#1369 |
A-pillar update!
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() D.
. CLA 250, 4MATIC |
#1370 |
I connected my I-Touch for the first time ina while, for some reason it sounded better than my regular MP3 player, i hardly put cd's in anymore although CD's give you far better sound. I need to find a good program that will convert audio files without losing alot of SQ.
Maybe somebody can chime in. Congrats on the i Pad ! One question if you play a movie on the i Pad will you get surround sound straight off the USB or would you have to run an Audio / video cable like this ?
![]() ![]() Audio is under Construction Kenwood KDC-X794 Hifonics Zeus ZXI6.5C 6.5-Inch 2-Way Component Speaker System - AUTOTEK ATX65CX 6.5-Inch Hifonics BXi 1210D - Crunch PowerZone P1400.4 (2)12 inch Kicker CVR's - 0 gauge from battery to Distribution block - 4 Gauge Power/Grounds to amps - Duralast Yellow Top - Big 3 |
#1371 |
Roadrunner Jr.
Music file conversion? Goldwave.
“To argue with a person who has renounced the use of reason is like administering medicine to the dead.” ― Thomas Paine |
#1372 | |
D.
. CLA 250, 4MATIC |
#1373 |
Roadrunner Jr.
Hey D,
How do you have the thread-serts installed in the baffle for the mids? Just screwed in?
#1374 | |
![]() D.
. CLA 250, 4MATIC |
#1375 |
Roadrunner Jr.
#1376 | |
1.- mark precisely all 4 holes. 2.- use a tiny drill bit to center the thread-serts 3.- use a bigger drill bit but still smaller than the thread sert 4.- screw in the thread sert 5.- unscrew the tread sert 6.- apply CA + accelerator into the MDF hole 7.- re-screw thread sert 8.- apply CA + accelerator to the outside of the thread sert I know, maybe sounds complicated but the rings for the HL-70s don't leave space for errors/mistakes, it's just to small. Like you can see in the photos the thread serts exposed on one side... final en result... rock solid. ![]() ![]() ![]() D.
. CLA 250, 4MATIC |
#1377 |
Today I test fit the a-pillars... like a glove! fit is perfect!
D.
. CLA 250, 4MATIC |
#1378 |
My brother came to visit us, I took him for a ride on my Yaris, well I gave him the keys for the ride of his life! and this is what happen later:
We start pulling out the drive way and a couple of blocks away he tells me "This is a very quiet car, feels very solid and I can barely hear or feel the engine" He has a 2008 Subaru Legacy. Then I turn on the P-99 (no a-pillars, no Mids, tweeters on cup-holders) and he was speech less... then I explained to him about Time Alignment, front stage... and he was thrilled! I told him how much better the sound is when the Mids are in action. He just couldn't believe it. Another point for the Yaris and one more day of making me feel good about it... all this work and time on my car. Makes me feel proud of my self. (o: D.
. CLA 250, 4MATIC |
#1379 |
Congrats bro !
#1380 |
Roadrunner Jr.
I was hoping you CA'd those thread-serts in.
good news on the test drive!
#1381 | |
got used to it when building r/c airplanes. ![]() ![]() D.
. CLA 250, 4MATIC |
#1382 |
Roadrunner Jr.
More spurring for D to follow:
![]() ![]() ...Of course I didn't take the opportunity to take a picture with the grills over the speakers. What I have to do now is to find a NON-stainless steel machine screw (preferably a flat headed security type screw) so that I only need to use magnets on the grill's underside to attach them to the kick. That'll probably happen sometime this week or early next. What should be noted about these grills is that these are for daily driving and use. I have some "show" grills being made right now. I'll place those on...during shows obviously. These that are made above are a little bit of router work, some sanding, painting, stapling, and gluing. It's a fun afternoon project really.
#1383 | |
D.
. CLA 250, 4MATIC |
#1384 |
Roadrunner Jr.
The back huh?
You're trying to see if I have them open like the last pods? If that's the case, no I don't. I've got the opening on the bottom that leads down into/through the subframe holes in the floorboard. ![]() ^This is actually the side of the pod. I can tell because the little hole right there is used to bolt the pod into the car where the wiring bundles behind the kicks go. It doesn't look like I have any direct pics of the back. I can take some if you'd like. ![]() ^You can see the hole I was referring to through the grill cloth... ![]() ^There's also this one too... You can see with that last one that the pod's glassing is VERY thick. When you rap or knock on the pod, it's pretty much a dead thud or impact. It's not hollow at all. I'd liken it to the same sound when you hit a stone wall. There's just THAT sound...that nope, it's not moving sound. All the interior and edges of said interior of the pods have been coated with long hair. It's simply rock solid. I'd estimate that each of the kicks unloaded weights at least 10 lbs.
#1385 |
Very nice Sqcomp,
Has HAT come up with a formula to calculate the area for venting? when I did my first pods (Spheres) some one at DIYMA wrote that the vents should be at least 1/3 of the cone area, what are the Legatia's cooking recipe for this scenario? D. Ps... why did you do only 1 pair of kick panels? lol
. CLA 250, 4MATIC |
#1386 |
Roadrunner Jr.
Why only one pair of Yaris kicks? No one else has the nuts to do kicks like me.
![]() He he...J/K D!
| sound deadening: sq footage amount for 3dr | goku87 | In Car Entertainment + Electronics (audio / video / alarm) | 29 | 11-14-2013 12:37 PM |
| 2007 Yaris S Sound Deadening | sqcomp | In Car Entertainment + Electronics (audio / video / alarm) | 70 | 12-13-2010 07:40 PM |
| Sound deadening | 06vitzRS | General Yaris / Vitz Discussion | 10 | 05-05-2010 01:51 PM |
| Sedan Door Panel Deadening | sqcomp | In Car Entertainment + Electronics (audio / video / alarm) | 42 | 06-01-2009 02:47 PM |
