Old 03-02-2009, 09:18 AM   #1
Sodium Duck
╚══════════RN
Sodium Duck's Avatar
Drives: 2008 Liftback
Does anyone have the glowshift a-pillar gauge pod?
http://www.glowshiftdirect.com/06-07...illar-pod.aspx
Glowshift’s 06 - 07 Toyota Yaris Liftback Triple Pillar Pod is a triple gauge pod specifically designed for your Yaris and will mount three 52mm or 2 1/16th inch gauges while bringing a unique style and look to your vehicle’s interior. Each A-pillar pod is crafted from the highest quality ABS plastic available to withstand cracking, fading, and warping while still giving your Yaris a custom fit and finish. This pod is currently offered in a clean OEM black style while still offering the user the ability to paint the pod if needed. All necessary mounting hardware and instructions are included with each order.
* Full Size Black Triple Pillar Pod
* Holds three 52mm or 2 1/16th inch gauges
* Crafted from the Highest Quality ABS plastic Available
* Includes Mounting Hardware & Instructions
* 1 Year Warranty & Free Installation Support
Right, so... it's an OEM BLACK? a-pillar... Okay, don't got that. It only fits 06-07's... Okay, don't got that...
As long as the fit and finish is ok, anybody know?
Is this it? More pics if it is?
http://www.yarisworld.com/forums/sho...9&postcount=13
Old 03-02-2009, 09:35 AM   #2
LtNoogie
LtNoogie's Avatar
Drives: '08 Bayou Blue LB AT
Yikes. I just bought one. This weekend, I spraypainted it with Valspar primer which is almost the same color as the regular interior plastic pieces. Next, I'll spray it with some eggshell clearcoat to protect the primer.
Mike, are you saying that the old a-pillar molding stays on the car and this just mounts on top of it? It kinda makes sense now considering that it had no tabs to connect to the rest of the car.
Old 03-02-2009, 09:57 AM   #3
Sodium Duck
╚══════════RN
Huhmmm... Well, please post pics when you finish it up Noogie. So you are using it at the a-pillar totally? You didn't attach it to the original, if I understand you correctly?
Old 03-02-2009, 09:58 AM   #4
Sodium Duck
╚══════════RN
freakin ninja posts!
Old 03-03-2009, 11:30 PM   #5
LtNoogie
LtNoogie's Avatar
I painted the Glowshift gaugepod this weekend. Next is a satin clearcoat and then it goes into the car. I am disappointed that it mounts over the exisitng gaugepod and does not replace it. They give you three screws to fasten it to the existing pillar. Lame
Old 03-03-2009, 11:48 PM   #6
yarisugi
やりすぎだ~
yarisugi's Avatar
Drives: Me: Nuts:
looks really nice. It looks like you could almost replace the factory one... maybe?
Old 03-03-2009, 11:53 PM   #7
LtNoogie
LtNoogie's Avatar
I don't know what holds the existing a-pillar cover on. This thing has no clips. I'll try to see how hard it is to remove the a-pillar cover this weekend.
Old 03-04-2009, 12:06 AM   #8
I'd just 3M that bad boy in and call it a day so you don't have to use the screws
Old 03-04-2009, 12:13 AM   #9
LtNoogie
LtNoogie's Avatar
Yeah, that's a thought. I just need to choose the third gauge and stick the entire assembly on one time.
Old 03-04-2009, 12:14 AM   #10
do they make a Bad Ass Boosted gauge yet?
Old 03-04-2009, 12:15 AM   #11
LtNoogie
LtNoogie's Avatar
No just the "I Gotta Have Mo Power Blues" gauge.
Old 03-04-2009, 12:18 AM   #12
PHXDEMON
PHXDEMON's Avatar
Drives: 2007 Red Liftback
+1 I would 3m it. Camelll Does the pod bother you and create blind spots when you drive around? The A pillar stock in my liftback without any gauges gets to me sometimes
Old 03-04-2009, 12:26 AM   #13
1NZYaris1
1NZYaris1's Avatar
Wow do they make one for Right hand drive cars
Old 03-04-2009, 09:28 AM   #14
Sodium Duck
╚══════════RN
FWIW, I think I'll be going with something like this. I'll have an Ecogauge, tachometer, and volt meter possibly.
http://cgi.ebay.com/ebaymotors/52mm-...Q5fAccessories
Old 03-04-2009, 09:29 AM   #15
Sodium Duck
╚══════════RN
Originally Posted by camelll View Post
Another thing that bothers me a little bit even though it is no big deal is that the texture of that pod does not match the stock pillar. When I had mine done I had them sand the passenger side pillar and paint that as well so it matched the drivers side.
Ditto, that's why I'm going for the above, and the blind spot issue.
Old 03-04-2009, 12:34 PM   #16
Doc Zaius
Lurker supreme!
Doc Zaius's Avatar
Drives: old and boosted!
Thomas (eTiMaGo) has his on the dash as well. Check his garage for pix.
I'm still debating...
2006 Red Blitzed RS 5-door
Old 03-04-2009, 12:57 PM   #17
33OH
Drives: '08 Yaris
I mounted my original tach to my dash, it lights up and glares off the windshield at night. Super annoying.
I bought the glowshift A-pillar, and now I'm waiting for it to get warmer so I can paint it/install it..
Old 03-04-2009, 03:32 PM   #18
LtNoogie
LtNoogie's Avatar
Ryan, the color you see is Vaspar primer. It's a really good match for the OEM color and sticks well to the plastic.
A-pillar gauge pod Tonavi Cosmetic Modifications (Exterior/Interior) 26 02-26-2009 07:35 AM
ebay a pillar gauge pods KSIbucky Cosmetic Modifications (Exterior/Interior) 2 07-16-2007 11:47 AM
a-pillar gauge pod 07typeS Cosmetic Modifications (Exterior/Interior) 36 06-17-2007 08:53 AM
Gauge Pod for Liftback? eight_heads General Yaris / Vitz Discussion 2 06-07-2007 10:41 AM
