#1 |
Returning to Toyota
Drives: 2013 L 3dr MT Join Date: Mar 2013
I responded, though I don't see it in my private messages (sent). If you don't get my message (Frank N), then post here.
![]() ![]() ![]() Drives: 2018 Yaris SE 5MT Join Date: Aug 2017
Since this thread is already resurrected, I thought I'd add to it..
![]() I was looking for the Toyota OEM block heater, but read that Toyota Canada recently issued a recall for the factory unit due to manufacturing faults that could lead to a short circuit. https://www.toyota.ca/toyota/en/abou...-block-heaters If you can't find the OEM model, the recall may have affected your region as well. I found 2 options for aftermarket, cartridge style block heaters that are listed to fit our cars: - Kat's Heaters, p/n: 11813 - Zerostart (Phillips-Temro), p/n: 3100129 When I went to the local Ideal Supply (NAPA in Canada) they said they don't carry the Kat's, that it's only in the U.S. stores. The Zerostart, made by Phillips-Temro, is the one stocked in the Canadian stores. Installation follows the information given in this thread. There's also a good YouTube video install on a Tacoma and Corolla if you search. Hope that helps someone stay warm this winter. -- Adam |
#3 |
![]() ![]() ![]() Drives: White '07 3dr LB Join Date: Jun 2016
I just installed mine on my '07 HB auto. The pictures Naossoan posted really helped. I simply fisted my right arm down there and moved stuff around till I felt a hole underneath the metal hose. Then the fight was to get the Phillips-Temro heater I bought off Amazon.ca (~$53 CAD) in just the right Tetris location so it could slide straight in without snag on the hose and cables. Had to push harder from different positions to get the heater clip to snap in, but all in all it took me about 15 minutes under light cold rain.
Then to run the cord to the front grill. Fugget about it. I park in my yard and when it snows the front grill is 6 feet under. Good luck rampaging the extension cord with the shovel at 4am in the morning. I bought the Noco GCP1 AC port and plan on installing it by the black plastic flashing near the passenger side view mirror if there's enough depth (need 1.5"). That would keep the cord in clear sight and out of the snow so I can easily operate. |
#4 |
#5 |
![]() Drives: Echo Join Date: Jul 2021
Here is the original block heater for $65 Cad, I have purchased one from my local dealer, seems good quality, has lube included and several zip ties. Now need to install it.
PK5A4-08J04 BLOCK HEATER https://parts.sptoyota.com/products/...4-block-heater ![]() free images hosting |
#6 | |
![]() Drives: 2008 Yaris 3dr Join Date: Aug 2020
Dielectric grease? Thermal paste? |
#7 | |
![]() Drives: 2007 Toyota Yaris 5-Door HB Join Date: Oct 2011
This is for a 2007 Yaris with auto trans?
It looks like the right one as for some reason 2007 has a 90 dergree plug end on the heater end, eh?! I had an issue with my electrical plug in end and decided to just cut the old one off and solder a three prong plug I had from an old programable timer. It was a pain to add but I didn't feel like taking the whole cord out. If my fix last until Spring then I will get this new one. Thanks for the post and I hope this thread is back to life now!! Quote:
#8 |
Just an update. I got the block heater this morning via Purolator!! The price total was $84. Heater $65, Shipping $15 & Taxes $4. I am pleased as this is a genuine Toyota replacement part unlike all those other heaters you see on Amazon and PartsAvatar, etc. With shipping it costs about the same anyway!
Toyota even revises these things! Mine is REV 03 date of 7/22 on it! Yay! |
#9 |
Drives: 2008 Vitz 2SZ-FE Join Date: Dec 2024
Does anyone know of a block heater that would be compatible with a 2008 Toyota Vitz with a 2SZ-FE engine?
| engine block heater | linny | DIY / Maintenance / Service | 6 | 01-19-2012 11:22 AM |
| My $7 Interior Upgrade - Center Heater Vents | Meteorite_Marty | Cosmetic Modifications (Exterior/Interior) | 54 | 05-18-2009 08:51 AM |
| Rostra seat heater and lumbar support | sesmith | In Car Entertainment + Electronics (audio / video / alarm) | 1 | 01-03-2009 08:51 AM |
| Where to find block heater cable that was factory installed? | D6U4 | General Yaris / Vitz Discussion | 5 | 12-16-2008 07:04 AM |
| Performance mods that won't affect/will hardly affect gas mileage?? | Mr.Yaris | Performance Modifications | 15 | 07-30-2007 12:32 AM |
