Old 03-03-2013, 12:36 PM   #1
tooter
play every day
tooter's Avatar
Drives: 2012 Yaris L 2dr 5sp
Not yet...
You know, I thought about that metal lattice and was searching online to see if anyone else had any negative effects from removal. All I could find was problems with a screen on older cars, but that was in front of the MAF sensor. Removing it messed with the idle and A/F ratio for some vehicles. I can't see how removing it would cause any problems, although I thought it might make for smoother less turbulent airflow across the backside of the butterfly when it's less than fully open. The air flow over the tipped in end of the butterfly is smoother because it's slanted in the right direction whereas the backside tips upward into the airflow.
I just played it safe and used standard readily available off the shelf stock Toyota O ring gaskets on both ends. The metal lattice can simply be snipped out if desired.
Old 03-04-2013, 07:27 PM   #2
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
MUAHAHAHAHAHAHAHA!
Old 03-04-2013, 09:39 PM   #3
JustDidIt
JustDidIt's Avatar
Drives: '08G2T Prius
Awesome! Can't wait 2 see what you come up with..
JustDidIt is offline   Reply With Quote
Old 03-05-2013, 11:57 AM   #4
tooter
play every day
tooter's Avatar
It's gonna be a real doozy...
I'm sourcing the raw materials.
Old 03-07-2013, 11:26 AM   #5
malibuguy
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan
i like your thinking
-Greg...the Exhaust Freak.
-82 Malibu, 1uzfe swap
-97 Tercel coupe, 1nzfe/4.31
-96 Tercel 4dr
Old 03-07-2013, 12:47 PM   #6
tooter
play every day
tooter's Avatar
This whole project has been so much fun.
One idea always leads to another so I'm going to follow them off the beaten path just to find out where they lead. It's my favorite kind of experimental approach:
"Adapting things to an unintended purpose."
Old 03-07-2013, 02:29 PM   #7
CrankyOldMan
Aah yes, the old "under-utilized engineer" syndrome: if you don't give them problems to solve, they start making up their own.
I had also played with some ideas for a new plenum involving 6" aluminum tubing and some CNC'd flanges, but I seem to have lost a large amount of the files when I uninstalled AutoCAD. If you're going to be doing the CAD work yourself and you want some flow analysis, I have access to ANSYS at school and SolidWorks Flowxpres at work.
Old 03-07-2013, 07:25 PM   #8
tooter
play every day
tooter's Avatar
Thanks for the offer Cranky...
But I leave that to the CNC guys. We go over the design details and they render them into a 3D visual, and then into xyz coordinates that tell the milling heads exactly where to go. The really nice thing is that the design office and the machine are all in one location.
Old 03-07-2013, 01:07 PM   #9
malibuguy
Obsessed with 1.5L
I thought about recreating the plenum when I go to do mine...just because the factory is so damn ugly. But I wonder if a larger volume could benift even more?
-96 Tercel 4dr
Old 03-07-2013, 07:34 PM   #10
tooter
play every day
tooter's Avatar
I unolcked some secrets in that "ugly" plenum...
There's a "reverse velocity stack" which extends into the center of that really small plenum.
And I noticed something else... even though the picture doesn't show it, nothing is at right angles or parellel to the plane of the runner entrances. Everyhing is cocked at odd angles including that velocity stack.
Now this could likely be for noise reduction as that seems to be a major consideration in passenger vehicles, or it could be to break up resonant harmonic frequences so as to smooth out the peaks and valleys in the power band over a wide rpm range. There is almost no information on the web about these intake manifold issues, so I'm going to go off in a direction which I think will work.
Because that's what life's all about...
...finding out.
Old 03-07-2013, 07:45 PM   #11
JustDidIt
JustDidIt's Avatar
...finding out.
Old 03-09-2013, 02:01 PM   #12
CrankyOldMan
I managed to re-install inventor and get my project back. Here's a crude 3D pdf of a concept assembly. It's rather machine-intensive for the lower flange, so it would really need to be CNC'd, but the upper part could probably be done manually.
If you look at the bottom (four-barrel) end, you can see that the inserts are all a little different depth. This is to allow the entire existing plenum to be cut off and still retain the same relative tube length when mating to the 1NZ cylinder pitch.
Old 03-09-2013, 03:33 PM   #13
tooter
play every day
tooter's Avatar
I'm going with a different concept that retains the existing rounded square base...
...to save the most costly and complex task of machining the 4 runner entrances. I already have some 6 inch tubing left over from the velocity stack spacer, and might use that. Although the other end will be something different if I can get a hold of the right materials.
Old 03-09-2013, 06:32 PM   #14
CrankyOldMan
I had contemplated that, but then I would have to figure out how to weld up a rounded-square body. My idea was to match the radius of the base with some tubing, cut it into quarters, and weld panels between them. Given my lack of welding skill but substantial access to machining equipment, the tube + flanges seemed to make the most sense. It would still require someone to weld the seams, but tube-in-a-hole is easier than plates-hanging-in-space.
Old 03-10-2013, 12:11 AM   #15
tooter
play every day
tooter's Avatar
The solution to that is simple.
A 6 inch diameter circular aluminium plate with a rounded square hole cut in the middle of it. I know a really competent welder who can weld anything. The secret to any project is finding good honest people who you can trust.
Old 03-11-2013, 11:31 AM   #16
JustDidIt
JustDidIt's Avatar
Hey Tooter, I need to come up 2 LA and meet this welder of yours. I have a project I would like to run by him. Whereabouts is he located?
Old 03-11-2013, 06:40 PM   #17
tooter
play every day
tooter's Avatar
Sure.
Ajax's
7933 Gloria Avenue
Van Nuys, CA 91406
818-781-5667
Bill is the owner.
Tell him tooter sent you.
His place is easy to get to as it's just West of the 405 off the Roscoe Boulevard exit.
West on Roscoe
South on Woodley
East on Strathern
South on Gloria
Old 03-11-2013, 07:50 PM   #18
JustDidIt
JustDidIt's Avatar
Sure.
Ajax's
7933 Gloria Avenue
Van Nuys, CA 91406
818-781-5667
Bill is the owner.
West on Roscoe
South on Woodley
East on Strathern
South on Gloria
Awesome! Thank you!
homemade intake manifold ttr125fan09 Performance Modifications 1 02-17-2012 01:09 AM
Custom Intake Manifold + Direct Port Nitrous blacksandiegovitz Performance Modifications 9 04-21-2010 07:05 PM
Turbo Manifold thread Sabretooth Forced Induction Forum 78 05-22-2009 06:52 AM
