Old 01-23-2010, 12:58 PM   #1
lowsushi
Akiba Otaku
lowsushi's Avatar
Drives: 2010 Yaris 5dr
Send a message via AIM to lowsushi Send a message via Yahoo to lowsushi
yeah I know, just wanted to make it easier. dont think I will get around to installing my lowered shocks this week anyway with this rain. My garage just soaks up the water. I can hardly keep it up with out putting weights on the otherside to balance it out. Up to 40lbs now. I would hate for a weight to fall on the Yaris.
PS3 Trophies
lowsushi is offline   Reply With Quote
Old 01-23-2010, 10:46 PM   #2
CtrlAltDefeat
I ♥ Yaris
CtrlAltDefeat's Avatar
You have to weigh down your garage when it rains?
Old 01-24-2010, 08:48 AM   #3
lowsushi
Akiba Otaku
lowsushi's Avatar
To keep the garage door open I need to counter-balance the weight of the rain soaked bottem portion with weights on the top part of the garage door when opened.
PS3 Trophies
Old 01-31-2010, 05:47 PM   #4
advocate
Drives: car
Just finished this install!
Great product, great price, great DIY!
Thanks MicroImage!
I really need to get a torque wrench...
Now to install the Tanabe strut bar!
Old 11-23-2010, 05:25 PM   #5
Teledan71
Drives: Toyots Yaris
where and how can i buy ?
Hi i'm writing from Italy and i'd want to buy one rear sway bar for my yaris. I read many posts in forum toyotaclubitalia and one member who's named Suiller, has posted your photo how to installate sway bar; this member has writed that is possible to buy the bar from other member named Garm ??? Can you help me. Thanks a lot
Teledan71 is offline   Reply With Quote
Old 11-23-2010, 07:49 PM   #6
Klink10
Klink10's Avatar
Forum vendor this site name is Garm and owns/represents Micro Image. Look for posts by him and or google Micro Image.
Old 11-30-2010, 01:54 AM   #7
pjh
Drives: 2006 Yaris HB
Hey guys, just got a (stock) 2006 Yaris HB and thinking of doing this mod. How much does this mod (for both 19mm and 23mm) affect the understeer/oversteer balance? I'm looking to reduce the understeer and improve turning response, but I don't want it so extreme as to be losing the back end regularly. I don't want my wife to drive it and end up backwards in a ditch. My gut feel is that this won't be a problem, but does anybody have a comment from experience on how extreme the two sizes are with respect to terminal understeer/oversteer?
Also, anybody have experience ordering to Canada from MI?
pjh is offline   Reply With Quote
Old 11-30-2010, 04:44 AM   #8
ddongbap
Yes. Garm will get it done for you. He ships worldwide.
Old 02-12-2011, 08:03 PM   #9
sickpuppy1
Drives: 2010 Yaris Sedan
They are both good bars. if your wanting to just get rid of some understeer (and as a side benefit, make it less susceptible to cross winds, or big trucks and such) I would go with the 19MM if its a 3/5 door. If you want to really"go for it" then MAYBE the 23. I have a sedan and the 19mm by ultimate racing (microimage) It is definitely a vast improvement, worth every penny. That being said, if I did it all over again, with a sedan, I would go with the 23mm in a heartbeat. More overhang off the back end (sedan) would benefit more from the 23 than a 3/5 door would, without worrying about oversteer. Like I said, I love the difference over stock with my 19 but feel I could have gotten even better without sacrificing any ride or stability. I have wood plank ramps I use for oil changes. I just put them under the back end and drove it up on them. Basically a four inch rise. Didnt have to take offs wheels at all.
Old 01-21-2011, 01:53 AM   #10
matthewai
matthewai's Avatar
Drives: it is kinda stock
i know this prob was answered but can some one refresh me...does the UR 19mm fit on 2010 sedan ?
Old 01-21-2011, 12:41 PM   #11
RedRide
RedRide's Avatar
Yes it will fit as the suspensions are identical for all sedans and HBs
Old 01-21-2011, 12:57 PM   #12
^ correct, and thanks!
Old 02-03-2011, 01:47 AM   #13
matthewai
matthewai's Avatar
if i were installing an exhaust should i put the sway bar on after or before or does it not matter cuz im waiting for an exhaust now and also the mounting hardware for the bar just want to know what i should do first when i get both these...thanks
Old 02-03-2011, 02:04 AM   #14
^ doesn't matter. an axle-back exhaust is two bolts and installs in 10 minutes or less.
Old 02-03-2011, 02:11 AM   #15
matthewai
matthewai's Avatar
yeah didnt think so, awesome
Old 02-12-2011, 03:37 PM   #16
PumpkinSteve
PumpkinSteve's Avatar
Drives: Yaris SR 1.8
How long does it take to fit the TRD sway bar? Do you need to take the rear wheels off? I want to do it myself but I don't have ramps/ axle stand so I'll probably have to pay someone else to :(
PumpkinSteve is offline   Reply With Quote
Old 02-12-2011, 05:09 PM   #17
^ Takes about 30 minutes max. You can do it with the car on the ground if you're not lowered. It helps to jack up the the rear a little though to take the weight off the shock bolt (one of the two bolts that hold on the sway bar.
Old 02-12-2011, 08:06 PM   #18
auxmike
auxmike's Avatar
Sway bar is a must have item. I love my TRD one...
Rear Sway Bar Instructions - Additional Pics SeaYa Wheels, Tires and Suspension Forum sponsored by The Tire Rack 10 02-26-2009 01:05 PM
TRD rear sway bar...street or race setting? detroiter Wheels, Tires and Suspension Forum sponsored by The Tire Rack 14 02-08-2009 02:26 AM
TRD Rear Sway Bar Install ?? bikegerm Wheels, Tires and Suspension Forum sponsored by The Tire Rack 6 12-26-2008 01:46 AM
solid torsion bar bushings... the best rear anti roll upgrade turboyaris Wheels, Tires and Suspension Forum sponsored by The Tire Rack 28 12-05-2008 11:37 PM
DIY - TRD rear sway bar kurokoma-kun DIY / Maintenance / Service 0 10-20-2008 01:21 PM
