Old 01-13-2015, 05:25 PM   #109
Eduardo_mty
can i use this switch on my 2015 yaris
Eduardo_mty is offline   Reply With Quote
Old 03-21-2015, 06:56 PM   #110
Portugal329
Drives: 2009 Yaris Sedan
So the red and white wire is coming from the aftermarket switch is this correct?
Originally Posted by docvirus25 View Post
For those who are installing the aftermarket fog lamps without a factory stalk, you can apply 12vdc tapped from the aftermarket switch and plugged into the fog lamp relay hole underneath the dashboard. Connect to the hole indicated by the green arrow using a spade connector.
Hope this helps all of you out there. Cheers!
Portugal329 is offline   Reply With Quote
Old 04-20-2015, 04:45 PM   #111
M4One
Drives: 2007 Toyota Yaris Hatchback
When I was trying to install my fog lights on my 2007 hatch a long time ago, I remember CTScott saying something like how installing them this way was a bad idea because it could screw with the fuel pump or something like that. Has anyone run into any trouble?
I did get my lights working by going through the firewall, which was a pain, and connecting by this method, without connecting to the outside fuse. Something happened and then they did not work anymore and I really didn't have time to try to fix it until now.
I'm looking to start fresh and was wondering if anyone could recommend a good kit that is pretty easy to install. I don't plan on installing the stock. I also have a denso relay from my first attempt.
M4One is offline   Reply With Quote
Old 04-21-2015, 11:07 AM   #112
invader166
Pumpman
Drives: 2019 Kia Soul EV Base
Honestly, one of the best kits would be the micro-image one. It's a shame the're they've closed shop. I was lucky enough to get my hands on one for my '09.
That kit had you plugging the fog lights into a connector in the engine bay fuse box, rather than running a separate wire through the firewall.
Not only that, but it would also illuminate the indicator light in the instrument cluster.
Old 04-22-2015, 05:37 PM   #113
M4One
Do you remember the name of the kit so I could try and find it online.
Old 04-22-2015, 06:06 PM   #114
The Micro Image kit was a custom kit of their own.
Old 07-12-2022, 03:48 PM   #115
sh0rtlife
its a shame the pics in this are SHOT...anyone got a shot of the connection point to the engine side of the firewall fuse box?...its my only missing link at this point
Old 02-19-2023, 07:01 PM   #116
snipes
Drives: 2008 4 door hatchback
I'm not 100% sure what you mean but the attached might help. It's from CTScott on here.
Late post but might help someone else.
File Type: pdf Yaris 2006+ Remote Start Wiring Guide.pdf (598.5 KB, 16 views)
snipes is offline   Reply With Quote
Fog light install 07yaris_fe Cosmetic Modifications (Exterior/Interior) 10 07-20-2010 01:18 PM
Looking for the Toyota Fog Light install RocknRollRon DIY / Maintenance / Service 33 06-13-2010 06:46 PM
DIY:Day time running light Disabled with stock fog light remain function summergxz DIY / Maintenance / Service 12 09-26-2007 10:42 AM
Before I start calling around: fog light install prices St_G Cosmetic Modifications (Exterior/Interior) 4 03-17-2007 09:45 AM
Finally installed oem ebay fog light for hatchback Adriaan General Yaris / Vitz Discussion 6 12-27-2006 04:24 PM
