Old 08-12-2018, 11:06 PM   #91
Originally Posted by stidnam View Post
Not trying to be argumentative tmontague, but Toyota did match the 2zr to the HB chassis, like you mentioned. If using all of the factory mounts and driveshafts, I wouldn't expect a single clunk or growl from the drive train. I wouldn't expect that to apply to a Vios though.
Now that may not necessarily be the fix for this problem, but it'd be something I'd keep in mind if the problem persists and you've ruled everything else out Adam.
Interesting tidbit of information - the mounts and brackets used in the new 2018 GRMN Yaris are exactly the same as the 2008 South African and New Zealand ZSP90. Looks like Toyota went and just dug through the parts bin. It should also be noted that all of those vehicles use a 6 speed transmission - 2008 models used an EC67.
Anyway I digress. Adam, I've read back through your thread and I couldn't see which drive shafts you used? Assuming the Yaris ones. Not sure what the exact differences are, but it may be also worth investigating the differences in the XD shaft lengths and whether that might also be a solution - just thinking if the 2zr rh mount has shifted the motor and box towards the left...
I agree w/ you but all of us 2zr swaps hb or sedan have originally kept yaris axles. If the swap was to be done totally to factory spec in a HB then yes I would expect it to be silent. With the mix and match to keep costs down that most of us have, noises are inevitable. Plus most who have done the swap are racing their cars and have other modifications in it either transmission gears/lsd or engine mounts which leads to all kinds of fun nvh that factory spec won't leave you with.
At this point I'm keeping my fingers crossed that the fuel trims level out as that is the main issue currently. Unfortunately I'm not much help as this is out of my wheel house in regards to what it could be
Old 08-15-2018, 10:04 PM   #92
atomic_hoji
Drives: 2018 Yaris SE 5MT
So, no such luck on the AFR sensor. Swapped the Yaris' 1NZ sensor in and it didn't change the behaviour - now, the Yaris does use a different part number, but same electrical checks, 4-wire, etc.. and the car ran the same using it. I cleaned the 2ZR sensor by soaking it in gas for several hours and wiping clean - it was pretty clean when I pulled it anyway, but I thought while it was out I'd do it for good measure.
What I did find after I swapped the 1NZ AFR sensor is that when I went to clear the codes there is now a MAF code as well for 'MAF sensor circuit out of expected range' or similar; I'll have to check the OBD2 code, but I think it's P0101. This is new since installing the FPC ECU.
I did also find that the LTFT is better than it was before. The test drive I did after installing the FPC ECU sets the LTFT at -27% (this was before playing with the AFR sensors at all, but after installing FPC ECU) instead of the almost -40% worst case that I had seen prior; loaded the old data and it was fugly, lol. So I think the FPC ECU has helped, but then it's hard to say given there's clearly some other problem.
In a quick read on the P0101 code, apparently the MAF can get tripped up reporting air flow if the signal is noisy from nearby, high current wires. Since I've checked and double-checked the wiring supplying the MAF, I tried a shielding wire quickly - a grounded wire wrapped around - with no change. But, the MAF is basically snuggy-bunny with the main ECM, so going to have to try to rig up a test where I can move the ECM well away from the MAF and see if that helps. The other thing is the OBD2 code does point to a MAF problem, which I boggles me because it's a brand new MAF and electrically checks out when doing the troubleshooting checks. Thinking that maybe mixing the xD 2ZR-FE intake with a 2ZR-FAE iM MAF could cause an issue?! If the calibration assumes a larger intake diameter, so it's reporting X g/s air flow, but in reality with the smaller intake only X-- air is getting in, so it runs rich and the ECM adjusts ST/LTFTs to accommodate ...? Also going to look at the injectors as a last check - they're pink, like they're supposed to be, but who knows, maybe the iM owner had bigger injectors installed?! I can't read the injector numbers while they're in place, so I figure as a last resort I'll confirm the numbers and make sure they match the model injectors.
So more troubleshooting to do.. Generally it drives ok. Misbehaves some at idle and is rough when shutdown; like shutting a diesel off, lol. Since installing the FPC ECU I have found it's touchy when dropping throttle from accelerating; e.g. pulling into traffic and accelerating up to speed quickly, then shifting and letting off the throttle to cruise the revs 'wobble' and rock the engine around on the mounts.. like stabbing at the throttle. Not sure if the FPC ECU change is related or if it's whatever else is causing the fuel issues worsening.
I feel like when I figure this out the AH-HA moment I will feel both relieved and like a dumb-ass - it feels like it's going to be one of those simple things..
-- Adam
Old 09-12-2018, 11:22 AM   #93
atomic_hoji
SO, another quick update - fortunately someone jogged me as I've been busy with plant shutdown at work, kids back to school, back to shift work (rotating days/nights) etc.. etc.. and realized it's been forever since I've jumped on to YW.
SUCCESS! Somewhat..
My 'stick-tape-everywhere-that-could-be-rubbing' test found the issue, which in hindsight I can't believe I didn't find earlier, but in my defense it's really hard to see down in there. I happened to stick my hand in around between the front side of the engine and the frame-side body mount and noticed it's really close - when looking from above it's blocked by the cover on the frame mount and underneath there's a ton on pulleys and A/C piping in the way.. Sure enough, tape test revealed rubbing. Supported the engine, dropped the engine mount, frame mount, and pulled the engine bracket off. Using a grinder clearanced it about a 1/4", painted, and re-installed - voila, no more left-hand turn vibration! I took a picture of the brackets, showing there wear marks, but then got excited and re-installed without showing the mod.. whoops.
Take away: if you do the 2ZR swap in a 3rd gen. HB and find you have a left-hand turn growl/vibration, trying gaining some clearance by modifying the engine bracket with a grinder by about 1/4" along the outer rib - runs between the top 2 bolts.
Also played with some ideas on the intake side of things which supported my suspicion about the mixing xD intake with iM MAF. I ordered and (finally) received an AEM Scion/Corolla iM short-ram intake kit, installed it, and the P0101 and P0172 codes are now gone. When monitoring the LTFT it is sill quite low, but resolved enough that it's not tripping up the ECM and throwing a code anymore. In going for a ride with a buddy in his new Tacoma, we found that general, daily type driving he sits around -7 to -10 LTFT on his 2GR V6, BUT at start-up the learned value remains approx. 0 for both. Seems like Toyota's run a bit negative LTFT while driving around normally. Might try my FJC next time I'm out and get another sample...
Maybe it seems obvious, but a combination of using the Fuel Pump Control ECU and installing an iM intake has adjusted the LTFT to the point where it no longer throws a code - or, in other words, install the stuff the ECM is expecting and it works. lol
As a side note, and good to document, this came about because I was focused on using the Scion xD parts for the swap - the xD parts work for a lot of things, especially on the 2nd. gen swaps. For this -FAE swap from the iM, the mechanical parts, e.g. engine mounts, heater & rad. hoses, etc.. the xD parts work, however where the electrical bits are concerned, e.g. MAF, the differences cause the iM ECM issues. Using the MAF example, fit the same and has the same electrical connections, but do not work the same, and even though the intake piping is a mechanical piece, since it supports the MAF it also needs to meet iM spec, not the xD - mix and match == bad.
Other general, on-going things I've been finding with the swap:
The throttle is extremely touchy; it's not that I needed to get used to it, it's spaztastic in the first 10-20% (ish?) of travel.. lol. And it still has some fuelling related problems - idles rough, nearly stalls for the first split second until fuel picks up when accelerating (like a delayed response) so I use more throttle when starting than I did with the 1NZ (or in any manual car I've driven), and shudders at shutdown. Basically same issues as above, excepting that I found the weird 'stabbing' on the throttle issue is user error.. apparently if your big-ass, clompy safety shoes remain on said touchy pedal and you don't notice it will cause issue - I found my days off it was fine (sandals) then had the issue when I went in to work the next set of nights... two and two together = oooohh... dum-dum.
I hate (I mean vehemently hate) my exahust setup, and want to change it. Given the Corolla / iM uses an approx 2" exhaust, and the performance setups at 2.25", I won't be surprised if replacing the 1.75" xD/Yaris-with-crappy-bends-making-it-more-like-1.5"-in-some-places setup helps dramatically improve the remaining issues.
Progress.. Slowly working down the little issues here and there. That said, I do daily it to and from work without issue (except the exhaust rattling, which is just annoying as F*). We did a couple hour trip in it and, less needing the A/C recharged still (d'oh!), it ran a treat. Tracked fuel economy now that it seems to be having less LTFT issues and found on a trip of ~200 kms, driving mostly rural roads ~90kph it was sitting at 8.2 L/100km or ~28 MPG(US).
Take care,
-- Adam
Old 09-13-2018, 04:51 AM   #94
stidnam
Drives: Starlet
Great update and glad to hear you've ironed out those bigger issues. Bet that's a good feeling :)
I suspect that the Yaris gearbox mounts and mounting points aren't providing enough space for the 2zr to bolt to the gearbox and clear the frame. Just out of interest, was there a little lateral tension on that engine mount when you unbolted it?
Good to know about the need to keep things matching up :)
Interesting on the throttle point as well. I actually find the stock Yaris throttle in the first 10 to 20% to give me no throttle, which to me is not what I'm expecting coming from a car with a cable operated throttle. I'd welcome a linear throttle that mapped 1:1 what my foot was doing! Speaking of gas pedals, the pedal is damn aweful as well but I've been eyeing off a replacement option from another Toyota that should make heal toe a little easier.
stidnam is offline   Reply With Quote
Old 09-13-2018, 07:31 AM   #95
Great to hear you are figuring out the issues!
Fwiw- my 1nz and now 2zr all sit around -10 to 12 % LTFT. This has never caused any issue in my engine and it runs fine so as long as you are not getting a CEL then I'd just leave it as is.
Toyota throttle by wire system is very light and not very refined. I just outright stopped driving my car with my winter boots on as it became ridiculous.
Enjoy driving your unique car and congrats on what you've done!
Old 09-15-2018, 08:06 AM   #96
atomic_hoji
Thanks for the positive feedback guys... it is nice having a peppy, reliable ('ish?!) daily driver. Does also mean the FJC's time in the driveway is coming to an end..
It is definitely pushing hard into the LHS (transmission) mount, and required a lot of 'persuasion' when I had to get the RHS mounts installed and back into place. I knew that was going to happen from the effort required when it went in the first time. Optimally, I would like to pull the trans. side mount, dig out the rubber and re-position the steel tube for the bolt offset, then pour polyurethane to make a DIY mount that holds it tight toward the LHS better. I'll add it to the projects list...
I recall you saying that and thought about it when I was going for a ride in the Tacoma. Curious to see if the FJC also does it, but looks like that's well within' the norm. Driving around into town last I was sitting -15 to -17% LTFT, dropping into the -24% range, so I suspect it's still not perfect, but as you said, no CEL/MIL is a win for daily driveability.
LOL, I'm now slightly more worried that winter is coming soon.. jk'ing - but, have to see how I manage in work boots.
-- Adam
Old 10-07-2018, 10:00 PM   #97
atomic_hoji
SO ... LTFT is back to -35% or so and CEL/MIL is on again ...
I was under the hood and realized in doing troubleshooting I'd disconnected the PCV vent from the valve cover to the air intake... so I diligently reconnected it and blammo, back to the same old problem.
Since the PCV seems to be directly impacting the LTFT I decided to pull the intake manifold and check the PCV valve - turns out it works fine, but not a big waste as I figure I'll install the catch can I bought.. BUT, the intake has quite a bit of oil and a stanky smell. The oil has a couple thousand kilometers on it, but I decided to change it anyway to see how it was doing - the engine did sit at the wrecker for who knows how long. Oil is 0W20 and was warm, but came out very thin, nearly like water, is very dark, almost black, and stinks god awful - same smell as in the intake manifold.. I've smelled gas in oil before - reasonably recently when a friend's bike carb was flooding and dumping gas into the oil - this isn't quite the same, and the same friend dropped over and didn't think it was quite the same either.. The smell is nasty though, almost like exhaust gases or the oil being burnt..?
Not really sure what's up with this stubborn thing... borrowed a compression tester from a friend to do due diligence and make sure I don't have bad rings, but given it only has a few thousand kilometers on it I wouldn't have thought rings would be suspect.. That said, I did have the oops with leaving the exhaust manifold taped and starting the engine - made a good bang, scared myself stupid.. lol - but I wouldn't have imagined that could have blown a piston ring.. ??
Open to other ideas re: sources of super stinky oil and would be causing combustion to be too rich...
-- Adam
Old 10-31-2018, 11:39 PM   #98
ArmstrongRacing
Data doesn't lie
ArmstrongRacing's Avatar
Drives: That Scrappy 2zrVios
I've replaced many PCV valves due to vehicles running lean before, its not uncommon.
The only way I found that was the issue is by 1) doing smoke test on the manifold and found ZERO leaks. 2)replaced A/F sensor due to a rapid fluctuation between 0 and -30% STFT. 3)After that the LTFT was staying around -17%. 4)Thats when I replaced the PCV valve and the LTFT dropped down to 8-10%
What are the codes youre getting and hows it run?
Old 11-01-2018, 06:51 PM   #99
atomic_hoji
Hey Tom, thanks for the note! The code I'm squabbling with is P0172 System to Rich, which jives with the way negative LTFT. For general driving it seems alright, has a bit of a howl/vibration when I left off throttle and coast, but the only real nuisance is a terrible idle - it's very rough, has a lot of vibration, and shudders; which I assume is the ECM pulling so much fuel trim that it's wanting to stall (never has though..).
For the small cost of a PCV valve I may just give replacing it a try too, just to rule it out.
After I had pulled the intake I did a little driving around with the emissions disconnected at the air intake - so disconnected the PCV to the intake manifold, the valve cover vent, and the fuel purge at the throttle body and taped them all off. When I compare the plots for AFR, STFT, LTFT it doesn't appeared to have made much if any difference, which seems to bust my theory that it's pulling oil or fuel vapour into the intake and causing the ECM to pull fuel trim.
I did find that there seems to be a correlation between the AFR sensor going way lean when the purge solenoid operation. Originally I had thought about fuel vapour getting into the air intake and when the solenoid closed it stopped adding it, so it leaned out and fuel trim had to adjust. Now, after trying the line disconnected, I'm wondering if there's an electrical noise issue where the solenoid energizing / de-energizing is tripping up the AFR sensor.. Just a quick theory, but haven't chased it.
The other obvious culprit with a fuel problem could be the injectors dripping/leaking. I haven't had the time to pop them out and give them a check, but hoping to get at it soon; unfortunately available time is getting less and less, not better..
I did do a compression test last weekend (or one prior..?) and it was solid numbers across all cylinders; good pressure, consistent across cylinders, and held steady.. Not surprisingly I don't think there's a mechanical problem with such a new engine, but was worth a check - and a huge p.i.t.a to get at those spark plugs and get a tester hooked up. lol
Thanks as always for the help!
-- Adam
Old 11-01-2018, 10:38 PM   #100
ArmstrongRacing
Data doesn't lie
It seems you’ve done the right steps in eliminating possible issues. The odds are low that an injection is the issue, but have you checked the MAF signal at all? It should gradually rise with the RPM, and spike pretty high when you stab the throttle.
I remember you saying something about a different fuel pump control strategy on the IM right?
Old 11-02-2018, 05:55 PM   #101
atomic_hoji
Thanks for the feedback Tom! I agree, it seems unlikely the injectors are an issue, was thinking it would rule them out at least - the engine did sit at a wrecker for about a year with the fuel line crimped and no idea if it was drained properly, I figured maybe ethanol gunk stuck in one of more injectors.
After I replaced the MAF and intake with iM models vs. xD and the MAF related codes went away I'd been ruling out MAF problems and basically ignoring it to chase other things. BUT, you bring a good point - I've been so focused on trending the LTFT and AFR, but I haven't included the MAF signal to see how it's responding! I'll have to play with the data I had collected already and plot it again with the MAF signal. And, definitely worth running it through the rpm range as you suggest to see if it's even behaving as it should.
The iM does run a Fuel Pump Control ECU like the 2014+ Corolla and a number of other newer Toyota's do; except the Yaris, which is out-dated... which is also great because it's simple! lol I have wired an iM FPC ECU in and it seems to respond as it should, which is basically demand 70% fuel pump duty unless you go full throttle, then it bumps up to 100% fuel pump duty.
I'll have a try at a couple of things as you suggested before I go and start yanking injectors..
-- Adam
Old 11-05-2018, 09:08 PM   #102
ArmstrongRacing
Data doesn't lie
So do you have a xD intake that your not using any more? I may be interested in that
Old 11-06-2018, 01:28 PM   #103
atomic_hoji
I do actually.. I did modify it to fit the 3rd Gen. as it doesn't fit under the headlight like on the xD. When I'm home tonight I'll have a dig around and see if I can get you a picture of what I've got. I'll PM you tonight.
I did also have a look back through some data and did a few 2nd to 3rd gear pulls at different loads; well, wife drove while I data logged. The MAF responds linearly with revs, but when you throw the clutch in the MAF tanks and everything goes squirrelly from there.. And some random squirrelly stuff here and there with the AFR - which I did run a known working AFR sensor with the same results. I started plotting other things, like VALVMATIC angles as the Lift has a huge impact on air, but don't know what's normal on there or abnormal - I did notice VALVMATIC Target angle is never populated.. always reads 0. wondering if it has an issue and when load drops it's dropping Lift, reducing air flow, and the system goes squirrelly from there..
Just thinking out loud..
-- Adam
Old 11-06-2018, 08:17 PM   #104
atomic_hoji
Since I can't figure out how to stash the picture somewhere without making it super tiny...
-- Adam
Old 11-07-2018, 02:39 AM   #105
ArmstrongRacing
Data doesn't lie
#6
Old 12-04-2018, 09:11 PM   #106
atomic_hoji
Quick update: been busy busy with studying for work, but after the last test I took the weekend off to kickback, relax, and actually did a bit of work on the Yaris. Unfortunately, I think the brain marbles as to the troubleshooting I've done on the Yaris have been displaced by studying.
I followed Tom's advice and had a run through the MAF response. Took the car out with my wife driving and had her pull through gears gently, then progressively using more throttle up to basically flooring it in 1st, through 2nd and 3rd. MAF seems to respond as expected. Do find that the values are a little high as compared to the service manual (not surprising there's extra air given the negative fuel trim) but then my idle is a bit on the high side anyway - more on a related, new issue in a minute.. :face palm:
Using my fancy little jig I also cleaned the injectors with carb cleaner, just for the sake of due diligence. It didn't help, but it's done, and it's the first time I've tried it so it was an educational experience, lol.
In a prior job I was a Control Tech and in flow measuring applications where you had short pipe runs and turbulence we would install flow straighteners to help stabilize the flow readings. There are the same sorts of things for automotive intakes - some manufacturers actually use a rough sort of straightener in their intakes. I installed a piece of door screen across the end of the intake (held by the filter clamp) and it brought the LTFT down into the -20% to -26% region - the car will go for a couple of days before the codes pop back on now; PROGRESS! I've ordered an actual flow straightener to fit my intake and I'll have to see if it helps. Also ordered a used, OEM MAF from eBay - I still have a dis-trust of this aftermarket MAF and the used OEM was actually cheaper than what I paid for the aftermarket! Have a couple of other ideas related to airflow as well that I'll keep in my back pocket..
Anyhow, new issue: after clearing the learned values and resetting everything after messing about with the car I now have a revving problem. I've read the Scion iMs have a "rev-hang" issue between shifts, but that's not quite the issue.. When I put the clutch in the revs drop, then bounce up to about 3000 rpm and sit there for about 2-3s, then drop off. I have to stop at a guardhouse on my way in to work and I get looked at funny as to why I'm sitting revving my engine - I'm just waiting to get hauled aside.. lol Now, the embarrassing part: this could be something to do with the injector cleaning or the screen on the air intake (not too bad); it could be because I kicked my ECM across the garage floor on accident (dammit!); or it could be because I disconnected my throttle body while powered (the clue should have been that it was making an electrical whine.. :face palm:)
Ever have one of those days..? lol
OH, on a much better note, I did get my microimage engine bay short shift kit installed. Fits great, and I can now install the block heater as an added bonus. Transmission is nice and notchy now; because #racecar!
-- Adam
Old 12-04-2018, 10:16 PM   #107
06YarisRS
Drives: 06 2ZR Turbo Yaris RS
Yup, many of them.
And, I too unplugged my MAF while powered. I heard the "whine". No adverse effects as of yet.
My chance to offer encouragement in return. Keep goooooooing! Can't wait to witness the end result. It will be legendary!
Old 12-04-2018, 10:30 PM   #108
atomic_hoji
lol, thanks man. A dash clear of warning lights will feel pretty good.
I didn't mention, but is a nicety, that I finally re-installed my trim pieces; center console, windscreen bits, etc.. so it looks like a complete car again and no a ghetto-mobile as my wife has referred to it. lol
-- Adam
2zr, 2zr-fe, 3rd gen, t-sport
Toyota to Debut 2018 Yaris At New York; No Mention of Yaris GRMN Thirty-Nine General Yaris / Vitz Discussion 39 07-01-2017 11:38 PM
Went and looked at a yaris Sport! mr_miles General Yaris / Vitz Discussion 19 02-20-2012 10:28 AM
My UK Yaris T Sport Matty Photo-Video-Media Gallery 9 02-21-2010 07:04 PM
