Old 10-27-2010, 01:49 AM   #1
Hershey
Exclamation Found : head gasket oil leak on 2 used 2010 YARIS ...
at TOYOTA dealer lot . Both had less than 5,000 miles . They sold another used 2010 with low mileage and was being picked up by the new owners as we looked at these . Hopefully that didn't have the oil leak as those 2010s , our 2 YARIS ( 2008 sedan and 2010 3 door ) , and a friends 2010 3 door .
Old 10-27-2010, 02:04 AM   #2
Hershey
The 2010s ( including ours ) with the oil leak were manufactured between AUGUST > OCTOBER of 2009 .
Old 10-27-2010, 02:18 AM   #3
jaime
Drives: 2010 Yaris 5-door LB
My 2010 LB was made in April 2010 (it says 4/10 on the door sticker). I havent checked, but could mine also have this problem?
jaime is offline   Reply With Quote
Old 10-27-2010, 02:32 AM   #4
Hershey
Yes , it's possible . We just had the head gasket of our 2008 sedan replaced under warranty and no longer leaks oil . Our 2010 still leaks oil from the head gasket , plan to take that in for replacement under the warranty . Could include 2007 > 2010 . 2011 ? . We've notified TOYOTA of JAPAN and corporate offices here ( U.S. ) of the issue and haven't heard a word as of yet .
Old 10-27-2010, 07:24 AM   #5
krolos
Drives: 2008 yaris sedan
you are now going around to the dealers
checking other yaris for oil leaks and you find some
with same problem, wow I dont know what to believe
You must have the Lemon curse really bad
krolos is offline   Reply With Quote
Old 10-27-2010, 08:25 AM   #6
ROCKLAND TOYOTA
TRIM HUNTER
ROCKLAND TOYOTA's Avatar
i call until this guy posts up some pictures in a toyota dealer's lot with said leaks....
Old 10-27-2010, 09:01 AM   #7
krolos
This was Probably the Reason for the claim. http://money.cnn.com/galleries/2010/...eliable/2.html
Old 10-27-2010, 10:43 AM   #8
yaris-me
Learn to Relax
Drives: 2007, Meteorite, LB
I don't think it's a head gasket leak. What you're seeing is probably a valve cover leak. That is a big difference.
A head gasket leak would cause a massive recall by Toyota. A valve cover leak is solved most of the time by tightening the hold down screw or bolt.
You should confirm a head gasket leak with some kind of proof.
Old 10-27-2010, 11:39 AM   #9
Hershey
It's no B.S. . They took one of the YARIS into the shop and will be monitoring the leak by driving both for a period of time for oil to build up . This is the same dealership that replaced the head gasket of the 2008 sedan and where we purchased the 2010 3 door ( oil leaking from the head gasket ) . I know where to look for a leaking valve cover , have over 20 years of experience with cars . You'll have to take our word for it .
Old 10-27-2010, 12:09 PM   #10
why?
Only Happy When it Rains
why?'s Avatar
Drives: Yaris LB
ehh, you've been so negative for so long i highly doubt anyone will believe you until we see a recall notice from toyota.
Colin Chapman disciple
Old 10-27-2010, 12:10 PM   #11
Hershey
That's fine . Take it or leave it .
Old 10-27-2010, 12:44 PM   #12
1stToyota
1stToyota's Avatar
Guess you can issue a told you so if you end up being about a year or two ahead of Toyota and the rest of us on this.
1997 Lincoln Town Car - SOLD
2008 Scion xD
(w/ automatic) - SOLD
2008 Yaris HB - SOLD
Old 10-27-2010, 02:14 PM   #13
yaris-me
Learn to Relax
I'm willing to bet that you don't know what you're talking about.
You need to confirm a head gasket leak with some kind of proof.
Old 10-27-2010, 02:58 PM   #14
Hershey
Say what you will , but won't change a thing .
Old 10-27-2010, 03:42 PM   #15
RemieGino14
RemieGino14's Avatar
Drives: 2010 5dr Hatchback Yaris
Send a message via AIM to RemieGino14
I think he was talking about pictures, maybe even a statistic printout? I don't know, I'm still going to school for this right now...
- RemieGino14 -
'91 Midnight Black, Acura Integra RS - Crashed
'07 Silver Mica, 4dr Toyota Yaris - Crashed
'99 Cypress Green, Acura 3.0 CL
'10 Carmine Red Metallic, 5dr Hatchback Toyota Yaris
RemieGino14 is offline   Reply With Quote
Old 10-27-2010, 04:13 PM   #16
Hershey
There are plenty of pictures of our 2008 and 2010 YARIS showing the extent of the leak and its location in the DO IT YOURSELF room .
Old 10-27-2010, 06:46 PM   #17
Hershey
Here's the actual worksheet from the Toyo service center showing the head gasket replacement on the 2008 sedan. There has been NO leak since the fix.
Old 10-27-2010, 06:50 PM   #18
Hershey
The 2010 3 door that has the same oil leak as the sedan had is to be repaired in the near future. When the job is done, we'll post the worksheet for that as well.
best synthetic oil and m/t oil?? doodoo DIY / Maintenance / Service 122 04-03-2017 08:43 PM
Transmission Oil for Yaris 1st Gen adigilani DIY / Maintenance / Service 3 10-23-2011 02:48 PM
