Old 05-14-2013, 03:28 PM   #1
kou
Drives: 08 lb
If you need someone to test it in a forced induction setup send one my way for a couple of weeks.
Old 05-14-2013, 03:37 PM   #2
tooter
play every day
tooter's Avatar
Drives: 2012 Yaris L 2dr 5sp
Thanks for the offer, kou... but I only have one left and its already up for sale.
By the way, I found pics of the only others I know of.
normally aspirated...
...and forced induction.
I bet that turbo setup is a real screamer.
Old 05-14-2013, 05:45 PM   #3
JustDidIt
JustDidIt's Avatar
Drives: '08G2T Prius
Cool Stuff!
JustDidIt is offline   Reply With Quote
Old 05-16-2013, 10:50 AM   #4
Flipper_1938
Flipper_1938's Avatar
Drives: 2010 Yaris Sedan
How are you going to put the square peg in the round hole?
Old 05-16-2013, 03:28 PM   #5
3cyltrbo
Tooter
Thanks for your replies
Just so I understand (I'm slow)
You have a tooter instock that is made to accept the 1zz and its $450 shipped?
Thanks
Will
3cyltrbo is offline   Reply With Quote
Old 05-16-2013, 04:50 PM   #6
JustDidIt
JustDidIt's Avatar
Originally Posted by 3cyltrbo View Post
Tooter
Thanks
Will
http://www.ebay.com/itm/Toyota-Yaris...item2c6d36b28c
Old 05-16-2013, 09:55 PM   #7
tooter
play every day
tooter's Avatar
Tooter
Thanks
Will
Yes I do, Will.
This is the picture of the actual 1ZZ ready tooter manifold that's in stock for sale.
It's $495 on ebay only because of the added fees. From me directly, it's $450 including shipping.
Greg
greggabi@verizon.net
310-455-3340
Old 05-17-2013, 12:34 PM   #8
3cyltrbo
Originally Posted by tooter View Post
Yes I do, Will.
Greg
310-455-3340
Other than a 1ZZ TB which I have already, what else would I need that might not be included?
Old 05-16-2013, 10:16 PM   #9
tooter
play every day
tooter's Avatar
Only the round half goes into the round hole and is inside the plenum...
The square half sits on top of the hole on the outside of the plenum like the head of a rivet so as to hold the 1ZZ throttle body. The corners overhang on purpose so that it doesn't just fall through all the way. This will make welding really easy as it will rest exactly where it's supposed to be.
Old 05-17-2013, 07:18 AM   #10
Flipper_1938
Actually I was wondering about the "boob" to factory square intake flange.
Old 05-17-2013, 10:44 AM   #11
tooter
play every day
tooter's Avatar
I'm getting a round piece of aluminum plate and cutting a rounded square hole in it. The diameter of the plate will be slightly larger than the hemisphere so that it can sit on top of it, while the square hole will be slightly smaller than the factory runner retention flange to allow the plate to set on top of it.
After the welding, everything gets stainless steel bead blasted for a clean consistent uniform finish.
Old 05-17-2013, 12:12 PM   #12
47_MasoN_47
What I thought I'd do was
47_MasoN_47's Avatar
Drives: 09 Yaris Sedan
Wow, I hadn't checked on this thread in a while so I missed about 50 pages.
So, with this I could snag a 1zz tb and one of your adapters and be able to rock the 1zz on my Blitz setup?
How far do you think this would offset the intake? I've got an AFe and there's not a lot of extra room there.
Old 05-17-2013, 01:07 PM   #13
tooter
play every day
tooter's Avatar
It wouldn't offset it at all if the thickness of the adaptor matches what you cut off of the Blitz.
There's plenty of material to work with on the bottom round section. In fact if thickness became an issue, you could simply cut off the whole round section with a hack saw, and just use the square throttle body base part. You would want to flare out the smaller runner opening with a grinder for a smooth transition to the larger 55mm adaptor bore.
Old 05-17-2013, 01:09 PM   #14
47_MasoN_47
Oh I didn't realise that stuff had to be chopped off the Blitz part. Blarg, probably beyond what I'm willing to try haha.
Old 05-17-2013, 01:25 PM   #15
tooter
play every day
tooter's Avatar
Yeah... you'd need to want a 1ZZ on your Blitz really badly!
There's no other way to retain the same location of your intake without cutting and welding. And it would be a pain, because you'd need to remove the unit to cut it and take to to a welder. It would definitely an advanced project, but not a difficult one as aluminum is really soft and cuts and welds easily. One day someone with the mechanical skills will try a SC 1ZZ. I bet it would be an effing screamer because even running normally aspirated, the throttle response is truly amazing.
Old 05-22-2013, 10:07 AM   #16
3cyltrbo
PM'd
Cheers
Will
Old 05-22-2013, 01:17 PM   #17
tooter
play every day
tooter's Avatar
PM'd
Cheers
Will
Enjoy your tooter, Will.
Arrives on the 30th.
Greg
Old 05-22-2013, 11:31 AM   #18
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
This is on my to-do list once I get my A/F monitoring under control. I just got a set of 255 cc injectors and a scangauge II this morning and an injen CAI last week.
homemade intake manifold ttr125fan09 Performance Modifications 1 02-17-2012 01:09 AM
Custom Intake Manifold + Direct Port Nitrous blacksandiegovitz Performance Modifications 9 04-21-2010 07:05 PM
Turbo Manifold thread Sabretooth Forced Induction Forum 78 05-22-2009 06:52 AM
