Old 10-01-2011, 11:50 PM   #91
Hershey
Hmm interesting thing to do. But would it work if you changed the sealing washer? (also unecessary)
Torque wrench complete overkill for something like this however. Manual says something like "Torque the oil filter with a torque wrench. If you dont have one take it to your dealer for proper torque."
Just intimidating the public Im afraid. The bastards. Actually torqueing the OF to their spec will prolly result in it being nearly impossible to remove IME.
This method worked for the '08 YARIS 3 door w/ 5 speed manual . The permanent marker remained for a while . If I remember correctly , reused the washer from the factory . Would get a new one when doing a second change of gear oil .
Old 12-20-2011, 07:48 PM   #92
dan4yaris
Drives: 2007 yaris sedan 4dr
great DIY
Excellent DIY! Just be advised, when you are filling using the vinyl tube with the funnel the oil runs very slow so be patient!
Also, you must use a 24 mm socket, there is some metal on the way when you try to remove the drain bolt. I tried with a wrench it just did not work!
excellent pics to help locate plugs.
drain plug parallel to the drivers tire!
fill plug parallel to the front bumper!
dan4yaris is offline   Reply With Quote
Old 02-14-2012, 02:51 AM   #93
zondakaka
Drives: Yaris Sedan 2006
where can i find a similar guide for the cvt k410 transmission
zondakaka is offline   Reply With Quote
Old 04-08-2012, 05:59 PM   #94
Illryion
Drives: 2007 Yaris Hatchback
Just used this guide - Easy Peasy. Thanks Guys.
Illryion is offline   Reply With Quote
Old 04-09-2012, 12:57 PM   #95
CoryM
Drives: 2009 5-door, 5-speed
A suggestion to all owners, but specifically while doing this job:
Make sure your vent is clear as well. The transmission has a vent on it to allow for the expansion of the oil/air inside. Otherwise the seals have to deal with the pressure and will eventually fail. These vents often clog, and mine was plugged when I got the car with 38000km on it. A good indicator it is plugged is you will hear a hiss of air as you open the fill plug.
I can't recall exactly where the vent is on these cars. iirc it's just behind the shifter. A little white(?) plastic knob that you twist and wiggle a little to free up any junk.
I'll try to find a picture.
Cheers.
Old 04-09-2012, 01:38 PM   #96
CoryM
Pretty sure this is it. Grey metal cap I think.
Old 05-16-2012, 05:34 PM   #97
ijose 845
ijose 845's Avatar
Drives: 07 Toyota Yaris
Hey this is a great diy but I'm having difficulty finding the fill plug is it on the bottom front by the airbox or on the side?
Angry Bird Crew #1
ijose 845 is offline   Reply With Quote
Old 05-16-2012, 08:54 PM   #98
Em_
Drives: 2007 Yaris
i did it my self about 2 months ago
it's in the front as you look at the engine
Em_ is offline   Reply With Quote
Old 05-16-2012, 09:25 PM   #99
ijose 845
ijose 845's Avatar
okay thanks! im doing mine tommorow i just wanted to make sure i got everything mapped out before i do it llol
Angry Bird Crew #1
Old 05-16-2012, 10:42 PM   #100
Hershey
You using a torque wrench ? May want to mark one plug as F.P. ( filler plug ) .
Old 05-18-2012, 12:41 AM   #101
kyote
kyote's Avatar
Drives: 2007 liftback base
i didn't notice this thread until I already did the job, and apparently I over-torqued the nuts. i was assuming they were crush washers like on my honda. is this a problem?
also, my oil was very dirty at 26k.
kyote is offline   Reply With Quote
Old 05-18-2012, 07:40 AM   #102
ijose 845
ijose 845's Avatar
hey i did my gear oil change i added 2 quarts and nothing leaked out? im guessing it didnt it didnt need to level itself out? should i add more? or just leave it the way it is
Angry Bird Crew #1
Old 05-18-2012, 10:49 AM   #103
Hershey
The 2 qts. will be fine .
Old 08-03-2012, 09:45 PM   #104
dfhnpdx
Drives: 2009 yaris
Thanks, ttufrosty...This is how I will be spending my Saturday morn. Great DIY post...
dfhnpdx is offline   Reply With Quote
Old 01-02-2013, 09:45 PM   #105
The Spectacle
The Spectacle's Avatar
Drives: 08 BSP LB
Great DIY and I just want to give a few notes for anyone tackling this in the future.
- I didn't do this on my car until 75k. The fluid came looking brand new with no metal shavings. However, I was having some issues with the shifter being stubborn in cold weather, especially reverse. After the fluid change, the tranny shifts better than it did stock (as far as I remember)
- A lot of people are recommending Redline, Royal Purple and other exotic oils...you don't really need that stuff. I used Pennzoil Syncromesh out of Autozone for like $8 a quart and it like I said, it shifts better than it did brand new. For reference, here's what it looks like: http://pennzoil.com/other-car-produc...mission-fluid/
- The 24mm socket size for the fill plug was impossible to find in 1/4 inch. I ended up buying a 1/2 to 1/4 adapter to do the job.
- Buy whatever you need so you can do the fill from the top. I used a hand-actuated vacuum pump that I used to bleed brakes and it was a major PITA to do under the car. I did my best to put all 2qts in, but really as long as you can stick your finger in the fill hole (lol) and feel fluid, you've got enough in there.
The Spectacle is offline   Reply With Quote
Old 01-03-2013, 08:53 AM   #106
yaris2010RS
yaris2010RS's Avatar
To add^ its alot easier to fill the fluid from the reverse sensor port
Old 01-06-2013, 08:56 AM   #107
DeathBeard
DeathBeard's Avatar
Drives: 2010 Yaris S
Where is the reverse sensor plug located, seems like a less messy way than filling from the bottom? Can someone take a picture
"In his heart a man plans his course, but the Lord determines his steps."
Proverbs 16:9
DeathBeard is offline   Reply With Quote
Old 01-27-2013, 04:30 PM   #108
Fatty Lumps
Drives: 2007 Toyota Yaris
Just want to give a thank-you for the DIY. Made the job simple for me, faster than changing the oil.
I'm also interested curious about the reverse sensor fill method if anyone has a reference image?
Fatty Lumps is offline   Reply With Quote
Help with oil change specs autophile DIY / Maintenance / Service 31 04-25-2011 09:22 PM
Yaris Auto need help with tranny oil change chrisada_to2a General Yaris / Vitz Discussion 2 05-17-2007 01:51 PM
DIY Oil Change Bassmonkey DIY / Maintenance / Service 42 02-19-2007 08:37 PM
Oil change question Ryu DIY / Maintenance / Service 22 03-07-2006 11:21 PM
