Old 06-24-2012, 02:14 PM   #1
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
It would be nice if you would be willing to provide all dimensions for that Blox setup. It could be a great component depending on physical dimensions for my turbo installation especially if they provide the type of air flow performance that is touted.
Old 06-24-2012, 03:54 PM   #2
tooter
play every day
tooter's Avatar
Drives: 2012 Yaris L 2dr 5sp
Sure. Be happy to. It arrives this Thursday the 28th. From the installation pics I've seen, a lot of them are turbos like this for example.
Old 06-24-2012, 08:44 PM   #3
Golddeenoh
Takes corners too fast!
Golddeenoh's Avatar
I was experimenting a few years ago with the Spectre Filters (inward facing cone/ no oil) that you get from Advanced Auto Parts and the short period of time that it was on there it sounded really mean. I don't Know how much better it would sound with my AEM cold Air intake but I might try it out again(this time with a real Intake pipe to connect to). It sounded like it rev'd up higher and louder when I had tried it out but that could have just been the sound it made and not what it actually did. I don't know what the feeling to these filter are but It may be cheaper or an easy replacement for future use.
Old 06-24-2012, 09:46 PM   #4
tooter
play every day
tooter's Avatar
That's a really good design because it has at least another third more filter surface area on the inside. They're an oiled filter, and come in 3, 3.5, and 4 inch openings so some adaption would be needed to make them fit a yaris intake tube.
I had a go on the manifold with some sandpaper just to see how well the surfaces would clean up...
Not too bad as a raw finish, except up close there are too many little pits, nicks, and flaws, so it will likely end up being painted.
Old 06-26-2012, 10:14 PM   #5
malibuguy
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan
Damn i thought you got the SecretWeapon intake. I really like the SW filter. The dragon is good stuff...just not my style.
-Greg...the Exhaust Freak.
-82 Malibu, 1uzfe swap
-97 Tercel coupe, 1nzfe/4.31
-96 Tercel 4dr
Old 06-27-2012, 12:00 AM   #6
tooter
play every day
tooter's Avatar
No problem, guy...
I figured that, because it's certainly not my style either. I was just bought it for the intake tube. The Dragon is the cheapest one and uses exactly the same intake as the Secret Weapon which costs $40 more. So I spent that money on the BLOX velocity stack dry filter instead. Putting them together makes a really neato intake for $224.
I'll post some pics when I put the parts together.
Old 06-26-2012, 11:18 PM   #7
or powdercoated, or even better yet, ceramic coated. Good cheap place in LA for that.
Old 06-27-2012, 12:31 AM   #8
tooter
play every day
tooter's Avatar
Hey Garm,
I knew nothing about Ceramic coatings and needed to go read up on it. Some coating businesses recommended not doing it on old aluminium because of the 1,300degree high heat. They mentioned the possibility of warping and the metal outgassing. One auto forum poster warned not to coat the inside of intake manifold runners in case any of the coating was to flake and get run through the engine.
Has your ceramic experience been different? Are there any advantages? Any drawbacks that you know about? I have no idea if what I'm reading on the internet is true or not. But since I don't want to take any unnecessary chances, its more likely I'll go with powdercoating as it sounds safer. The manifold is only exposed to mild tempratures anyways so maybe ceramic isn't necessary.
Old 06-28-2012, 05:31 PM   #9
07typeS
07typeS's Avatar
Drives: 2007 White Toyota Yaris Type S
Send a message via AIM to 07typeS
daaaannnggg thats a big filter haha. I know you said the diamter is 7.5 inches, whats the length? Looks to be fairly close to the diamter measurement..
TRD Springs w/ KYB Struts and Shocks, Custom CAI w/ K&N filter and pre filter wrap, Weapon R Header, Stock 15 inch alloys, Dezod Performance pads, Tanabe Front Strut Bar, 35% front door Tint and 20% Rear doors back Tint, De-Badged Ass, Custom painted flat black interior, Pioneer deh-p6700bt w/ IPOD hookup, Infinity components up front with custom mounted tweeter, Inifinity 6x9's out back, 1 12" kicker comp cvr........
07typeS is offline   Reply With Quote
Old 06-28-2012, 07:06 PM   #10
tooter
play every day
tooter's Avatar
Yeah, it's a big ass filter all right!
It's 7 inches long. I discovered that this filter is exactly the same one used on the big 4 inch intakes, which I think is great. If it has the flow capacity to handle a 4 inch intake, it'll flow really good on a 2.5.
I really like the fact that the BLOX is a dry element filter so I don't need to mess with oil. Besides costing a lot more, it was why I didn't get the K&N Typhoon short ram kit.
And the fact that the velocity stack outer diameters are 6 inches regardless of throat diameter, it makes this particular stack really large with such a small 2.5 inch throat on it.
Right now, I'm cutting the intake pipe little by little until the whole assembly is short enough to fit. It won't take much, likely about an inch all totaled. The diameter is totally fine as the stock airbox is fat. Man, does it fill up that space!.
Old 06-28-2012, 07:20 PM   #11
fnkngrv
fnkngrv's Avatar
well for my purposes with my current turbo setup that filter wouldn't work :( It is MUCH too big. I was rubbing on my harness with the K&N 6" just co clear my hood. Wonder how much of an issue it would be to use my AFE Pro Dry and retrofit it on?
Old 06-29-2012, 01:05 AM   #12
tooter
play every day
tooter's Avatar
I don't think a 6 inch filter will work, as just the diameter of the velocity stack alone is already 6 inches...
I got the filter on this evening... and ended cutting about 4 inches off the intake pipe so now it's a really short ram intake...
Drove it to town to gas up and reset the mileage. I don't think it actually made any big difference but I've only driven it just a few miles. I had expected there to be some intake noise, but it's pleasantly quiet. I'm not sure, but it might be because of the really smooth direct flow pattern, or maybe because the filter is so large. Overall, I'm pleased how it turned out, a simple direct almost straight true velocity stack short ram intake that flows well. The car runs great, and no check engine light...
...and it looks really COOL.
Old 06-29-2012, 02:52 PM   #13
tooter
play every day
tooter's Avatar
With the intake completed, and over 1,000 miles on the engine, the car is ready for a baseline dyno this coming week...
It will be done with:
Weapon R short ram intake with BLOX velocity stack air filter
Weapon R 4-2-1 tri-y header
Micro Image MagnaFlow Center Exit exhaust
Old 06-29-2012, 04:06 PM   #14
BEEF
BEEF's Avatar
Drives: 2008 yaris 3d
that filter is huge in the engine compartment. it does look nice and filled though. a lot of the aftermarket intakes make it look like there is something missing there.
can't wait to see your baseline numbers. how is the actual intake manifold coming along? any pics of its progress?
Old 06-29-2012, 04:16 PM   #15
tooter
play every day
tooter's Avatar
With that way oversized filter, it's almost like having an open intake because there's hardly any flow restriction. I'm still suprized at how super quiet it is. There's almost no difference in sound from the stock air box.
My two week timeline was wildly optimistic...
They have all the aluminium stock and the 3D drawings are still being worked on. One of the guys is in the hospital for an appendix operation, so the project got held up while he recovers. I'll be there next week to go over the computer drawings with them before machining begins.
Old 06-29-2012, 05:08 PM   #16
tk-421
tk-421's Avatar
Drives: 5D-07-LB
That cone filter fills that space really well.
Still got an OEM throttle body? You may want to swap it out for a compatible one that is perhaps less restrictive... 2¢
Old 06-29-2012, 06:34 PM   #17
tooter
play every day
tooter's Avatar
I'm happy with the stock one as I'm more of an economy driver than a high performance guy. Although it's lots of fun experimenting with flow design, both my wife and I basically drive the car like it's stock.
Old 06-29-2012, 08:06 PM   #18
tk-421
tk-421's Avatar
Drives: 5D-07-LB
Something tells me the newly added growl will inexplicably make your feet heavier...
Your setup is very close to what I want to do with my car, so you bet I'll be watching that dyno chart very closely regardless of our different driving style/conditions.
homemade intake manifold ttr125fan09 Performance Modifications 1 02-17-2012 01:09 AM
Custom Intake Manifold + Direct Port Nitrous blacksandiegovitz Performance Modifications 9 04-21-2010 07:05 PM
Turbo Manifold thread Sabretooth Forced Induction Forum 78 05-22-2009 06:52 AM
