Old 09-06-2011, 02:18 PM   #91
Originally Posted by cgarcia1821 View Post
i want to install led lights in the interior, but i want them to turn on when i turn on the headlights...any help with where i can locate the correct wires for this? a picture would help :)
On the headlight stalk connector (remove the bottom steering column cover to get to it), Pin #13 is the switched wire for the taillights (which turns on with with both the high and low beams).
If the car has daytime running lights (or is 2009 or newer), then pin 13 is a ground, switched by the headlight switch (so, you would use pin 13 as your LED ground and would connect the +12 wire for the LEDs to a 12 volt source).
If the car is 2008 or older and does not have DRLs, then Pin #13 is not a switched ground, but instead is a +12V feed which is switched at Pin 10 (the wire to the left of the Pink one) (which will be green instead of white with a black strip). So, on this vintage, you would connect the + wire for the LEDs to the green wire in pin 10 and the - wire of the LEDs to a chassis ground.
Old 09-07-2011, 10:05 PM   #92
I accidentally starting messing with these wireds to see if any were for the headlights (i was trying to install interior led lights) and all of my dashboard lights are now going off like crazy (airbag, check engine, battery, sliding, etc), the a/c and heater doesn't work, the turns signals don't work if i step on the brake, and it no longer indicates what gear i'm in. I really messed up, but I would like to know if anyone has had this issue or knows a solution or what's going on.
YIKES!!!!
Check the Dome and ETCS fuses in the under hood fuse panel. Hopefully you popped one of those and didn't cook the ECM. The DLC3 connector is purely for diagnostics. There is a constant power wire on the connector for powering a diagnostic tool, but other than that no pin on that connector should ever be connected to a load.
Old 07-16-2012, 08:29 PM   #93
Rudra223
Rudra223's Avatar
Drives: 2006 Belta
Question where is the reverse light wire?
and what is the colour?
Rudra223 is offline   Reply With Quote
Old 08-17-2012, 06:47 AM   #94
mpyoos
Drives: yaris t1
Hi,
Trying to wire an aftermarket radio
Please advise:
Re- yellow wire, a black wire, a pink wire and a white wire - which wire is ground (earth) and which wire is power - 12v? Which fuse is the radio fuse? The radio works if I connect directly to the battery...
mpyoos is offline   Reply With Quote
Old 08-17-2012, 07:54 AM   #95
Originally Posted by mpyoos View Post
Hi,
Please advise:
What year is your Yaris and was it built in Japan or France?
Old 08-28-2012, 10:46 PM   #96
mamun22s
Drives: Toyota Vitz
Tach wire location at pin 9 of DLC3 connector:
09 (Beige wire):
07-08 (Green Wire):
Can any one help the abt the chip on the pic coloured red and blue. what is there function?Be cause one of them getting hot. What actually they do? and also the function of the fuse? How do i know whether they functioning or not.
mamun22s is offline   Reply With Quote
Old 08-28-2012, 10:56 PM   #97
They are relays. The left one is the IG1 relay and the right one is the HTR relay. The left one gets warm when the ignition is on and the right gets warm when the blower is running. That is normal.
The fuse above it to the left is for the power windows and the one above it to the right is for the defogger.
Old 09-26-2012, 09:42 PM   #98
Rammy
Where is this whole piece as seen in post 14?
I want to wire some door sills and have them light up when the door opens up. I usually keep the light in the off position and not on the "door" position. So if I want it to work the way I want it to, am I going to have to keep the switch on "door"? This might be the wrong thread but I was redirected by Scott on another thread. Thanks!
Rammy is offline   Reply With Quote
Old 09-26-2012, 09:47 PM   #99
Behind the little storage cup on the bottom left side of the dash.
Old 09-26-2012, 09:53 PM   #100
Rammy
Oh ok! Thanks.
And where can I tap into the parking lights? The lights that turn on when you twist the switch half way. I am also installing some LEDs for the interior and I want them to turn on w/ the parking lights. And do any of you recommend the "L bars" or just regular LED clusters? I want them to go under the whole dash kind of where your feet go.
Old 09-26-2012, 09:57 PM   #101
Oh ok! Thanks.
See my remote start wiring DIY for the parking light connection:
http://www.yarisworld.com/forums/showthread.php?t=24860
Old 10-19-2012, 01:38 PM   #102
I thought your post might have been spam with odd combination you were asking about, but since you sent me a PM with some specific questions, it seems like you are not a spammer.
In your PM you mentioned that you found all except these two:
1.Oil circuit detection
2.Cut oil and electric circuit off.
For #1, the Yaris has an oil pressure switch that is located on the front of the block about 6 inches above the oil filter. It has a single yellow wire (since its case is grounded to the block). That yellow wire is only an input to the instrument cluster for the warning light.
For #2, I am not sure what you are looking for. The only circuit associated with oil is that simple oil pressure switch.
Old 10-19-2012, 02:19 PM   #103
OK - That makes more sense for it to be the fuel cut-off. Sometimes the directions seriously lose something in translation.
In that case, you are interested in the violet wire on Pin 7 of the smaller ECM connector.
Old 10-19-2012, 03:51 PM   #104
I would need to see a better explanation of the module. In theory there should be two wires - in and out, so the device can interrupt the fuel pump feed.
Old 03-04-2013, 01:31 PM   #105
fase4
Drives: Yaris TS 05
hi! If I want to turn something on with the flash or high beams od the headlight, were I had to connect the + and - wires of my 12v circuit? I wanna do this because I want to open my garage goor with the opener activated when I flash my headlights.
Maybe I have to tap de + with the Pin 9 and the - at the Pin 11?
fase4 is offline   Reply With Quote
Old 03-04-2013, 05:33 PM   #106
If you have a 2005, then yours is a fist gen, so the headlight wiring will be different than the second gen connector pictured.
For the first gen, the red wire with the yellow strip in pin 9 is the high beam wire from the switch. That wire gets switched to ground when the high beams are flashed, so you would use pin 9 as your switched ground wire.
You would want to use a relay that you switch the coil of with that wire, and then use the normally open relay contacts to trigger your garage door opener's switch.
Old 03-05-2013, 03:07 AM   #107
fase4
Drives: Yaris TS 05
regarding to colors, I cannot rely
lol
Mines is a european base model so maybe for that the colors difference
Ok I get it about the pin 9. So I tap here the - right? what about the + connection? Also the relay for what would serve?
sorry for the question but I know almost nothing about this
Old 12-12-2013, 03:52 AM   #108
yelcur
yelcur
Drives: toyota yaris sedan
please send full detail on toyota yaris sedan year 2008. .front totally damaged in accident .if someone selling parts let me know..! wiring system completely damaged.
yelcur is offline   Reply With Quote
DIY Cruise Control FAQ (2006-2010 Yaris) CTScott DIY / Maintenance / Service 468 11-19-2024 04:45 PM
2012 Yaris at SEMA Jason@SportsCar Third Gen Yaris General Discussion 5 09-23-2013 04:55 AM
New Yaris race car Jason@SportsCar Tracking, Racing, Auto-X Forum 83 11-01-2012 03:32 PM
