Old 03-03-2011, 11:42 AM   #127
Hershey
" hershey for the record ur pics look extra "staged" or "serious" now with his pics next to it. the pics u posted look to have very fresh oil and a significant amount. "
. Are you saying I somehow planted the oil there for both cars ? We've posted the worksheet and the extended warranty . Not much more we can do to prove this is real , not fiction .
Old 03-03-2011, 12:09 PM   #128
Hershey
GONZO , you still may want to take a look at the area pictured for both our cars . You could always remove the plastic engine cover to see if any oil was spilled on top of the valve cover during an oil change and then look around the backside and corner of the valve cover to see if any oil is leaking from the valve cover . It only takes about 5 minutes to take of the cover for a better look . Good Luck .
Old 03-03-2011, 01:47 PM   #129
yaris2010RS
yaris2010RS's Avatar
lol, dont take it the wrong way; no i dont think u planted it there. but for there to be oil dripping like the pic u showed but no oil on the driveway and u not needing to add oil seems odd and i do still think MOST of ur evidence is spilled oil.
as for worksheets, if u go an complain to toyota they will do the work, they dont care, they get paid.
Old 03-03-2011, 02:54 PM   #130
Hershey
Here's some pics taken today . Top is engine cover removed showing no oil spilled during any of my oil changes since bought new , 2nd down is oil collecting underneath which you'll see the pattern is different than the previous pic from post #124 ( bottom pic ) , 3rd down is back and corner of valve cover gasket ( no oil ) , and bottom is side of valve cover gasket with no oil leaking . Not much more we can do to for proof .
Old 03-03-2011, 03:03 PM   #131
Hershey
No new car should have an oil leak as our 2010 does , the 2008 did , and our friends 2010 does . He has over 60,000 miles on his . We're waiting to see how his car holds up as the mileage racks up . If his develops problems we'll then get our 2010 repaired under warranty .
Old 04-04-2011, 02:09 PM   #132
Nu18F
Drives: 2011 Yaris
Hershey,
I see the photo's of the oil and i do believe you. 2 ounces of oil can make a much larger mess than your photo's show without affecting oil level. That said and just FWIW , i wouldn't automatically assume it's faulty head gaskets. The list of possibles could be long.
Whatever the cause, if in fact there are many 1.5's out there with the same problem, i really hope it was caught before the 2011 model was built.
They wife's new 2011 set's outside with 26 miles as i stumbled across this topic.
Nu18F is offline   Reply With Quote
Old 04-04-2011, 03:18 PM   #133
Hershey
Thanks for the trust . The 2008 sedan head cylinder gasket was replaced under warranty at 23,747 miles and hasn't leaked any oil since the fix . Tells of a likely defective head cylinder gasket . I found the oil leak of both during an oil change for the 2008 when I decided to look at the engine for any leaks . Took a few days to pinpoint it for both since it's in a well hidden spot of the engine block . The 2008 had 17,803 miles and the 2010 3,467 miles at the time of discovery . So , the oil leak starts very early . The 2010 still leaks . I've found the same oil leak on YARIS from 2007 > 2010 . We considered trading the 2010 3 door ( TOYO dealer knowing of oil leak ) for an 2011 , but were concerned may end up with the same issue . I hope you and others don't encounter this .
Old 04-04-2011, 03:25 PM   #134
Hershey
Last , the Multi Layered Steel head cylinder gasket that replaced the the factory H.C.G. of the '08 sedan seems a bit thicker . Compared to the factory installed H.C.G. of the 2010 .
Old 04-04-2011, 03:37 PM   #135
Nu18F
Drives: 2011 Yaris
Thanks for the clarification - I hope we have the newest style.
Is there by chance an online parts fiche for the Toyota's? I would like to see if the head gasket part number has been superceded.
Old 04-04-2011, 04:21 PM   #136
Hershey
Just called a few TOYOTA parts departments . The kit number is # 04112 - 21231 and the M.L.S. head cylinder gasket in this kit was likely to be #11115-21040 , this was current in September 2010 when the work was done . Was also told the original ( factory installed ) M.L.S. head cylinder gasket is most likely to be #11115-21030 . The current M.L.S. H.C.G. is #11115-21050 . As for the #11115-21040 being thicker than the 21030 is unknown . Seems to be to the touch of the finger from the '08 and the 2010 . Hopefully the 2011 is the 11115-21050 and not the 11115-21030 . Confusing , ain't it ?
Old 04-04-2011, 04:38 PM   #137
ROCKLAND TOYOTA
TRIM HUNTER
ROCKLAND TOYOTA's Avatar
11115-21030 IS FOR THE ECHO/PRIUS AS FAR AS MY CATALOG GOES. 11115-21050 IS GOOD FOR 2006-2011 YARIS.....
Old 04-04-2011, 05:42 PM   #138
Hershey
The 11115-21050 H.C.G. comes with the current head cylinder gasket replacement kit. Was told this by the parts dept. Thanks
Old 04-04-2011, 05:51 PM   #139
Hershey
Rockland, is it possible that the newer gaskets are thicker than the factory installed gaskets? Is there any way you could find out? Thanks
Old 04-05-2011, 09:23 AM   #140
ROCKLAND TOYOTA
TRIM HUNTER
i could measure a newer one if you have an old one to compare it to....
Old 04-05-2011, 11:49 AM   #141
Hershey
" i could measure a newer one if you have an old one to compare it to...."
The service center sent the original H.C.G. to Toyota for inspection and threw out the package it came in . I'll try to find a way to measure the one on the '10 . Very difficult to do thanks to the location in the back of the engine , not much room to work with as you can see ( exposed part of H.C.G. in RED ) . Thanks .
Old 04-05-2011, 12:02 PM   #142
Hershey
Here's a side view of the exposed part of the H.C.G. ( circled in BLUE ) after being cleaned on the 2008 sedan not long after finding the source of the oil leak . Last night the better 1/2 noticed that a part of the multi layered steel head cylinder gasket looks to be split apart ( gap ) ( circled in RED ) . What's your take on it ? A defect ? I'll try to get the same picture of the 2010 that leaks oil for comparison . ( may need to zoom in for better view )
Old 04-06-2011, 03:58 PM   #143
Hershey
Just took these pics after cleaning the M.L.S. head cylinder gasket and the surrounding area of the 2010 and that has the split ( gap ) of the H.C.G.. Looks very similar to the '08 H.C.G. above that was taken before H.C.G. replacement . I also noticed in AUXMIKES You Tube video that his has the same split as the '08 did and the 2010 does . To see go to , http://www.youtube.com/watch?v=EVK_uBKotcU , you'll need to watch it FULL SCREEN and then pause it at 29 > 30 seconds into the video where you'll see the split ( gap ) in the M.L.S. head cylinder gasket . Looks like it starts near the exhaust manifold and goes further to the right . Makes me wonder if the heat of the exhaust manifold is causing this or the M.L.S. H.C.Gaskets from the factory are defective or possibly a combination of both . The oil leak occurs from under that area . The new H.C.G. in the '08 no longer leaks oil and looks to be thicker than the original H.C.G.. Probably thicker to withstand the heat of the exhaust manifold . . Did call a few Toyota techs to explain the issue and said not likely for the split of M.L.S. H.C.G. to be normal . Here are the pics from today of the '10 3 door for comparison to picture above and AUXMIKE's video . May need to ZOOM in for better look of the 2010 photos , gap is circled in RED . Last , What's your take on this matter ? Thanks .
Old 04-06-2011, 08:51 PM   #144
Hershey
Well , the split in the gaskets shown above are not likely to be the culprit . Just took a picture of the new M.L.S. head cylinder gasket in the 2008 sedan that was installed in September and that too is split . You'll notice all the black F.I.P.G ( Form In Place Gasket ) sealant used to reseal it . One possible cause down . So , possibly to be defective head cylinder gaskets installed at the factory . Think they were supplied by a company in China . Here' the pic , split is circled in RED . May need to ZOOM in for better look .
best synthetic oil and m/t oil?? doodoo DIY / Maintenance / Service 122 04-03-2017 08:43 PM
Transmission Oil for Yaris 1st Gen adigilani DIY / Maintenance / Service 3 10-23-2011 02:48 PM
