Old 02-03-2019, 12:34 AM   #1
Type-Y
Drives: 2007 Yaris hatch
This is a cool idea. I for one have always loved bugs, in all their various iterations, including the baja bug. I've often thought of the Yaris as the modern day VW bug due to it's simplicity, reliability, dependability and utility. Good luck and post your progress.
Type-Y is offline   Reply With Quote
Old 02-04-2019, 09:40 AM   #2
Maritime
Drives: 2008 yaris 5dr hatch
Me too, I bought the car out of affordability and necessity but really found I love the little thing. I've always loved the Baja bugs and Manx buggies but they cost so much now that I want to do my Yaris up as an Baja inspired byt the VW's.
Maritime is offline   Reply With Quote
Old 02-03-2019, 04:26 PM   #3
Maritime
Ok guys. Still working on this but wife decided this weekend was master bathe reno start so I beat out tearing out tiles, tubs and shit. Spacers came in and I think with 1.5" I shouldnt need to worry about axle or shocks. Ill get little bits done here and there over the next few days and report back.
Sent from my moto e5 play using Tapatalk
Old 02-05-2019, 07:35 AM   #4
Maritime
My camber bolts arrived in Maine along with some bumper brackets, my front bumper has been flapping around since I changed out a headlight and found the PO had hot glued the bumper on LOL. I'll grab those this week sometime and the last of what I need to install the lift will be in hand. I'm copying the off the shelf lift from Russia that says no axle relocation required, I hope they are correct but I'll let every one know once I get it installed.
Old 02-05-2019, 01:36 PM   #5
Maritime
also looking at parts fiches for the rear you could make a bracket to lower the hubs on the axle instead that would give clearance and lift without touching the springs and shocks at all.
Old 02-05-2019, 01:48 PM   #6
myfirstyota
3 Yaris and counting..
That's what I had done for my spacer build. Took my sketches to a metal place that does custom cutting. They used a waterjet to cut my pieces. Now if I could only weld lime a pro, they'd look perfect when I'm done lol
No one suspects the Yaris.
Xd/2zr-fe Swap/Build Thread
Old 02-05-2019, 01:49 PM   #7
Maritime
Cool.
Old 02-05-2019, 01:53 PM   #8
Maritime
ok so get an axle from a wrecked car, then do this:
cut off both:
flip from one side other, reweld on bottom:
Or make a bolt on plate:
Old 02-05-2019, 01:54 PM   #9
Maritime
but then what to do to match on front is the harder one.
Old 02-05-2019, 02:10 PM   #10
scion xb gen1 springs: LIFT IT. LIFT IT GOOD!
Old 04-16-2019, 10:24 PM   #11
YarMatey
Drives: 2008 Toyota Yaris 5dr Liftback
With just the xD springs how much lift would you estimate it gave you? Any issues with the shocks being topped out that you noticed?
Also, Myfirstyota you said the whole strut assembly from an xD will bolt right into a Yaris with no modification? What about the rear shocks do you know?
Hot Rhonda
- Bayou Blue
- Cosmo Racing Short Shifter
- Kenwood Single DIN Aftermarket Headunit
- Rockford Fosgate Punch 6.5” Speakers
“the dents make her handle better.”
YarMatey is offline   Reply With Quote
Old 04-23-2019, 04:31 PM   #12
myfirstyota
I'd say an inch to an inch and a half. And yes, you must be careful when going over speed bumps etc. When the suspension dropps out. Because there is much less weight, the struts top out quick. Daily driving is no problem. But if you take a speed hump quickly, the struts will top out.
And yes, theyre a direct bolt-in. You could order an aftermarket assembled strut and you're done.
Old 02-05-2019, 02:19 PM   #13
Maritime
Ha, ok. I really want to put the lift I have made in tonight because its +7C today here. I wonder if the wife will let me out of bathroom duty to do it?
Old 02-05-2019, 04:51 PM   #14
myfirstyota
Maritime, I don't think that rear cut and weld axle idea will work. Not sure how your axle is built but mine doesn't look like that at all. The bearing mount on the ends of the axle are welded around the circumference of the mount. The axle is like an oval pipe on the ends. On my car, the bearing mount is fully welded around the outside to the pipe that makes up the axle. It's not like pictured in post 84.
Side note:
See where this is going?
Maritime, I'll stop polluting your thread now lol
Old 02-05-2019, 05:36 PM   #15
Maritime
I see ;D
Old 02-06-2019, 05:17 PM   #16
Maritime
Pulled the thule out of storage. Going to need a trim width wise and need to sort bolts but it will.work great and at 0$ budget friendly.
Old 02-06-2019, 06:53 PM   #17
hotracer_05
Hmm, I see...
hotracer_05's Avatar
Drives: 2012 Toyota Tundra and Yaris
subd, thought about lifting mine as well...but ive gotten used to cornering pretty hard in it lol.
"Everything happens for a reason. Sometimes that reason is you're and idiot"
hotracer_05 is offline   Reply With Quote
Old 02-06-2019, 07:33 PM   #18
myfirstyota
Use xd springs. Still corners ok with the trd rear sway bar and 70 series tires
Vacationed in Italy - Brought home a D4D diesel Yaris CTScott Photo-Video-Media Gallery 19 07-26-2012 03:13 AM
