Old 08-11-2018, 07:27 AM   #11
stidnam
Drives: Starlet
Not trying to be argumentative tmontague, but Toyota did match the 2zr to the HB chassis, like you mentioned. If using all of the factory mounts and driveshafts, I wouldn't expect a single clunk or growl from the drive train. I wouldn't expect that to apply to a Vios though.
Now that may not necessarily be the fix for this problem, but it'd be something I'd keep in mind if the problem persists and you've ruled everything else out Adam.
Interesting tidbit of information - the mounts and brackets used in the new 2018 GRMN Yaris are exactly the same as the 2008 South African and New Zealand ZSP90. Looks like Toyota went and just dug through the parts bin. It should also be noted that all of those vehicles use a 6 speed transmission - 2008 models used an EC67.
Anyway I digress. Adam, I've read back through your thread and I couldn't see which drive shafts you used? Assuming the Yaris ones. Not sure what the exact differences are, but it may be also worth investigating the differences in the XD shaft lengths and whether that might also be a solution - just thinking if the 2zr rh mount has shifted the motor and box towards the left...
stidnam is offline   Reply With Quote
2zr, 2zr-fe, 3rd gen, t-sport
Toyota to Debut 2018 Yaris At New York; No Mention of Yaris GRMN Thirty-Nine General Yaris / Vitz Discussion 39 07-01-2017 11:38 PM
Went and looked at a yaris Sport! mr_miles General Yaris / Vitz Discussion 19 02-20-2012 10:28 AM
My UK Yaris T Sport Matty Photo-Video-Media Gallery 9 02-21-2010 07:04 PM
