Old 05-15-2011, 05:09 PM   #1
macky
Drives: yaris
help pls
any one who knows where can i find main body ECU of yaris 2006 because ihave bypass module dball data base tranponder i need to connnect (stsw output to stsw+ pi4 of ECU main body , but idont no where? pls help any diagram regarding stsw wire yelow no 8 frm. dball http://www.xpresskit.com/VehicleComp...px?p=null&year to see chart of my problem,
macky is offline   Reply With Quote
Old 05-15-2011, 08:42 PM   #2
The main body ECU is actually the white box under the dash with the fuse panel mounted to the bottom of it.
Old 05-15-2011, 11:18 PM   #3
macky
Drives: yaris
thnks i check it up later
Old 07-06-2011, 06:42 AM   #4
The red one that's hidden on the end of the second row is definitely ignition switched +12 volts. Make sure you have a good ground that you are referencing it to, or use the white wire with the black stripe on that connector as your ground.
Old 07-16-2012, 07:29 PM   #5
Rudra223
Rudra223's Avatar
Drives: 2006 Belta
Question where is the reverse light wire?
and what is the colour?
Rudra223 is offline   Reply With Quote
Old 09-26-2012, 08:42 PM   #6
Rammy
Where is this whole piece as seen in post 14?
I want to wire some door sills and have them light up when the door opens up. I usually keep the light in the off position and not on the "door" position. So if I want it to work the way I want it to, am I going to have to keep the switch on "door"? This might be the wrong thread but I was redirected by Scott on another thread. Thanks!
Rammy is offline   Reply With Quote
Old 09-26-2012, 08:47 PM   #7
Behind the little storage cup on the bottom left side of the dash.
Old 09-26-2012, 08:53 PM   #8
Rammy
Oh ok! Thanks.
And where can I tap into the parking lights? The lights that turn on when you twist the switch half way. I am also installing some LEDs for the interior and I want them to turn on w/ the parking lights. And do any of you recommend the "L bars" or just regular LED clusters? I want them to go under the whole dash kind of where your feet go.
Old 09-26-2012, 08:57 PM   #9
Oh ok! Thanks.
See my remote start wiring DIY for the parking light connection:
http://www.yarisworld.com/forums/showthread.php?t=24860
Old 10-19-2012, 12:38 PM   #10
I thought your post might have been spam with odd combination you were asking about, but since you sent me a PM with some specific questions, it seems like you are not a spammer.
In your PM you mentioned that you found all except these two:
1.Oil circuit detection
2.Cut oil and electric circuit off.
For #1, the Yaris has an oil pressure switch that is located on the front of the block about 6 inches above the oil filter. It has a single yellow wire (since its case is grounded to the block). That yellow wire is only an input to the instrument cluster for the warning light.
For #2, I am not sure what you are looking for. The only circuit associated with oil is that simple oil pressure switch.
Old 10-19-2012, 01:19 PM   #11
OK - That makes more sense for it to be the fuel cut-off. Sometimes the directions seriously lose something in translation.
In that case, you are interested in the violet wire on Pin 7 of the smaller ECM connector.
Old 10-19-2012, 02:51 PM   #12
I would need to see a better explanation of the module. In theory there should be two wires - in and out, so the device can interrupt the fuel pump feed.
Old 03-05-2013, 02:07 AM   #13
fase4
Drives: Yaris TS 05
regarding to colors, I cannot rely
lol
Mines is a european base model so maybe for that the colors difference
Ok I get it about the pin 9. So I tap here the - right? what about the + connection? Also the relay for what would serve?
sorry for the question but I know almost nothing about this
fase4 is offline   Reply With Quote
Old 12-12-2013, 02:52 AM   #14
yelcur
yelcur
Drives: toyota yaris sedan
please send full detail on toyota yaris sedan year 2008. .front totally damaged in accident .if someone selling parts let me know..! wiring system completely damaged.
yelcur is offline   Reply With Quote
Old 02-28-2014, 10:30 PM   #15
bonnorano
Drives: jdm wannabe yaris
Hello everybody i missing a dimmer switch on my indonesian/thailand yaris 2012 5doors, i want to add tachometer on my yaris. Please help me :(
bonnorano is offline   Reply With Quote
Old 02-28-2014, 10:34 PM   #16
The Asian market Yaris do not have the dimmer rheostat. You can either just use ignition switched power for the tachometer illumination wire of you can use the illumination wire on the radio.
Old 10-25-2014, 11:34 PM   #17
THEBRADLEY
Drives: 06 hatch
hey man i was wondering if you could tell me how to go about installing footwell led lights to be activated with a switch prefferably in the center console by the e-brake. i know you have to bypass the firewall somehow for power, but i have no idea how/where to do so. help would be greatly appreciated.
THEBRADLEY is offline   Reply With Quote
Old 03-11-2014, 08:43 AM   #18
Mittelklasse
Problem, officer?
Mittelklasse's Avatar
Drives: '06 Yaris 5DLB 1.5
My Thailand-spec Yaris uses electronic dimmer circuit built within the instrument cluster.
You have to toggle the trip button while having your lights on to access this function.
Mittelklasse is offline   Reply With Quote
2012 Yaris at SEMA Jason@SportsCar Third Gen Yaris General Discussion 5 09-23-2013 03:55 AM
New Yaris race car Jason@SportsCar Tracking, Racing, Auto-X Forum 83 11-01-2012 02:32 PM
