Old 07-15-2011, 12:39 AM   #1387
derickveliz2
derickveliz2's Avatar
Drives: Yaris Sedan "S"
Why only one pair of Yaris kicks? No one else has the nuts to do kicks like me.
He he...J/K D!
Just because I really want a woofer up front, I'm putting my Lows at the doors OEM location, other wise kick panels is the way to go.
tell us a little bit why you went from a pair of L8 down to L6SE? I know down size sometimes it's good.
D.
CLA 250, 4MATIC
Old 07-15-2011, 07:18 PM   #1388
sqcomp
Roadrunner Jr.
sqcomp's Avatar
Well, the L8SE's are massive. I'd say they're suited more for the space available in a truck versus a sub compact like ours. Take for example:
versus
Why? Isn't there no replacement for displacement? Yes and no. In this case, I would be starving the L8SE's for airspace. It would be like putting a turbocharger on our engine without upgrading the injectors. More air needs more fuel. Recall that both these speakers like to run IB. Well, I'm closer to an IB setup with the L6SE given that I'm in the same general airspace perhaps a little bigger with the smaller speaker and the same "vent" through the bottom.
I do lose 1 mm of Xmax and the cone area. But really? I have HUGE power available. More power than I'll ever need.
Working with that logic, I'm interested to hear these things sing here in a couple weeks.
― Thomas Paine
Old 07-15-2011, 07:29 PM   #1389
sqcomp
Roadrunner Jr.
sqcomp's Avatar
Oh...we got the rack frame up:
I know it doesn't look like much, but that board is the space of just the two amplifiers. RAWR!!!!!
The S4b will be on the cabin side of that framed board.
The Bit One will be under the passenger's seat in a little protective cover. Tonight I'll be heading to the shop to start fleecing for the sub enclosure and carpeting the amp board. Hopefully I'll be able to start the cover for the Bit One as well.
― Thomas Paine
Old 07-16-2011, 07:31 AM   #1390
derickveliz2
Question
Well, the L8SE's are massive. I'd say they're suited more for the space available in a truck versus a sub compact like ours.Recall that both these speakers like to run IB. Well, I'm closer to an IB setup with the L6SE given that I'm in the same general airspace perhaps a little bigger with the smaller speaker and the same "vent" through the bottom.
Agree 100%, sounds very clever.
On the passengers side... how are you venting the L6SE's? to the floor like on Pilot's side? or in that vertical cavity towards the wheel well?
D.
CLA 250, 4MATIC
Old 07-16-2011, 08:35 PM   #1391
sqcomp
Roadrunner Jr.
sqcomp's Avatar
I'm venting them the same way as the driver's side. We do have the option of also using the vertical cavity as well. If I feel that my mid bass is choking, I'll open up the sides.
― Thomas Paine
Old 07-17-2011, 01:19 AM   #1392
derickveliz2
I'm so tired of sanding, and the a-pillars don't even look close to finish )o:
D.
CLA 250, 4MATIC
Old 07-17-2011, 11:06 AM   #1393
sqcomp
Roadrunner Jr.
sqcomp's Avatar
Pics...
...and yes, that mid-pillar burn out will happen. You think mine just appeared "perfect"? Feel my sacrifice and sanding pain. :) Why do you think a good shop wil charge so much for custom work like that? Time, time, and more time.
― Thomas Paine
Old 07-17-2011, 03:04 PM   #1394
sickpuppy1
Drives: 2010 Yaris Sedan
D, and when your done, and their in you'll say, F yes! I did that! and when people ask who did them for you or if you did them yourself, your gonna be so proud.Its worth it in the end.......just getting to the end that sucks,lol
Bet.....when there in and set up you get this giddy little sentimental chuckle inside....
Old 07-17-2011, 05:59 PM   #1395
sqcomp
Roadrunner Jr.
sqcomp's Avatar
^ I'll second that! This is YOUR work. This is something YOU should feel proud of. If you need help, let me know. I'd say send the pillars to me and I'd finish them...BUT...they need to be YOUR pillars.
― Thomas Paine
Old 07-18-2011, 12:39 AM   #1396
derickveliz2
Exclamation
Pics...
Here are some pictures of the a-pillars WIP...
D.
CLA 250, 4MATIC
Old 07-18-2011, 12:43 AM   #1397
derickveliz2
Thumbs up
Thanks guys!
I'm sure going to feel proud and sore! jeje
Here is something I don't need to sand! AKA 175watts x 2 for my L6's
D.
CLA 250, 4MATIC
Old 07-18-2011, 12:45 AM   #1398
derickveliz2
I started with the soft filler that I used on the spheres to cover the really small uneven surfaces, tomorrow I suspect more sanding...
(o:
D.
CLA 250, 4MATIC
Old 07-18-2011, 10:33 AM   #1399
sqcomp
Roadrunner Jr.
sqcomp's Avatar
He he! You know my quest...POWER! You've upgraded your grounds and the alty to battery, right?
Now...to the pillars.
How's the transition between the filler and the plastic? Is it smooth? Truly? I had to bring that line up a bit more than you have yours. The red marks are to bring attention to spots that you need to work on?
― Thomas Paine
Old 07-18-2011, 10:36 PM   #1400
sqcomp
Roadrunner Jr.
sqcomp's Avatar
More spurring for you D...Get crackin' on your $hit!
^The speakers are back in...
― Thomas Paine
Old 07-18-2011, 11:13 PM   #1401
derickveliz2
Arrow
Yes I did a Big 3, you help me do it! LOL
Transition it's smooth, of course it can get better (it will), I'm concern on how to finish them... Primer, texture, paint or flock?
Yes the red marks are from a previous Bondo/Sanding in my attempt to fill valleys and little imperfections.
D.
CLA 250, 4MATIC
Old 07-18-2011, 11:41 PM   #1402
derickveliz2
Exclamation
Thinking about the power...
At 40MPH - under 2,000 RPMs - fifth gear - flat road - Lights on - AC cranking full power - HU on at max volume - Spanish pop music playing - =
13.8 volts according to the P99s volt meter.
CLA 250, 4MATIC
Old 07-18-2011, 11:52 PM   #1403
derickveliz2
Thumbs up
That's a very strange spare tire... LOL
The L4SE's have a nice sexy BUTT.
Mmm... you still need front and rear spoiler, ground effects, eye lids, front grill, shark fin antenna (fake), allow wheels, Lowering springs, SSK, etc ... JKD . (o:
I know your install is much fancier and nicer than mine, but I'll let you have the best sound system on a Yaris! on that side of the continent! jeje and I forgot... RED looks faster!
D.
CLA 250, 4MATIC
Old 07-19-2011, 01:12 AM   #1404
derickveliz2
Talking
It's hot and humid down stairs!
I did sand last night glaze coat! easier to sand than bondo, after 3 layers of bondo I'm done with bondo!
added another layer of glaze so I have something to sand tomorrow. Every layer makes the a-pillar look better.
D.
CLA 250, 4MATIC
