#1 |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 black yaris Join Date: Oct 2010
.032 to .029.
I would go as low as .022
-Derrick- "Racing is important to men who do it well. When you're racing... It's life. Anything that happens before or after, is just waiting." |
![]() ![]() Drives: Yaris 3dr hatch Join Date: Jan 2012
I'm not sure I'm going to mess with the gap anymore because I'm 90% sure it has to do with the FIC itself just because when the FIC is bypassed the car doesn't misfire at all. So I figured as long as the car is getting the signal to spark, it does and doesn't have a problem igniting the mixture without the FIC.
#3 |
I hear ya. And you're probably right. I was just suggesting what gap I set mine. My crx had issues with loosing power at full boost. Is wasn't at bad when I went .033 and eliminated the issue completely at .022.
I am not saying this is the problem with your car. I am just adding my experience and what I set my gap when I was boosted.
#4 |
@blown_xa, I do have a lightweight flywheel but you can hear and feel when it misfires so I don't think its a false code unless it's just idling rough for some other reason and the misfire code is just a coincidence
@ilikerice, no I get ya, that's why I did try closing the gap a bit but it just seems more like the problem is from another area. I also don't have any problems with misfiring when I'm giving it gas or hitting boost, it's only when I let go of the gas and idle or put it in neutral that you hear and feel it misfiring. |
#5 |
Try zero's yet in the lower RPM range yet? Sounds like its too rich at idle
#6 | |
My brother is helping me put together a junk PC tower tonight with a bunch of his random spare parts to use. I'll post with the results of the change as soon as I get that all done. Last edited by thatbryanguy; 10-08-2013 at 03:19 PM. |
#7 |
I finally got an old laptop to use to change my cal file on my FIC. So when I go to modify the fuel map on the cal file, what boxes should I make 0 for the lower rpms? I'm completely unfamiliar with how this works.
The car runs fines with a completely zero'ed out map (the base cal file) so I just need to know how exactly the FIC picks what boxes at idle. I see the rpms across the top but on the left it says psi so I'm not sure what to change. Last edited by thatbryanguy; 10-18-2013 at 06:47 AM. |
#8 |
Update: Put in zeros for the boxes the FIC uses for idle and it helped a little it seemed with the roughness but it still stalls out at idle.
#9 |
Bump for reference....
| FS: AEM FIC + Wiring Harness Boomslang | djgab101 | Items for Sale by private party | 18 | 12-06-2013 03:36 AM |
| FS: Zage Turbo kit, AEM FIC with Pnp Harness | djgab101 | Items for Sale by private party | 32 | 04-11-2013 10:42 AM |
| AEM FIC tuning experience | thatbryanguy | Performance Modifications | 0 | 09-03-2012 01:29 PM |
| AEM FIC to replace CamCon cc101 ?? | vten | Forced Induction Forum | 26 | 08-04-2012 07:38 AM |
