View Poll Results: Oil you use /recomend ?
MObil One 47 83.93%
Castro Sync 9 16.07%
Voters: 56. You may not vote on this poll
Old 10-26-2008, 07:45 AM   #73
bobby
bobby's Avatar
Drives: 2007 Yaris/2009 Phit Sport
I think generally we think too much about the oil in the car. How would anybody REALLY know which oil is better than another? Are you analyzing the engine parts at a lab?? Seems silly to me.
I truly believe that if you use a name-brand oil with the recommended weight (5-20, 5-30, or whatever) and change your oil & filter frequently (every 3,000 miles or 5,000) your engine will last and last and last. The trick to longevity is keeping the engine oil clean, by frequently flushing it out with new, clean, oil. Beyond that, I have no idea how one would determine which oil works better.
bobby is offline   Reply With Quote
Old 10-26-2008, 10:24 AM   #74
TheSilkySmooth
TheSilkySmooth's Avatar
You just want quiet, smooth engine reasonable economy, service life and not varnish. The Varnish will break loose at the oil changeout period and can get into small places and cause problems. Sales staff say our car has Life time "chain tensioner" and hydraulic cam phasing so this parts do not suffer varnish floating around without problem. My Family had Mazda v6 which tensioner alway is failing due to dirty oil and so to my brothers motorcycle. He had to switch to superior AECA formulation from inferior ILSAC SM specification N.A. gunk. Sorry I digress ...So, the wider the Viscosity Index the less optimal the oil will be for long life and varnish creation (cause by oxidisation of polymeric additives). So even in Ethylene gas synthesized - 0W30 worse than 10W30 and 0W20 (cause of tighter VI) better than 0w30 if engine expressly designed for the base oil weight. Yaris 1dot5 litre is not designed for 0W base oil and will have shortened service interval in this suboptimal application. Sorry Gentlemen - I try to act like dumb skirt so people will not hate me and like me but i have to throw down the gauntlet now seeing so much misinformation on this forum. Sorry to say API oil "sucks" All of it.
Last edited by TheSilkySmooth; 10-26-2008 at 10:27 AM. Reason: dark typing lessons needed
Old 10-26-2008, 11:38 AM   #75
gid
Drives: '08 Yaris sedan , '08 Liftback
we're using synthetic because it tames the engine noise and do many short trips. Someday may switch to a syn-blend and then to conventional oil again .
gid is offline   Reply With Quote
Old 10-26-2008, 02:54 PM   #76
battleversiontc
battleversiontc's Avatar
Drives: 08 vip yaris
i run greddy gr3 5w 30 with some lucas oil additive and she runs smooth
08 junction produce belta almost done and ready for paint
06 junction produce tc 604 bhp 445tq ddriven still trying for 700+hp
90 crx sir ls vtec turbo 755 hp
mecp masters certified
battleversiontc is offline   Reply With Quote
Old 10-28-2008, 12:57 PM   #77
TheSilkySmooth
My dad says:
Try CD oil detergent with extreme pressure-wear additives available at the local auto-parts store is very good to get API oil perform almost like AECA A3 B3? Except Viscosity will be less for economy. Will make almost to Porsche spec
-S
Old 10-28-2008, 02:32 PM   #78
gid
if using an 5w-20 , I read it's best to use one that's rated ACEA A_ and B1 or greater . The PENNZOIL Platinum 5w-20 we're using is only rated A1-02 , while the PLATINUM 5w-30 is also B1 and B5 . I believe MOBIL 1 5w-20 has a B rating , as for other manufacturers . Would have to do some searching on the web or in the store . May go to another 5w-20 synthetic that has the B rating . The ratings are printed on the label on back of the oil bottle .
Old 10-29-2008, 09:32 AM   #79
1stToyota
1stToyota's Avatar
Have you researched Amsoil yet? I'm considering switching to Amsoil with my next oil change. I can get Amsoil's HP 5w30 for nearly the exact same price that I'm now paying for Eneos.
1997 Lincoln Town Car - SOLD
2008 Scion xD
(w/ automatic) - SOLD
2008 Yaris HB - SOLD
Old 10-29-2008, 12:36 PM   #80
gid
I would use AMSOIL or REDLINE if they were cheaper . PENNZOIL Platinum gets very good U.O.A.s ( used oil analysis ) at www.bobistheoilguy.com ( look under Used Oil Analysis - Gas ) , plus it's fairly cheap . I've picked up the PLATINUM for less than $3 a quart in the past .
Old 10-29-2008, 12:42 PM   #81
TheSilkySmooth
I would use AMSOIL or REDLINE if they were cheaper . PENNZOIL Platinum gets very good U.O.A.s ( used oil analysis ) at www.bobistheoilguy.com , plus it's fairly cheap . I've picked up the PLATINUM for less than $3 a quart in the past .
HI Mr. GID: Do you get the high mileage with your platinum oil too? Is the Power good? How do you drive hard or easy? This may be a good deal
Old 10-29-2008, 12:48 PM   #82
Benggolf2
Benggolf2's Avatar
When it will be time for my first oil change, I'll be using Mobil 1 5W-20.
Been using Mobil 1 for many, many years and never had any engine problems; besides our C55AMG and C350 uses Mobil 1 too.
Old 10-29-2008, 01:13 PM   #83
gid
with the PLATINUM 5w-30 the power is good , been averaging close to 39 miles per gallon since last NOVEMBER , and it tames the engine noise . Using REDLINE MT-90 true synthetic gear oil as well for the '08 5 speed liftback . This car was used for delivery route once a week for about 8 months as well , so quite extreme driving . One time the car got 42 m.p.g. while doing the route , other times 40 or little less ( some of that included 4 studded tires ). The route was 100+ miles , 4 hours long , around 400 stops , many steep hills , and 2 people . There's usually 2 of us in the car since the purchase . The '08 automatic sedan has the PLATINUM 5w-20 and got 40.03 miles per gallon on a test drive after 4 studded tires were put on ( see post under FUEL ECONOMY FORUM ) . That car has overall average of 39 miles per gallon as well , right on par with the stick shift . We'll have to wait and see how the colder weather affects it .
Old 10-29-2008, 02:31 PM   #84
1stToyota
1stToyota's Avatar
Amsoil's XL5w20 has the A1/B1 rating, and a friend offered to get me some for a discounted price of $5.65 per qt, but I'm thinking of staying with 5w30 and bumping up to their mid-priced HP series for $6.95 each (it has a A5/B5-04 rating) ...the HP5w20 ratings should be pretty close to those same ratings, I assume. And agreed on the Pennzoil Platinum UOA's...the oil expert (SgtGeek) that I made mention of earlier stated that their results were some of the best he sees.
2008 Scion xD
Old 10-29-2008, 02:36 PM   #85
gid
I'd go with the XL 5w-20 at that price . The U.O.A.s for XL are very impressive at B.I.T.O.G.. Decisions , decisions .
Old 10-29-2008, 04:57 PM   #86
1stToyota
1stToyota's Avatar
I'm getting a special price, not sure what the real list price would be. Probably $7.50 for XL and $9.00 for the HP...
2008 Scion xD
Old 10-30-2008, 11:16 PM   #87
gid
just went from PENNZOIL Platinum 5w-30 > Platinum 5w-20 for the '08 Liftback at 13,400 miles . Took little less than 3 and a 1/2 quarts to bring to FULL mark . The new TOYOTA ( Denso ) 90915-YZZF2 oil filter soaked up close to 5 ounces of the oil needed for the change . May go with the MOBIL 1 E.P. 5w-20 or give a few calls to local auto parts stores to see if any AMSOIL XL 5w-20 is available and the cost per quart . This wouild be for the '08 sedan due for oil change next month , currently PLATINUM 5w-20 .
Old 10-31-2008, 12:57 AM   #88
staypuft
aka SDMF
staypuft's Avatar
Drives: 07 LB Met Met
running royal purple 5w30, feels so much better than mobil 1
staypuft is offline   Reply With Quote
DIY: CHANGE MANUAL TRANNY OIL ttufrosty DIY / Maintenance / Service 157 09-07-2018 01:43 PM
Engine oil ddi not come out hans_fh DIY / Maintenance / Service 18 01-23-2009 11:30 PM
oil and oil filter question.. marcus DIY / Maintenance / Service 27 07-11-2007 03:25 PM
metal particles in oil 007 hatch DIY / Maintenance / Service 9 06-22-2007 02:56 AM
