#91 |
Data doesn't lie
Drives: That Scrappy 2zrVios Join Date: Oct 2014
Thank you for the feedback.
I dont want to control the information, Ive already created a list of parts needed in the beginning of this discussion. What I want is to use my sponsors help to accumulate the parts needed, and if there is enough interest we can get a better deal...like a group buy. If there is no real interest, then we just move on and hope the next guy that does this swap tries using a Yaris transmission....because that is the only uncertainty as of now. |
#92 |
![]() ![]() ![]() ![]() ![]() ![]() Drives: '08 2zr swapped Vios M/T Join Date: Oct 2012
I can't remember if this was already answered, but if the Yaris Trans doesn't work then does the 2zr Trans direct fit into a Yaris.
Optimally you'd just keep the stock Yaris Trans and just mount in the new engine. If the price is reasonable then this is something i'd like to do down the road. Is the stock 2zr really a big gain in performance over the 1nz? I know the hp increase and tq is good but my question is how does it run as a stock engine? I'm trying to get a feel for how a stock 2zr runs compared to my modded NA 1nz. My 1nz is a lot of fun to drive now and I don't want to give that up just for some extra ponies
#93 |
Data doesn't lie
The 2zr trans works, its what we used.
Check out post #68, Scott mentioned how well the 2zr performed when he drove the swapped yaris. The gains in stock form are roughly 30hp and 20ftlbs. |
#94 |
So there is virtually no downfall to using the 2zr Trans other than a bit of extra work and cost. this looks like it would be an engine swap if all the mounts are the same and wiring is plug and play.
Where I live I wouldn't have to register the engine to pass an etest. As long as there are no CEL's then it's good to go as far as I know
#95 |
Data doesn't lie
When using a 2zr manual transmission you need the xd ABS module and wiring too...because there is no speed sensor on that transmission. Possibly the axles as well, and I think the gear ratios are taller.
#96 | |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 black yaris Join Date: Oct 2010
-Derrick- "Racing is important to men who do it well. When you're racing... It's life. Anything that happens before or after, is just waiting." |
#97 |
![]() ![]() ![]() ![]() ![]() Drives: 2015 H Production Yaris Join Date: Oct 2009
2012+ Yaris does not have a speed sensor on the trans either, pulls it from the ABS tone ring.
2005-2008 SCCA Solo BS National Champion 2017-2018 SCCA H Prod National Champion
#98 |
Data doesn't lie
Oh thank you Jason, I didnt know that!
#99 | |
2ZR swap. DO IT! Ask how!
Drives: 09 Meteoric Metallic HB Join Date: Feb 2011
The speedo sensor hole looks to be the same on all of the C-series gearboxes I've encountered. Looking at the parts diagrams for the xD, the speedo gear is still installed on the differential. If that's the case, you should be able to drop a standard speedo sensor in the hole and keep your Yaris ECU, assuming you have the differential-based speedo in the first place. My 09 has it, and all of the other C-series gearboxes I've torn apart use what appears to be the same part. Looking at the compatibility of the speedo sensor (83181-12020) it's used on lots of stuff: "TOYOTA: 14 models, 905 variants between 1991 and 2013." |
#100 | |
#101 |
Hmm. I guess it wouldn't serve any purpose, since the bearing seats against the diff carrier itself, but it's still shown in the xD parts diagrams.
#102 |
Data doesn't lie
This would make the 2zr swap so much easier...are the 2012+ 1nz's using a micro MAF sensor too?....that would be a direct swap with no wiring changes!
#103 |
![]() ![]() ![]() Drives: 2013 Yaris Hatchback L Join Date: May 2013
How do you go about checking if its a micro maf? I'll take a look at mine.
#104 |
MAF sensor is the same from 2007-2015. The thing that could hurt your swap on a 2012+ is the ECU and harness plugs, they are different. When we built the 2015 it was easier to swap the entire harness from the 2007 versus rewiring. If you can use the Yaris ECU and engine harness on the 2ZR you should be able to put it in any year car.
#105 |
Data doesn't lie
Interesting. I dont know that a pre-12' chassis harness would work on a 12+ though...its .not likely due to all of the interior changes. If someone becomes interested, Ill need to get a copy of the 12'+ wiring diagrams to come up with a solution.
www.Facebook.com/ArmstrongRacingPage www.youtube.com/c/ArmstrongRacing www.instagram.com/Armstrong_Racing http://www.wheelwell.com/profile/55f...35ac4a/garage/ Last edited by ArmstrongRacing; 12-15-2015 at 03:32 PM. |
#106 | |
![]() Drives: 2007 toyota yaris s Join Date: Oct 2015
#107 | |
Data doesn't lie
I'm still unsure if the Yaris Tsport has a 5 or 6 speed though, the Internet has conflicting information... |
#108 | |
![]() There's a few variants that use the EC67 gearbox, but it's very different from the C50. The slave cylinder is directly on the throwout bearing, and the hydraulic hard lines are different. The case is also 2-piece instead of 3. Here's an eBay UK listing of a similar gearbox. |
| Toyota Hybrid R Shows Its Yaris Roots | MadMax | General Yaris / Vitz Discussion | 0 | 10-10-2013 06:14 PM |
| 2012 Yaris at SEMA | Jason@SportsCar | Third Gen Yaris General Discussion | 5 | 09-23-2013 03:55 AM |
| New Yaris race car | Jason@SportsCar | Tracking, Racing, Auto-X Forum | 83 | 11-01-2012 02:32 PM |
