Old 06-07-2013, 11:15 PM   #1
xnamerxx
0-60 in slow
xnamerxx's Avatar
Drives: light blue liftback
Originally Posted by Shinare View Post
^^^ RE: "long tube header" - Please forgive this noob question, it really is a question and not a troll, but why does it matter the length of a pipe? Don't you want the exhaust to just get out via the back of your car rather than in the engine bay?
Its about exhaust scavenging. At a certain length and diameter, the exhaust pulse will create a sonic negative pressure wave at the valve creating a vacuum. That vacuum helps pull up on piston, clear out the cylinder, and suck fresh air into the cylinder. The exhaust itself still exits in the original location in most situations. On most otto cycle engines exhaust contributes to about 5-15% of the engines theoretical performance potential, on 2 stroke engines it can be as much as 40%.
In my case I picked up 7hp and 6 tq over a DC header with the long tube header I designed.
Old 06-08-2013, 06:31 AM   #2
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
Is that design, by chance, available for the rest of us? I'm sure there's a thread, but I'm really lazy in the morning.
Old 06-08-2013, 09:40 PM   #3
xnamerxx
0-60 in slow
xnamerxx's Avatar
Nope, spent a bit too much time with it to show off.
Old 06-08-2013, 10:31 PM   #4
tooter
play every day
tooter's Avatar
Drives: 2012 Yaris L 2dr 5sp
Who could forget the freaking awesome sound of your dyno runs, namer?
http://www.youtube.com/watch?v=fpkgkDjwHVg
I thought of your project every time I saw these.
But like you said, they only adjust for attitude, but not for length.
Had you come up with any other ideas to resolve the issue of engine arc travel? You seemed to be so close to a functional product.
Old 06-07-2013, 01:37 PM   #5
Remove your header and see how much power you lose with no exhaust at all. A LOT.
Old 06-07-2013, 04:03 PM   #6
Yoda
Yoda's Avatar
Drives: 2008 Black Sedan
I can attest to that
Old 06-07-2013, 05:34 PM   #7
Shinare
Bronze bombshell yaris
Shinare's Avatar
Drives: 09 Yaris HB 3door
Well that's strange, I never would have guessed that would even affect the performance of a car. So exhaust pipes on the header make the engine work better rather than having nothing there to restrict... to me that's just really weird, hehe
Old 06-07-2013, 07:09 PM   #8
CrankyOldMan
It's all based on the Helmholtz principle, the Bernoulli effect and fluid velocity. Lots of crazy physics and maths to explain it, but not really relevant unless you're into that sort of thing. Here's my understanding of it: escaping exhaust pulses down each tube (Helmholtz), drawing a slight vacuum on the adjacent tubes (Bernoulli). Velocity and pressure of a fluid in a tube is decreased by increasing the diameter. Decreasing the pressure means easier flow, but lower velocity and less scavenging effect...I think.
Old 06-07-2013, 03:52 PM   #9
TOLMACH
Drives: soarer
^ That is his yaris
Old 06-07-2013, 10:48 PM   #10
TOUGEghost
Mr. Clean
TOUGEghost's Avatar
Drives: 2009 Yaris S 3-Door
Originally Posted by tooter View Post
Nice wheels!
Old 06-08-2013, 12:53 AM   #11
tooter
play every day
tooter's Avatar
Originally Posted by TOUGEghost View Post
Nice wheels!
Thanks,
They were the closest truck wheel match to the ones on our Yaris.
Old 06-07-2013, 10:59 PM   #12
^ he puts them on everything.
Old 06-08-2013, 07:37 AM   #13
malibuguy
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan
That header is georgeous. Do you have any pictures of inside the collector?
-Greg...the Exhaust Freak.
-82 Malibu, 1uzfe swap
-97 Tercel coupe, 1nzfe/4.31
-96 Tercel 4dr
Old 06-08-2013, 11:52 AM   #14
tooter
play every day
tooter's Avatar
Sorry, no. But the runners are as clean and neat on the inside as it they are on the outside. And I agree, it's an excellent example of the exquisite beauty of flow design, and I bought it solely because of its visual appeal.
Note the similarity?
Old 06-24-2013, 08:24 AM   #15
CrankyOldMan
So many Freudian themes in this project! I was wondering where the actual seam would be on the bellmouth--for some reason I was thinking you would put it all the way up to the squared shoulders.
Old 06-24-2013, 10:55 AM   #16
tooter
play every day
tooter's Avatar
That's right, Cranky. I had originally planned for it to drop all the way down to the square corners, but that makes the round part of the bellmouth drop below the contact surface of the hemisphere creating a gap. While the welder could easily fill that gap, I want to try to keep burn through to a minimum by retaining complete contact between the two surfaces so that the inside surface is not compromised.
It took a couple of hours of handwork to get the fit as precise as possible, and I'm totally satisfied with the results.
When I bead blast the whole assembly to normalize all of the surfaces, you'll hardly be able to see the seam even with no welding.
The raised square corners will end up working out nicely as the whole circle of the contact seam is easily accessible to be welded from the outside of the hemisphere. Exploring how to make the best of each detail in the design process is what makes this project no end of fun.
Old 06-24-2013, 09:58 AM   #17
It looks from the picture, that because of the angle, the throttle body points more directly at two runners, which are slightly further away. See your second picture above. It would be interesting to see a flow test for to see how much each runner is getting.
Old 06-24-2013, 11:05 AM   #18
tooter
play every day
tooter's Avatar
I know. The offset angled orientation of the throttle body axis in the original plenum was even more offset than the one I'm building. So I softened it slightly. If it wasn't an issue for Toyota, it isn't for me. I think it was done just to get the throttle body pointing slightly upwards to line up with the stock air filter box, so I did the same thing so as to line up with mine.
This is the original manifold throttle body axis orientation.
And this is the tooter et throttle body orientation.
This is why I don't believe that it was ever an issue. First because the flow is so direct, and second the runners are pulling from the plenum That's what I like most about this particular design. It completely eliminates the 90 degree "kink" runner to throttle body axis orientation found in all of the other typical plenum designs.
homemade intake manifold ttr125fan09 Performance Modifications 1 02-17-2012 01:09 AM
Custom Intake Manifold + Direct Port Nitrous blacksandiegovitz Performance Modifications 9 04-21-2010 07:05 PM
Turbo Manifold thread Sabretooth Forced Induction Forum 78 05-22-2009 06:52 AM
