Old 11-05-2009, 07:48 PM   #73
advocate
Drives: car
So I know the sizes of the gauges that are going to be used in the pod but I can't seem to find a good way to search for specific gauges in specific sizes.
Are there any good, well-established sites that sell gauges that anyone can recommend?
advocate is offline
Old 11-05-2009, 08:18 PM   #74
frownonfun
frownonfun's Avatar
http://www.autometer.com/cat_gaugesearch.aspx
I crush you like tiny clown car, because you are clown, yes?
frownonfun is offline
Old 11-05-2009, 09:32 PM   #75
H3LlIoN
Drives: '09 Yarrrr hatch
jeg's/summit
H3LlIoN is offline
Old 11-05-2009, 09:47 PM   #76
tk-421
tk-421's Avatar
Drives: 5D-07-LB
Sorry for what is a lame question , how does your unit fix to the dash .
Trying to work out if it will suit right hand drive cars as well.
cheers
This piece gets mounted on top of the glovebox door. It will not fit RHD cars, but the piece I sold them originally will.
tk-421 is offline
Old 11-05-2009, 09:51 PM   #77
cruz-gsr
cruz-gsr's Avatar
Drives: 08 Yaris Lift Back
our unit will not fit a RHD. and i used the one i got from tk to make my original.
cruz-gsr is offline
Old 11-05-2009, 10:29 PM   #78
SilverBack
Joey
SilverBack's Avatar
Drives: '14 Scion xD 5-speed
So will it be glued-on, or will there be screws like the JDM?
SilverBack is offline
Old 11-05-2009, 11:19 PM   #79
anubisx99
here again..
anubisx99's Avatar
Drives: 2008 toyota yaris LB
ok, so for the mounting we have two options, 1- the unit could be mounted just like the original RHD with 4 long self tappers, in which case will be shipped with a template that you lay down on the glove compartment before pre-drilling, or 2- 1" "L" shape brackets mounted to the inside of the pod line it up and then drill the self tappers, whatever the case may be we'll choose the easiest and quickest way and post pics and instructions...
Don't be threating me with a good time!!!
anubisx99 is offline
Old 11-06-2009, 12:02 AM   #80
tk-421
tk-421's Avatar
Drives: 5D-07-LB
Couldn't you use 3M double sided tape in order to avoid having to drill up your OEM parts? I'm pretty sure the tape would hold and it is very thin (~1mm). http://bit.ly/3Hc8w3
It would just be a matter of adding an extra surface on the back in order to hold more tape...
tk-421 is offline
Old 11-06-2009, 12:45 AM   #81
1NZYaris1
1NZYaris1's Avatar
That's what i thought , no worries ,i was just curious as to how it was
also to fix to the dash .
1NZYaris1 is offline
Old 11-06-2009, 01:03 AM   #82
H3LlIoN
cheers
Just do a LHD Conversion.
H3LlIoN is offline
Old 11-06-2009, 01:07 AM   #83
1NZYaris1
1NZYaris1's Avatar
Smart arse ,it would cheaper to fly over there to live .
Old 11-06-2009, 01:13 AM   #84
H3LlIoN
Cheaper monetarily....but it'd end up costing you your soul, just like the rest of us.
H3LlIoN is offline
Old 11-06-2009, 07:07 AM   #85
anubisx99
here again..
anubisx99's Avatar
gents, you CAN use double sided tape to hold it in place however, the only problem I see (trust me I deal with this issue all day, I'm a sign maker lol) is that after you put the tach and the gauges on it adds a lot of weight to the pod and it might fall off (even with the 3M stuff which is pretty strong) beside the weight issue there's also the problem that even if you find a double sided tape that's 1/4" wide you'll still going to have some showing from the edge of the pod, however installing it is really up to you guys how you preferred, besides you'll need to drill some holes for the wires to pass thru...(if you don want them showing of course)
Old 11-07-2009, 12:51 AM   #86
cruz-gsr
cruz-gsr's Avatar
ok guys, correction, for the tach, the opening is actually 3 3/8" not 3.5, that's for the sunpro tach setting, the autometer tho is 3.5 if you have a mini monster (shift light included) otherwise is also 3 3/8, for the small the opening is 2 2/16", double check before you get a tach or otherwise you'll have to "Dremmel" the hole a little bigger
cruz-gsr is offline
Old 11-07-2009, 12:59 AM   #87
Gideon
★weeaboo★
Gideon's Avatar
Drives: 2008 Bayou LB
Put me down for one, great job guys, thanks for making such a elusive part easier to find and mount to our cars.
Gideon is offline
Old 11-07-2009, 01:04 AM   #88
was my last post deleted?
cali yaris is offline
Old 11-07-2009, 01:07 AM   #89
1NZYaris1
1NZYaris1's Avatar
Old 11-07-2009, 04:00 AM   #90
anubisx99
here again..
anubisx99's Avatar
put it again Garm
Triple C Design Presents........Gauge Pod collection cruz-gsr Items for Sale by private party 50 09-21-2009 11:21 PM
TRD Gauge Pod cruz-gsr Willing to Buy by private party 11 07-13-2009 01:42 PM
Does anyone have the glowshift a-pillar gauge pod? Sodium Duck Cosmetic Modifications (Exterior/Interior) 31 03-16-2009 12:49 PM
TRD Options S1L3N7 D3A7H New YARIS Purchase Forum 26 01-20-2009 01:52 PM
TRD Parts MC-BPT Sponsors Classifieds Area 9 06-23-2007 10:51 AM
