Old 01-10-2011, 05:07 PM   #1
Originally Posted by frankmontreal View Post
hi! same as teddy 06 canadian yaris, called the junk yard they got the stick with cable for 30$, so from what i understand the rest of the stuff from you scott?
Nice price on the stalk with wire.
I do have the pins that you'll need to complete the stalk wiring. Here's the link to my thread, which has pictures of the pins, but you need the three pins (ECM connector pin and two pins for connector D3) to wire up your stalk:
http://www.yarisworld.com/forums/sho...ht=cruise+pins
Old 01-15-2011, 01:52 AM   #2
bairjo
Stalk 84632-34011 on ebay today for 19.95. 10 available. Do your search by typing yaris cruise control. If you type the part number it will not show up.
Old 01-15-2011, 10:39 AM   #3
ibanezjeepguy
Drives: 2010 Meteorite Liftback
haha, 15 to 30 days shipping..... I guess its worth the wait ?
I just scored a nice factory stereo off ebay recently, good find as well
ibanezjeepguy is offline   Reply With Quote
Old 01-15-2011, 11:56 AM   #4
bairjo
It's worth the wait for me as I am in the process of breaking in my new yaris. I'm trying to vary the speed during my 30 mile commute each way. Not a bad little break in drive each day. I have read that setting your speed with cruise and forgetting about during break in is the worst thing to do. So I can wait....
Old 02-26-2011, 11:29 PM   #5
kimjo
Drives: 2007 HB Yaris
I got mine in 22 days looks good and the wires from ctscott
kimjo is offline   Reply With Quote
Old 01-15-2011, 12:04 PM   #6
ibanezjeepguy
the way engines are built today they can be broken in with less than a weeks worth of driving
Old 01-16-2011, 02:48 AM   #7
bairjo
One week of driving how many miles? Based on your reply you and I agree the car needs a break in. Just how many miles is in question. I understand why you feel that one week is good enough. The tolerances of todays cars are much tighter due to improved capabilties of machining or grinding equipment. However, that is on paper and not what is always held and passed on the shop floor. Even with a 100% inspection process, marginal product will get passed. Therefore, I have chosen to go the time proven break in process for piece of mind. It doesn't cost me anything so why not do it?
Since this is a thread on cruise control we probably should look for a thread on break in peroid for any further discusion on that subject. In the mean time, I'll be waiting for my cruise control stalk to arrive.
Old 01-16-2011, 08:34 AM   #8
ibanezjeepguy
true that man, maybe a mod should wipe these last couple posts...
post back with how your stalk install goes and if you have any problems.
Old 01-24-2011, 12:35 PM   #9
Buddy Fan
Drives: 2010 Yaris 3 door
Went to the dealer to order the stalk wire and clutch switch and was told they changed the part number for the cc stalk wire to 84633-02020. Hope this helps anyone planning this DIY.
Buddy Fan is offline   Reply With Quote
Old 01-24-2011, 01:17 PM   #10
Thanks for the heads-up. I updated the thread with that info and have confirmed it via the EPC.
What's the latest pricing on the stalk, wire, and clutch switch?
Old 01-25-2011, 09:42 PM   #11
Buddy Fan
I'll have to get you exact numbers, but it was in the range of $45 to $50 for both.
Old 01-24-2011, 11:23 PM   #12
ibanezjeepguy
same thing happened to me a couple months ago... the dealer can easily see the older numbers. even toyota parts zone or comparable sites list the new and old numbers I believe.
Old 01-25-2011, 05:35 PM   #13
yarisbird
yarisbird's Avatar
Drives: 2007 Yaris HB Bayou Blue
I just completed the installation of cruise control in my 07 hatchback using the oem stalk that I purchased from e-bay and the cruise indicator module/light and wires/pins from CTScott. The cruise control works great.
Only problem is with the indicator light. It turns on for one second when the ignition switch is turned on, but when the cruise control is turn on there is no light. I installed it according to the instructions using splice tap connectors. All of the connections are tight.
CTScott, is there any diagnostic check that you recommend to determine why the light doesn't turn on when the cruise switch is pressed? I have a digital multimeter if that helps. Thanks for all your help.
yarisbird is offline   Reply With Quote
Old 01-25-2011, 05:40 PM   #14
Just to verify:
The blue wire is connected to the wire that goes to the ECM pin and one of the wires going to the stalk?
The white wire is connected to ignition switched power?
The black wire is connected to ground?
Old 01-25-2011, 05:51 PM   #15
yarisbird
yarisbird's Avatar
Yes.
The blue wire is spliced into the wire that runs from the ecm to the connector under the steering wheel. (pin #1)
The black wire is spliced to the wire that runs from this connector (pin#2) to ground.
The white wire is spliced to the pink wire on the connector under the ignition switch.
Old 01-25-2011, 09:37 PM   #16
Yes.
OK. There is something wrong with the module. PM me you shipping address again, and I'll ship you a replacement.
Old 01-27-2011, 12:41 PM   #17
Yarisonline
Drives: 2007 Yaris CE
Hey, I suggest trying to find that part at www.yarisparts.com ,that's where I get my parts at warehouse price. Good luck :)
Yarisonline is offline   Reply With Quote
Old 01-27-2011, 01:01 PM   #18
I was just curious as to what the going price is, as I picked up a couple recently for less than wholesale, that I can offer for $40 shipped.
Cruise Control chessclubloser DIY / Maintenance / Service 11 03-27-2010 12:59 PM
Using Cruise control Driver General Yaris / Vitz Discussion 14 11-09-2006 11:12 PM
