Old 05-17-2007, 08:12 PM   #1
YamilR
YamilR's Avatar
Drives: Absolutely Red Liftback
Send a message via Yahoo to YamilR
Originally Posted by MrJester View Post
I would agree with that if only I could find a shop that sold them I have checked everywhere around here. Freakin newbie I thought that would be an easy tool to find.
Let me recommend a craftsman set, lifetime warranty is a must and you have all the tools that you need. No complaints here
http://www.sears.com/sr/javasr/produ...cemldffidfno.0
YamilR is offline
Old 05-17-2007, 09:53 PM   #2
Chris07LB
Chris07LB's Avatar
Drives: Yaris Liftback
Jester - you still need one? Ill send you one.
Chris07LB is offline
Old 05-17-2007, 10:17 PM   #3
churp
Clean and (dis)Functional
churp's Avatar
Drives: Yaris 2dr--Black Betty
I welded a rod onto the side (towards the top) of a cheap socket and it worked fine. Just gotta have a cheap welder!
____________
Old School Cobble Jockey
churp is offline
Old 05-18-2007, 04:59 PM   #4
MrJester
Drives: homo
I mean I could use one but I got my springs installed so I am good.
MrJester is offline
Old 05-31-2007, 09:31 AM   #5
nsmitchell
nsmitchell's Avatar
Hey Chris07LB, you should put in your required tool the Spring Compressor. If someone (complete noob) tries to do it without one, they will get one hell of a suprise and maybe a trip to the hospital. Just my 2 cents.
Get YarAss in gear!
RIP - Casey Tatum
nsmitchell is offline
Old 05-31-2007, 08:01 PM   #6
Chris07LB
Chris07LB's Avatar
You should read the DIY again.. its not only shown in the pics, but also mentioned a few times.
This is only a "guide" to help with the install/removel process.
Old 05-31-2007, 08:08 PM   #7
brickhardmeat
Lonesome Cowboy
brickhardmeat's Avatar
Drives: 2007 WHITE HATCHBACK
I think he's trying to call you a NOOB KILLER, Chris.
SPONSORED BY
brickhardmeat is offline
Old 05-31-2007, 08:56 PM   #8
Chris07LB
Chris07LB's Avatar
Old 06-05-2007, 10:53 PM   #9
nsmitchell
nsmitchell's Avatar
Holy Shit! These Megan springs are excellent. I just got finished installing them tonight (pics tromorrow) and I went to fix a friends computer. Coming home I went down a road that has been torn to crap, like a 2 foot wide ditch was dug in the middle and patched really crappy. With my regular OEM springs I could only take a few seconds of my right tires riding over that crappy patch job, but with these new ones, it was like budduh. I swear I could hardly feel them. The patch job goes on for like half a mile and I paid very close attention to the feel of the road and it was incredibly smooth feeling compare to the OEM springs. AWESOME!! Thanks Chris and BrickHard!!!
It dropped from 26.5" (measured from ground to fender) to a little under 25". 1.5" drop like they claimed. Looks real gooooood!
BTW - I went to sears and got one of these Craftsman 17 x 19mm Wrench, Deep Offset Box End for the top strut bolt. It works like a champ!
http://www.sears.com/sr/javasr/produ...seBVCookie=Yes
Get YarAss in gear!
RIP - Casey Tatum
Old 06-05-2007, 11:24 PM   #10
brickhardmeat
Lonesome Cowboy
Glad you are happy with the feel. I definately prefer a stiffer, shorter travel feel over that OEM stuff. Measure in a few weeks after they settle. Have you measured from the bottom of the hub center to the fender also? Not sure what tires you are on I'll check your garage. Churp says he didn't get quite the drop that Megan advertised but he seems very please with them also. Bet you like the look better without that huge gap.
anyway your measurements add up, cool
SPONSORED BY
Old 06-06-2007, 12:23 AM   #11
nsmitchell
nsmitchell's Avatar
These springs don't feel that stiff. I have not had them on the highway yet though. Going to work tomorrow on the crappy Cary St. in Richmond should reveal a lot about these. I am also getting an alignment ASAP! Like tomorrow if possible. I'm just amazed at how they soaked up that bumpy crappy road. I'm still in disbelief. I looked at the patches, and it was night time, but I don't think a crew has smoothed them out yet. I think the springs did! I recommend these to anyone who wants a smooth ride that looks cool too. Not necessarily Megan but anything besides OEM!
Get YarAss in gear!
RIP - Casey Tatum
Old 06-06-2007, 12:53 AM   #12
churp
churp's Avatar
Glad to here somone else finally put them on! I think they're great but have nothing to compare to besides stock....I think they're quite a bit stiffer than stock but softer than an RX7 I have, and have never bottomed out.
____________
churp is offline
Old 06-06-2007, 07:37 AM   #13
nsmitchell
nsmitchell's Avatar
Hmm.., mine feel supple. Takes bumps better, a lot better! Very Nice! High Five!
Get YarAss in gear!
RIP - Casey Tatum
Old 06-06-2007, 11:25 AM   #14
redyaris
Shiny Chromey Coolness
redyaris's Avatar
Where would one locate a 'spring compressor'? Im thinking of doing this mod. You've finally talked me into it. Can I rent one from AutoZone as a loaner tool?
And no, i'm not buying one as I will never use the freaking thing again!
redyaris is offline
Old 06-06-2007, 02:21 PM   #15
nsmitchell
nsmitchell's Avatar
Autozone will "loan" it to you by selling it to you and then refunding your ca$h when you return it. My spring compressors were brand new. I'm returning mine today. Also see of they have a deep offset 17mm wrench to "loan" to you. REALLY helps with getting the top nut off the strut. (hey, that rhymes!)
BTW - The only drawback to lowering I've seen is some rubbing on the inside of the wheel wells when hitting big bumps. But then again, what did I expect??
Get YarAss in gear!
RIP - Casey Tatum
Old 06-06-2007, 03:51 PM   #16
nsmitchell
nsmitchell's Avatar
I wonder if my bumpstops may be farting. Apparently you are supposed to line up the grooves to the holes... I may remove my struts and glue my bumpstops back together with Gorilla glue. Then make sure I line up the bumpstops correctly.
Get YarAss in gear!
RIP - Casey Tatum
Old 07-16-2007, 12:17 PM   #17
driver centric
I know right?
driver centric's Avatar
Drives: 07 Bayou LB
What does the noise sound like? I've noticed a weird noise coming from my driver side when the suspension is compressed and I didn't know there was any lining up to be done with the bump stops...this may be what I've been hearing too!
-Kev
07 Bayou Blue Liftback 5-spd manual
driver centric is offline
Old 07-16-2007, 01:49 PM   #18
Jerkratt
Jerkratt's Avatar
+1
"It hurts more when its wet"
Jerkratt is offline
Tanabe Strut Tower Bar Install & Review [pics!] Chris07LB Wheels, Tires and Suspension Forum sponsored by The Tire Rack 57 04-07-2022 07:46 AM
Springs - Tanabe DF210 or Tein S Tech andylai2k Wheels, Tires and Suspension Forum sponsored by The Tire Rack 9 06-10-2007 09:22 PM
Tanabe DF & Strutbar install mcdaddy DIY / Maintenance / Service 18 05-03-2007 09:57 PM
TANABE DF210 SPRINGS AVAILABLE!!! C2AUTOSPL Wheels, Tires and Suspension Forum sponsored by The Tire Rack 20 08-05-2006 12:28 AM
Spring Install Price redglare45 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 1 06-30-2006 08:32 PM
