
pero sabi ko obserbahan pa rin nya...at magpapalit pa rin ng matabang pipe na katulad sa amin.....kasi form 91 nag palit siya ng gas na 95 tapos napalitan ng vrum2x nya at biglang nag air intake na bago...kaya parang nanibago siguro yung makina nya ...sana maging ok na di ba..
kasi parang kape yan.... ..sanay sa kapeng nilaga tapos nakabili ng starbucks coffee...ayun nagtaepeace mike...
Old 06-14-2011, 07:53 AM   #782
duke_afterdeath
Old 06-14-2011, 08:14 AM   #783
duke_afterdeath
tol rosco sinubukan ko ung filter kagabi kahit wala pa ung clamp (clip) tinakbo ko ok naman, napansin ko lang kapag nag shift ka ng gear at di mo pa naabot ung pinaka peak nya nasasakal nga sya pero pag naabot na ang peak saka ka mag shift swabeng-swabe ang hatak, sa tingin ko un ang nagyari kay gosu.. kung baga sa stock kapag nag shift ka from low to high at wala pa sa peak aalog ang makina na parang hirap.. sa tingin ko si gosu di pa nya naabot ung peak nag change na sya ng gear..
tol rosco, advice mo lang ako if nakuha mo na ung clamp
Old 06-14-2011, 08:38 AM   #784
rosco
rosco's Avatar
ok tol tawagan kita pag nakuha ko.....
Old 06-14-2011, 08:46 AM   #785
armando
pilyo
armando's Avatar
Drives: blue yaris y 2009
duke wag mong patakbuhin ng walang clamp baka mahugot malaking disgrasya yan pasok ang dumi sa engine mo, maraming clamp yata kila ka bong
armando is offline   Reply With Quote
Old 06-14-2011, 08:55 AM   #786
syntax
syntax's Avatar
marami rin sa mga hardware store dyan sa atin pre'
Old 06-14-2011, 11:23 AM   #787
duke_afterdeath
uu tol tnx.. testing lang, hehehe.. inalis ko din agad, tinakbo ko lang ng isang round
Old 06-14-2011, 01:04 PM   #788
gosuyaris
gosuyaris's Avatar
Drives: Yaris 2010
Mga tol, sa wakas ok na c gosu... Npalitan na namin ni pilyo ng pipe tas un bumalik na sa normal.. Napansin ko mas pino ung andar niya ngaun.. D n rin gnun klkas ung tunog nung muffler sa loob.. Prang nkstock lng.. Laki nung pgkakaiba kesa nung dating pipe... Hayz!! Sa wakas mkkatulog na me.. Hehehe!
Old 06-14-2011, 01:05 PM   #789
gosuyaris
gosuyaris's Avatar
Drives: Yaris 2010
Thanks tol pilyo sa pipe and sa effort...
Old 06-15-2011, 12:55 AM   #790
armando
pilyo
armando's Avatar
welcome gosu anytime........
Old 06-20-2011, 03:56 PM   #791
rosco
rosco's Avatar
[yaris diffuser
Old 06-21-2011, 01:16 AM   #792
syntax
syntax's Avatar
[yaris diffuser
ganda ! ! ! pwede diba pre?
