Old 07-11-2013, 12:45 AM   #1
Originally Posted by rapev-8 View Post
do u have anymore?
Yes
Old 07-13-2013, 01:42 PM   #2
Jadijkstra2000
Drives: Toyota Yaris 2010
Do you have more? :)
Jadijkstra2000 is offline   Reply With Quote
Old 07-13-2013, 04:47 PM   #3
Yes
Old 07-14-2013, 04:19 AM   #4
Jadijkstra2000
Will it work on european Yaris 2010?
Old 07-16-2013, 10:13 PM   #5
My understanding is no, but a person from Germany recently ordered one from me, as he was told that it would work. I will let you know when I hear back from him.
Old 07-14-2013, 06:30 PM   #6
Hayabusaboy
Drives: 2007 white hatchback
Was reading thru a few treads, seems your saying that all yaris have the hard wiring from the factory, correct? I have a 07 hatchback auto trans. If all i need is this kit your selling i'd like to purchase one, if you still have some available. Pay pal ok? Thanks Bruce
Hayabusaboy is offline   Reply With Quote
Old 07-16-2013, 08:47 PM   #7
lanemeyer14
Drives: 08 base Hb
I'm interested in one as well if still available. Will be for an 08 liftback 5spd
lanemeyer14 is offline   Reply With Quote
Old 07-17-2013, 09:17 AM   #8
Jadijkstra2000
Number of the ECU is : 89661-0dd90
Hope it can work :) Would be nice
Old 07-18-2013, 05:57 PM   #9
Jadijkstra2000
It looks like the car already has the clutch switch installed, i cannot have it started when the clutch is not pressed... So i guess that one is installed...
Old 07-18-2013, 09:03 PM   #10
The cruise control clutch switch is different. The starting one requires the clutch to be pressed completely to trigger, where the cruise control one triggers as soon as the clutch switch is touched.
Old 07-21-2013, 08:01 AM   #11
Jadijkstra2000
ah alright, didn't know that, thanks :) are there ways to check if the car is prepared for cruise?
Old 07-21-2013, 12:13 PM   #12
The best test is to check the voltage on pin 40 of the A21 ECM connector (see my DIY below for that location). If there is 12 V on that pin with the ignition on, then cruise is present.
http://www.yarisworld.com/forums/showthread.php?t=33750
Old 07-23-2013, 10:35 AM   #13
Jadijkstra2000
Do I need to remove the A21 connector to do the test or leave it in place for testing?
Old 07-23-2013, 01:58 PM   #14
Leave it in place. You will need to pull the rubber plug if there is not a wire present, so you can stick a piece of wire in to take the measurement.
Old 07-28-2013, 12:50 PM   #15
Mommas Yaris
Drives: 2012
Just wondering if you have any of these left and if you do how much? If you do would you please comtact me though my email @ cgoretx@gmail.com
Mommas Yaris is offline   Reply With Quote
Old 07-28-2013, 08:35 PM   #16
email sent.
Old 08-20-2013, 12:20 AM   #17
xboxer
Drives: 2007 Yaris Liftback Auto
Same question as above, including the OEM Stalk CC Pin Kit, and Cruise Control Indicator Module. Please send PM. Thanks
xboxer is offline   Reply With Quote
Old 08-20-2013, 06:26 AM   #18
PM sent
Can we do this? (aka The DIY Cruise Control Thread) mrbond DIY / Maintenance / Service 502 07-22-2017 02:57 PM
This is pretty frikken stupid - Yaris '07 LB auto cruise control firemachine69 DIY / Maintenance / Service 10 07-20-2010 08:09 AM
