Old 07-16-2007, 12:52 PM   #73
eijikikimaru
Q(','Q)
eijikikimaru's Avatar
Drives: 3dr Meteroite
Originally Posted by 2006fronty View Post
here's mine:
Nice rims! however you fail to mention:
Rim brand
Rim size & width
Tire size
possible offset
eijikikimaru is offline   Reply With Quote
Old 07-22-2007, 11:15 AM   #74
red-jdm
red-jdm's Avatar
Drives: Yaris type E M/T
[QUOTE=ism3t;95957]i was gonna wait till tuesday when i throw the red lugz on, but i cant wait that long.
nice wheel you got there!!!!
red-jdm is offline   Reply With Quote
Old 07-22-2007, 11:22 AM   #75
red-jdm
red-jdm's Avatar
hi everyone, I am a new member, and here's mine :
Yokohama Advan RGII 15x7.0 +35 with Bridgestone Potenza S-02 195/55/15
Old 07-22-2007, 11:33 AM   #76
red-jdm
red-jdm's Avatar
[QUOTE=pabsan;107452]i have mine with 205/50/R16, with original springs and suspension. it rubs with road imperfection
Hi pab! the size of your tyres are just fine for yaris, however if you finds them rubbing then you should probably check on the width or the offset of your rims..
The guy at your shop was right, if you replace your standard coil springs with the sport ones, it will be less bouncy and hopefully less rubbing. Tanabe NF210 is great for your case, should try them!!
Old 07-22-2007, 03:18 PM   #77
manborn
are u still 34/39?
manborn's Avatar
Drives: flint mica yaris s sedan
17x7 Sport Edition E3 & 205/45HR17 Kumho Ecsta
installed just last friday 7/20...
17x7 Machined w/Anthracite Accent Sport Edition E3
205/45HR17 Kumho Ecsta AST
manborn is offline   Reply With Quote
Old 07-22-2007, 10:42 PM   #78
driver centric
I know right?
driver centric's Avatar
Drives: 07 Bayou LB
Those look great on your sedan manborn, good choice of wheels.
-Kev
07 Bayou Blue Liftback 5-spd manual
driver centric is offline   Reply With Quote
Old 07-22-2007, 10:55 PM   #79
Thirty-Nine
Small cars are a big deal
Thirty-Nine's Avatar
Looks awesome! Does it rub a lot?
Old 07-23-2007, 03:28 PM   #80
manborn
are u still 34/39?
manborn's Avatar
thanks man, i was trying to get a stock sports trd look similar to the camrys but i think mine came out better than any camry
Old 07-27-2007, 10:12 PM   #81
Zute
Zute's Avatar
Originally Posted by jookybanana View Post
Honda Civic SIR wheels 15x6 +45
with Yokohama A032R 205/50/15
Work Emotion CR Kai 18x7.5 +42 front, +36 rear
with Falken FK-452 215/35/18
Hot car! I can't wait to get my wheels and lower it!
Zute is offline   Reply With Quote
Old 07-30-2007, 11:05 PM   #82
nurburgring
ringmeister
nurburgring's Avatar
Drives: YARIS 1.5
Here's mine.
Buddyclub P1 Racing Replicas +42
Dunlop Sportmaxx 195/50R16
Tanabe NF210
Fully laden, no rubbing regardless of bump size or steering angle.
I wished the rear would be +35 offset. Its not flush like how I like it to be.
nurburgring is offline   Reply With Quote
Old 07-31-2007, 08:43 PM   #83
driver centric
I know right?
Drives: 07 Bayou LB
Agreed
-Kev
Old 08-01-2007, 12:25 AM   #84
ya_RS
ya_RS's Avatar
Drives: 07 RS
Originally Posted by nurburgring View Post
Here's mine.
Tanabe NF210
thats the hottest setup i've ever seen...
Honda to Toyota... lets see how this plays out
ya_RS is offline   Reply With Quote
Old 08-01-2007, 06:40 PM   #85
Yaris T-Sport
Nov 2006
Drives: Vitz S1600
Finally got the wheels, 17x 7, 40 mm offset OZ Racing Supert. WRC wheels w BFGoodrich g-sport, 215/40ZR17, with Tein S-tech 1.9 in dropped
Cold Air Induction|Blitz SUS POWER Air Cleaner System|2.4L 2AZ-FE Throttle Body|Blitz Compressor System|Full Light weight pulley kit|GReddy Ti-C exhaust System|Blitz Throttle Controller|T/B Coolant Bypass + Gasket Trimmed|Weight deduction|Exhaust Manifold|Center pipe|PCV Bypassed
Yaris T-Sport is offline   Reply With Quote
Old 08-01-2007, 07:35 PM   #86
kimona
kimona's Avatar
Drives: 2014 White VITZ
[QUOTE=Yaris T-Sport;119100]Finally got the wheels, 215 40R17, with Tein 1.9 in dropped
/QUOTE]
Looks first class fabulous!
Old 08-01-2007, 09:54 PM   #87
Thirty-Nine
looks awesome!
Old 08-01-2007, 11:43 PM   #88
seanele
seanele's Avatar
Drives: '07 Blazing Blue LB, '09 Jetta
dude...that is awesome looking Yaris!!..damn Longo..they should have given me the red one...
btw,
with that size of tire...is there any rubbing?
current: '07 Yaris LB - '09 VW Jetta
ex: '06 Beetle S(19x8.5 Audi A8) - MK4 GLi BMP(18x8 OZ, K04) - '03 GTi(17x7.5 Ronal, APR93) - '01 GLS - '88 GTi - '86 GTi - '83 GTi
seanele is offline   Reply With Quote
Old 08-01-2007, 11:53 PM   #89
seanele
seanele's Avatar
Here's mine.
is that just a Tip or a whole exhaust sticking out??
look very nice..., i might do the same way.
Old 08-02-2007, 12:36 AM   #90
seanele
seanele's Avatar
Blue one is an awesome color too there is no rubbing at all
I use this Tire Calculator on
http://www.discounttire.com/dtcs/infoTireMath.dos
the Overall Diameter of 215/40R17 is only + .03 compare to the OEM 185/60R15
, which is the closest overall diameter you can get to our OEM wheels in a 17in wheel (If your speedometer reads: 65, You're going approximately: 65.08)
205/45R17 would be + .52 bigger than the OEM 185/60R15 (If your speedometer reads: 65, You're going approximately: 66.42
the Tire Calculator is really helpful for you to pick the tire size thats as close to the OEM size as possible
PS. Blazing Blue and white wheels match up real good too
thanks..
i will seriously consider this white color rims + Blue Yaris..
Since my Yaris is not as fast as those frikin' Civics, i'll make sure it will beat them at least in looks.
good think i haven't place the order for the Konig Rewind...
