Old 04-19-2012, 08:25 PM   #1
Blown_xa
Blown_xa's Avatar
Drives: Scion xA
I seem to recall this situation with the FIC when our tuner tuned Scions a lot. if I remember correctly, it was one of two things..... The firmware used is not correct, or the FIC unit itself is faulty. I HIGHlY doubt the crank sensor took a crap.
Ptuning.com
Old 04-20-2012, 12:09 AM   #2
djgab101
djgab101's Avatar
Drives: toyota yaris
Wink
So wat ur saying is the my aem fic is fuked and there is nothing wrong with my crank sensor .. Probably have to send it from where I got it to maybe get it check out I got it as a present friends all put money together and brought it for me
djgab101 is offline   Reply With Quote
Old 04-20-2012, 10:05 AM   #3
^No. What he is suggesting is that it might need a firmware update to a different version, maybe even a previous version. I would certainly try that before deciding the unit itself is toast.
Old 04-20-2012, 12:37 PM   #4
Focus_Sh1ft
Focus_Sh1ft's Avatar
.z107 is the accepted firmware for toyotas / scions.
Old 04-24-2012, 06:39 AM   #5
djgab101
djgab101's Avatar
if that is the excpeted fireware i am using currently the F/IC - 6 Patch V3.05
where do u find the z.107???
Old 04-24-2012, 10:16 AM   #6
Yoda
Yoda's Avatar
Drives: 2008 Black Sedan
Check the aem forums they have it on there. Don't kno why you are having some many issues. It must be in the tuning somewhere I think. Most of us are running open loop with no o2 sensor.
Old 04-24-2012, 11:24 AM   #7
djgab101
djgab101's Avatar
well tuning is going shit so i probably say tunning is the issue!
Old 04-20-2012, 01:32 PM   #8
Yoda
Yoda's Avatar
^^^^This
Old 04-21-2012, 02:29 AM   #9
djgab101
djgab101's Avatar
alright thanks alot guys i will double check that with the guys !!!
Old 04-24-2012, 04:01 AM   #10
djgab101
djgab101's Avatar
okay guys getting my car tomorrow morning.. but not happy
speaking to the guy my o2 oxygen sensors the heating element inside both the o2 sensors keep short circuiting which means when my car is cold it will run crap cause it wont be getting information! They brought me two new ones and after they dyno'd it both sensors heating element have short circuited again! thats my first fuking problem
secondly my car will get up 5000rpm and will hit a dead wall! according to the guy he says it a conflict between aem fic and the ecu, could the problem be that the car timing is off at high rpm possibly? Which isnt properly done in the ignition section of the aem?
why is it that my yaris has major issues while other yaris members arent seeming to have as bad of issues as i am! i have a feeling that the boomslang i have maybe isnt the same wiring as the yaris in america!
he said that the afr on WOT is 12:1 which i still need to install my AFR gauage in
anyone give me any input i have no idea wat the fuk is going on!? i dont understand the point of having a boosted yaris if u can even have the full rev range
Old 04-24-2012, 10:33 AM   #11
Maybe you should ask your tuner that.
Did they give you the old parts to inspect?
RULE #1: Always get back any parts replaced on your car.
Old 04-24-2012, 11:23 AM   #12
djgab101
djgab101's Avatar
my tuner has no idea!! he says its conflict between aem and ecu
going tomorrow i will ask him!
Old 04-25-2012, 06:43 AM   #13
djgab101
djgab101's Avatar
Alright got my car back runs well Only problem is a constant cranksensor mulfaction and both exhaust sensor heat circuit
The 2 oxygen sensors both the heat element inside have broken which where brand new so the car has to warm up the o2 sensor
The car still hits a brick wall at 5000rpm but reading aem forums they have see this before I am going to try tonight and fix that problem that's to you guys and aem i think it's the firmware which I hope should fix it more to update!
Btw garm I asked for parts and he apparently couldn't find them which is bullshit! He probably has them in the garage!
Old 04-25-2012, 08:11 AM   #14
Blown_xa
Blown_xa's Avatar
Drives: Scion xA
I think hitting the brick wall a 5000rpm is probably the MAF voltage not being clamped. Feels like an early rev limiter yes? Did somebody wire in the FIC, or did you get the plug and play harness?
Ptuning.com
Old 04-25-2012, 08:38 AM   #15
djgab101
djgab101's Avatar
the maf hasnt been clamped which i was trying to solve how to do it and still unsure??? the aem is using the plug and play harness!
Old 04-25-2012, 11:39 AM   #16
1. No. The tuner is the issue.
2. See #1.
Old 04-25-2012, 01:35 PM   #17
Focus_Sh1ft
That's the version of the software you're running on your computer, not the firmware running on the FIC itself.
Your tuner is a moron.
I believe every person that has used the boomslang has had issues with a crank related CEL
Old 04-25-2012, 10:28 PM   #18
djgab101
djgab101's Avatar
good to know i am not the only one!
List of Boosted Yarisworld Members whooppee777 Forced Induction Forum 262 11-23-2022 05:49 AM
Boosted Yaris Quarter Mile Times 1.5 Forced Induction Forum 0 01-03-2010 05:49 PM
Yari Boosted, Enge lite... N3misiS Forced Induction Forum 14 11-20-2009 07:22 AM
Going Boosted FryGuy Forced Induction Forum 53 03-01-2009 10:01 PM
PE Boosted Yaris Video jinxor Forced Induction Forum 16 02-06-2009 02:33 AM
