Old 11-18-2012, 01:46 AM   #1
Your tooter sure does look purty.
I wouldn't mind having one of those to spruce up my, otherwise plain engine bay. No money for it tho. LOL
Old 11-18-2012, 04:33 PM   #2
tooter
play every day
tooter's Avatar
Drives: 2012 Yaris L 2dr 5sp
That's ok. chaotic... it's always better to live within our means.
I came up with a way to fit the BLOX velocity stack air filter assembly onto the tooter without needing the 90 degree bend connector.
First I got some aluminium pipe which is 6 inches outside diameter from a really cool place called:
intakehoses.com
Then I cut off a 2 inch section and glued it to the backside of the velocity stack...
then slipped the assembly inside the air filter...
And it's all done...
Gonna go put it on the engine now...
Old 11-18-2012, 05:42 PM   #3
tooter
play every day
tooter's Avatar
"Like a glooove... "
Old 11-18-2012, 06:27 PM   #4
very good thinking!
Old 11-18-2012, 08:23 PM   #5
tooter
play every day
tooter's Avatar
Originally Posted by Bluevitz-rs View Post
very good thinking!
I enjoy coming up with nonordinary outside-the-box solutions. Once the idea came to me, the real challenge was trying to find outside diameter pipe. Most all pipe is sized by inside dimensions. However engine intake pipes go by even outside measurements. That website intakehoses.com has all the specialized raw materials to build your own custom designed air intakes as well as intake manifolds. Now that there's a reliable source of materials, I'm already thinking up other ideas to try out.
Old 11-18-2012, 06:45 PM   #6
jetblast
Drives: Gen 1 XB
Not in the military any more, just flyin' them supplies....and unfortunately sometimes the fallen hero's home.
On a lighter note, I always have room for some more sparkling things. Note to self, buy large aluminum chain so wife can wear some of this bling. :)
jetblast is offline   Reply With Quote
Old 11-18-2012, 08:11 PM   #7
tooter
play every day
tooter's Avatar
Oooh... shiny.
Since I've had the cabinet, everything gets stainless steel bead blasted. Does your XB have a 1.5 or a 1.8? And what kind of aircraft do you pilot?
Greg
Old 11-18-2012, 09:38 PM   #8
jetblast
Drives: Gen 1 XB
I'm a 747 cargo flying tech....I slap pilots when they get stupid. Ego's incorporated.
Love the smoothness of that intake flow. Nice find!
Modding the 1.5 up to a 1.8, sigh, dreamin'.
Old 11-19-2012, 12:11 AM   #9
tooter
play every day
tooter's Avatar
I would think that just keeping them awake was good enough.
Thanks, jet... flow design has always fascinated me so it's been really fun experimenting with this manifold project. Everything leads to something else so I'm always on the lookout to see what new idea comes to me next.
Greg
Old 11-19-2012, 07:45 PM   #10
tooter
play every day
tooter's Avatar
Just finished bead blasting the throttle body adaptor and the MAF tube so that everything matches now...
Old 11-20-2012, 12:26 AM   #11
jetblast
Drives: Gen 1 XB
I know on extremely hot days my (heat transferring aluminum) Weapon R intake manifold drops power, but I still like the look. As far as looks go, that project you finished looks smokin'. Thermodynamic efficiency aside, even Toyota/Scion would admit that's one sweet looking motor. Nice job!!!!
Old 11-20-2012, 11:55 AM   #12
tooter
play every day
tooter's Avatar
Yes, heat soak becomes a factor with a hot start on a really hot day, but the tubing on the long runners is really thin with lots of surface area for air to flow over and to dissipate the heat when the car is moving.
Old 11-20-2012, 01:00 PM   #13
why not wrap it in heat reflective tape or polish it to reflect heat.
Old 11-20-2012, 01:26 PM   #14
tooter
play every day
tooter's Avatar
I don't think heatsoak is enough of an issue to bother about once the car is in motion. However, polishing just for the bling of it would be neato.
Old 11-22-2012, 04:17 AM   #15
jetblast
Drives: Gen 1 XB
How about one of the new Plasti-Dip colors, topped off with their Metalizer for a bit of bling. This would insulate too....and easy to peel off if the results sucked. :)
Why strive for a JDM BB, when you can promote the Scion badge?
Old 11-22-2012, 11:17 AM   #16
tooter
play every day
tooter's Avatar
I like black...
...so I might see what it looks like with a cheap rattlecan coat of high heat BBQ.
If it doesn't look good, it can easily be removed.
Old 11-26-2012, 11:07 PM   #17
tooter
play every day
tooter's Avatar
Did back to back stock manifold and tooter dyno runs today with the modified BLOX intake.
Tooter is blue, and stock is red.
Old 11-26-2012, 11:15 PM   #18
Awesome to see some gains!!
homemade intake manifold ttr125fan09 Performance Modifications 1 02-17-2012 01:09 AM
Custom Intake Manifold + Direct Port Nitrous blacksandiegovitz Performance Modifications 9 04-21-2010 07:05 PM
Turbo Manifold thread Sabretooth Forced Induction Forum 78 05-22-2009 06:52 AM
