#109 |
Drives: jdm wannabe yaris Join Date: Feb 2014
Hello everybody i missing a dimmer switch on my indonesian/thailand yaris 2012 5doors, i want to add tachometer on my yaris. Please help me :(
#110 |
The Asian market Yaris do not have the dimmer rheostat. You can either just use ignition switched power for the tachometer illumination wire of you can use the illumination wire on the radio.
#111 |
Problem, officer?
Drives: '06 Yaris 5DLB 1.5 Join Date: Oct 2010
My Thailand-spec Yaris uses electronic dimmer circuit built within the instrument cluster.
You have to toggle the trip button while having your lights on to access this function. |
#112 |
![]() Drives: Toyota Yaris 2007 Join Date: Jun 2014
Hi all. I'm planning to buy and mount a tachometer and water heat gauges on my Yaris 2007 Sedan. I've seen some loose wires and harnesses near the engin. These are unplugged . My yaris is number 2. It comes without RPM and Water heat Gauges. I bought it in Sultanate of Oman. My question is: does Yaris come with ready harnesses to plug and play my gauges? Otherwise, could you please show me how to mount them? What and where are the right wires located?
Thanks in advance Sent from my iPhone using Tapatalk |
#113 |
Drives: 06 hatch Join Date: Oct 2014
hey man i was wondering if you could tell me how to go about installing footwell led lights to be activated with a switch prefferably in the center console by the e-brake. i know you have to bypass the firewall somehow for power, but i have no idea how/where to do so. help would be greatly appreciated.
#114 |
![]() ![]() ![]() Drives: 2007 Yaris Hatch Join Date: Feb 2007
Where is the wire for the seat belt alarm?
#115 |
The driver's side one is under the driver's seat and then it goes under the center console directly to the SRS ECU. The passenger one is under the passenger seat and it goes to the Occupant Classification ECU and then that ECU communicates with the SRS ECU to relay the info.
What exactly are you looking to do with that wire?
#116 |
![]() Drives: Silver Yaris Sedan (4A) Join Date: Jul 2007
So does that mean if I want to steal a yaris like they do it in the movies I need to cut the yellow, pink and black wires and tap the yellow leads against the pink and black?
#117 |
![]() Drives: yaris sedan Join Date: Jan 2014
hi CTScott. where can i see the hotwire for parklights that is usually used in aftermarket alarms..when you press the lock/unlock button of alarm the parklight will blink once or twice.
#118 | |
http://www.yarisworld.com/forums/showthread.php?t=24860
#119 |
oh i see, but i already tried that wire. its not the wire for the parklights.
![]() i have owned my yaris since last year and until now theres no park light signal when i lock/unlock
#120 |
Post some pictures of the connector for your headlight switch.
#121 |
ok sir i'll post pic once i got home later
#122 |
![]() ![]() ![]() ![]() ![]() Drives: 2014 Yaris SE Join Date: Apr 2014
CTScott do you have a wiring diagram for the 3rd gen Yaris? In particular I'm interested in the body ECU and what wires go where.
#123 |
![]() ![]() ![]() ![]() Drives: Thndr cl metallic HB 3 drs '05 Join Date: Mar 2006
Im planning to add a gauge 2 cable for my amp on my new car from the battery, however, I'm not sure where is the right place to do so. Do I have to drill the firewall?
20 years... alive and kickin'!! ![]()
#124 |
There is no power feed inside the cabin that you can connect that large of a wire to. You can go through the large grommet that is behind the battery, rather than drilling the firewall.
#125 |
![]() Drives: Yaris 2008 Sedan Join Date: Apr 2012
Desperately looking for the 12v + reverse wire on the rear tail light
Looking to add power to an aftermarket backup camera. I've searched for over 3 hours for the location of this wire. Here's a picture of the connection for the left rear light assembly on my 2008 Yaris Sedan. Anyone know which wire?
The wires going into the rear lights are: purple, green, orange, white w/a black strip and light blue. Many many thanks! |
#126 |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 black yaris Join Date: Oct 2010
If nobody answers, you could get a test light and turn the key to accesories. With the hand brake up, you could just put it in reverse. Use a test light and back probe each wire. Record which ones have power. Then put it back into park and check again to see which one no longer has voltage. I can't look up the wire diagram right now while i am at work. CTScott would be the one to get the info to you the fastest.
-Derrick- "Racing is important to men who do it well. When you're racing... It's life. Anything that happens before or after, is just waiting." |
| DIY Cruise Control FAQ (2006-2010 Yaris) | CTScott | DIY / Maintenance / Service | 468 | 11-19-2024 04:45 PM |
| NEWS: TOYOTA REVEALS ALL-NEW YARIS SEDAN AT 2006 LOS ANGELES AUTO SHOW | VitzBoy | General Yaris / Vitz Discussion | 7 | 09-20-2023 08:50 AM |
| 2012 Yaris at SEMA | Jason@SportsCar | Third Gen Yaris General Discussion | 5 | 09-23-2013 04:55 AM |
| New Yaris race car | Jason@SportsCar | Tracking, Racing, Auto-X Forum | 83 | 11-01-2012 03:32 PM |
