Old 08-18-2014, 04:02 PM   #73
evil03
Drives: yaris/pc3
This the part number i got form the part 86190-52010 will check the car after work
evil03 is offline   Reply With Quote
Old 08-18-2014, 04:56 PM   #74
Ah, that part number is definitely the Scion one, but as long as the pinout is the same and the switched pin has a ~2.2K resistor, it would work.
Can you snap a pic of which head unit you have as well?
Old 08-19-2014, 11:21 PM   #75
evil03
Drives: yaris/pc3
ctscott
here they are
Old 08-19-2014, 11:25 PM   #76
ctscott imma trying upload the pics but it wont let me
Actually that's OK. I was able to verify by the model number that it is an AUX capable head unit. Did you verify the resistance as ohms or kohms?
Old 08-20-2014, 12:12 AM   #77
evil03
Drives: yaris/pc3
ctscott
2.666 k ohms is what i am reading off the aux port pin 4 and 3
with a mini jack plugged in with out the actual port plug in to the wiring harness
Old 08-20-2014, 06:42 AM   #78
ctscott
Grab a 2.2k resistor from Radio Shack and try a quick test:
With the 4 pin connector to the jack the wire order should be green, red, grey, red.
Take the 2.2K resistor and stick it into the red (opposite the green) and the grey and then press the aux button on the radio and see if it goes into aux mode.
Old 08-20-2014, 10:01 PM   #79
evil03
Drives: yaris/pc3
Ctscott
No luck..... 2.2k in pin 4 red and 3 Greg
Old 08-20-2014, 10:12 PM   #80
Ctscott
If the jack and cable came off a Scion, then the radio end may be pinned incorrectly.
The image below shows the radio connector of a Yaris, looking into the holes.
ALI: Aux Left
ARI: Aux Right
ASGN: Ground
AUXI: Switch input to enable aux mode.
Make sure that the red and black (or grey) above go to AUXI for the Red and ASGN for the black or grey wire.
Old 08-20-2014, 11:03 PM   #81
evil03
Drives: yaris/pc3
Ctscott
Everything is correct on my end according to your schematic but no dice
Old 08-21-2014, 12:22 AM   #82
evil03
Drives: yaris/pc3
Ctscott
I got it
Radio 11807
Is a 8 pin set up
In just added a 2.2k resistor to pin 19 and 18
But 18 pin is empty so I found random pin that fit the socket and made the connection with the radio
Everything works now
Thanks a bunch
DIY: Aux Input Jack Adapter TinyGiant DIY / Maintenance / Service 11 11-10-2012 05:33 AM
Viper Alarm Install gwasabi In Car Entertainment + Electronics (audio / video / alarm) 28 08-11-2010 02:57 PM
Hear noise when playing music with TomTom 910 through auxiliary audio input jack waylandchin In Car Entertainment + Electronics (audio / video / alarm) 11 04-22-2007 12:25 AM
High pitched whine using stock head unit / aux input? IsLNdbOi In Car Entertainment + Electronics (audio / video / alarm) 8 02-02-2007 12:49 PM
aux input... djfuji In Car Entertainment + Electronics (audio / video / alarm) 3 01-23-2007 09:25 PM
