Old 04-21-2009, 08:17 PM   #109
MGargano
Drives: 2009 Yaris Hatchback
Originally Posted by AlexNet0 View Post
^no, not unless you also capped the hoses.
lol no I used one of those barb couplers. I finally broke down and did the chip swap and coolant bypass. I have the gasket maker setting overnight and look forward to testing it out tomorrow morning.
MGargano is offline   Reply With Quote
Old 04-22-2009, 01:41 AM   #110
tk-421
tk-421's Avatar
Drives: 5D-07-LB
Good luck! Hope that gets that problem solved on your end.
I'm also considering capping the (now useless) tubes... What did you use for that?
Old 04-22-2009, 10:06 AM   #111
MGargano
Just a few inches of rubber tubing with a little brass plug on the end. I found the plug's at Lowe's in the same section as the barb union coupler.
Old 04-22-2009, 02:09 PM   #112
t0m4s
1NZ-FE
t0m4s's Avatar
Drives: Yaris Seddan 08
did everybody trim the OEM TB gasket to allow more air flow as t-sport did?
DC Sports Header, Vibrant Hi-Flow Cat, Round Magnaflow Muffler, Vibrant Tip, Dunlop Direzza 195/50 Rims 15", Injen Technologies Cold Air Intake, NST CR-Lite crank, waterpump & alternator pulleys, Tanabe NF210 Springs, NST SSK 1 & 2, NST Shifter Cable & Cage Bushing Kit, Nitto Engine Torque Damper
t0m4s is offline   Reply With Quote
Old 04-22-2009, 02:17 PM   #113
marcus
toyota
marcus's Avatar
Drives: 2007 Yaris RS Blazed
[QUOTE=jkuchta;275971]As far as I can tell, the TB is heated to give better fuel economy. Why a cold charge would cause those problems is beyond me.
im assuming the high rev on cold start is due to oil being cool has to warm up ..
Old 04-22-2009, 04:58 PM   #114
MGargano
No good so far. Oscillation is way worse at cold start up than before the chip swap and I got a CEL within 10 minutes of driving :(
Old 04-22-2009, 05:28 PM   #115
marcus
toyota
marcus's Avatar
darn it!!
Old 04-22-2009, 05:50 PM   #116
AlexNet0
AlexNet0's Avatar
Drives: '07 Yaris 3dr
its due to the open loop during warm up, a preset throttle position untill its warm and then it uses the sensors and activly adjusts it. the opening is 30 percent larger so the preset is automatically that much higher
Old 04-22-2009, 06:02 PM   #117
tk-421
tk-421's Avatar
Drives: 5D-07-LB
its due to the closed loop during warm up, a preset throttle position untill its warm and then it uses the sensors and activly adjusts it. the opening is 30 percent larger so the preset is automatically that much higher
Do you think that will have an impact on engine life and/or MPG in the end? I really like this mod, but I may not keep it if it's doing any damage...
Old 04-22-2009, 06:39 PM   #118
jkuchta
Drives: 2007 Yaris hatch (red)
I'm still getting 37-38mpg per tank with the 1ZZ TB...and I've had it on for nearly 1000 miles so far.
jkuchta is offline   Reply With Quote
Old 04-22-2009, 06:40 PM   #119
AlexNet0
AlexNet0's Avatar
Originally Posted by camelll View Post
I think you meant open loop during warm up.
lol yup *duh*
Old 04-23-2009, 12:24 AM   #120
MGargano
Unless someone can convince me otherwise, I'm putting the stock TB back on tomorrow. I can handle the CEL but the oscillation is a little scary. After the chip swap, it oscillates very heavily from 2k to 3k for almost 2 minutes.
Old 04-23-2009, 02:40 AM   #121
Yaris T-Sport.
Yaris T-Sport.'s Avatar
Drives: .
do this, put the stock TB back and drive it for over a week with out doing and or trying anything at all and then swap the chip back to 1zz and try it again, this helps your ecu to remember the normal setup, then give it a fresh try after that. it worked for me.
Yaris T-Sport. is offline   Reply With Quote
Old 04-23-2009, 07:40 AM   #122
yarstar
Drives: 2008 Absolute Red HB
I concur with T-Sport. Giving it a 2nd try made it work for me too.
35-38 mpg now for 3k miles with new TB. No issues at all, except high cold idle. I really think it's worth it.
AEM CAI, NST Pulleys/SSK, WR 4-2-1 Header, TRD axelback, R1 Concept Rotors, TRD Sway Bar, Nitto Rear Strut Bar, Cusco GT-Zero Coilovers, 1ZZ-FE 1.8L TB
yarstar is offline   Reply With Quote
Old 04-23-2009, 10:25 AM   #123
MGargano
I love the performance of the 1ZZ but the harsh oscillation is a killer. So I should reinstall the stock TB & chip for a week or so and then start over with the 1ZZ and chip swap?
Old 04-23-2009, 11:19 AM   #124
yarstar
That worked for me. You may be getting ocillation due to an air leak. Make sure you did the gasket maker correctly and really let it set up a long time (I let mine set up overnight). Check also the intake for leaks.
I pulled mine back off, waited a week, did the chip swap again, and re-installed and have had no probs since.
Old 04-23-2009, 11:20 AM   #125
MGargano
Originally Posted by yarstar View Post
That worked for me. You may be getting oscillation due to an air leak. Make sure you did the gasket maker correctly and really let it set up a long time (I let mine set up overnight). Check also the intake for leaks.
Thanks. I'll give that a try.
Old 04-23-2009, 11:45 AM   #126
mikenacarato
SIPNDEW
mikenacarato's Avatar
Drives: 15 STI
i just want to stress a point again. anyone who just did this mod you have to drive it for a good 2 days or so for the ecu to learn the now tb. it will oscillate bad until then.
1.8L Engine Swap, Possible? Yaris T-Sport Performance Modifications 4 05-06-2007 06:57 PM
swap for 2zz-ge???? yarisTOONR82 Performance Modifications 12 03-23-2007 07:15 PM
