Old 12-01-2012, 11:39 PM   #73
jcboy
Drives: Sedan 07
So no need to create a relay wiring? I mean, how do u figure out if the horn youre purchasing doesnt exceed the 10A fuse limit? Its not advisable to "upgrade" a fuse to a higher rating either--that can be costly if ever.
If i purchase any horn (except airhorns or ones with compressors), can i just bolt it right up without blowingup that 10A fuse every now and then?
Thanks!
Old 12-03-2012, 01:04 AM   #74
yarisugi
やりすぎだ~
yarisugi's Avatar
Drives: Me: Nuts:
^yes.
Old 12-03-2012, 08:40 PM   #75
Yaristeve
Drives: 3-door hatch
I dunno about the others but the Toyota Premium Horn is rated 10A, even with the dual horns.
After all this time, still working great and no problems whatsoever. I love using it whenever I need it and as much as I can.
Old 12-05-2012, 09:03 PM   #76
screenprintr
screenprintr's Avatar
Drives: 2010 Toyota Yaris
PIAA sells a dual horn via Advanced Auto or Auto Zone. Can't remember which. They also offer a relay for a couple of bucks. You can watch a video on YouTube which shows it's pretty easy to install.
screenprintr is offline   Reply With Quote
Old 12-06-2012, 09:25 AM   #77
jcboy
Drives: Sedan 07
Thanks for the replies. I ended up with bosch ec9s. 10A rating for both so i just bought 1 male connector (for the oem plug so no splicing or cutting) then 4 female for the horn terminals, 2 butt connectors for the ground and some shrinktubes. Looks exactly the same as those oem premium horns. :) best guess sounds like 'em too. :)
Old 02-23-2013, 02:02 PM   #78
markross
Drives: 2007 Toyota Yaris HB
I just wanted to say Thank You! I just used that tutorial to change my headlight bulb on my 2007 Yaris Hatch Back.
As I write this it is rainy and in the 30's and I do not have a garage. Glad I did not have to remove my whole Bumbper Cover and lay on cold wet pavement.
markross is offline   Reply With Quote
Looking for the Toyota Fog Light install RocknRollRon DIY / Maintenance / Service 33 06-13-2010 06:46 PM
Toyota Premium Horn Meteorite_Marty Cosmetic Modifications (Exterior/Interior) 22 02-18-2009 11:28 PM
buying from TRDSparks, can my local Toyota install it? Yawesh General Yaris / Vitz Discussion 7 12-17-2008 08:27 PM
Toyota Delays Buckethead General Yaris / Vitz Discussion 3 08-26-2006 03:16 AM
