Old 04-11-2015, 01:18 PM   #1549
Ccorderot
Drives: 2015 Yaris L 3d 5sp
My 2015 2 door 15x8 drift racing dr7 wheels +25 offset stretched 175/70R15 Bridgestone turanza tires stock height for now ;-)
Ccorderot is offline   Reply With Quote
Old 04-22-2015, 03:08 PM   #1550
maximtr
Recovered from Hell
Drives: 2010 Yaris
Originally Posted by gojon17 View Post
debadged yaris, stock steelies painted white with a bit of pearl, trd springs, hd lip
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
really like it! Simple Contrast perfect! Will do same for my yaris for winter season
maximtr is offline   Reply With Quote
Old 04-22-2015, 03:37 PM   #1551
maximtr
Recovered from Hell
Drives: 2010 Yaris
Originally Posted by catliektheif View Post
got a new-to-me set of wheels today!
Falken Hanabi's 17x7.5
made em white!
I believe I met you in ****** and it was different wheels white rims.
Old 04-27-2015, 11:05 AM   #1552
MedMantle
MedMantle's Avatar
Drives: Yaris '05 1.3 Hatch "R.I.P."
MedMantle is offline   Reply With Quote
Old 05-01-2015, 09:19 PM   #1553
Johnhosepipe
Drives: Yaris 1.0 Ion. (2007)
2nd Gen Yarris with 16" wheels 9J rear and 8J Front
Hi all just though I would share a couple of pictures of my Yarris.
Dare BBA Silver Polished Lip Alloy Wheels
Rear
9J et 30 with 195/55/16 tyres
Front
8J et 25 with 185/55/16 tyres
Johnhosepipe is offline   Reply With Quote
Old 05-01-2015, 09:29 PM   #1554
Johnhosepipe
I've also lowered the car with D2 coil overs there is about 4" of ground clearance under the car. I've also set the bump stops on the rear shocks to stop the arches hitting the side walk of the rear tyre when riding 4 up.
Old 05-01-2015, 09:32 PM   #1555
Johnhosepipe
Picture of wheels on there own.
Sorry the post is a bit all over the shop as I've uploaded the pictures from my iPhone and it will not let me insert a picture or have multiple attachments. Soz
Old 05-01-2015, 09:43 PM   #1556
Johnhosepipe
My car before when it was on a set of Corsa SXi 16" wheel
7J et 40 with 195/55/16 tyres all round
They worked fine for a bit, better than steels.
They did rub a bit on the inside at full lock but nothing serious.
Check this site out if you are thinking of buying alloys and want to know what
Wheel size, J size, et and tyre size to have. You can compare your wheels to what you are thinking of having on. This way you can measure and see if you need stretched tyre to get it under the arch.
http://www.willtheyfit.com/index.php...et2=30#content
I've left in my Corsa wheels and my new 9J wheel in for a comparison.
Hope the info helps.
Old 05-02-2015, 09:32 AM   #1557
Johnhosepipe
Here it is before I put my wheels on.
I borrowed a set of Corsa SXi wheels, better than the steels.
For reference
7J et40 with 195/55/16 tyres.
They fitted fine but rubbed slightly on the inside under full turn lock.
I used this web site for checking what alloys fitted on my car.
Below is an example of my two wheels.
Hope the info helps you all out.
Old 05-04-2015, 11:03 AM   #1558
ern-diz
ern-diz's Avatar
Drives: 2007 Liftback
Old 05-05-2015, 03:37 AM   #1559
ssbpgsr
Drives: 2010 Yaris
Mine
Mine
ssbpgsr is offline   Reply With Quote
Old 05-05-2015, 10:25 AM   #1560
ern-diz
ern-diz's Avatar
Originally Posted by ssbpgsr View Post
Mine
Looking good
Old 05-14-2015, 01:01 AM   #1561
RWJC
Drives: 2014 Yaris LE hatch
2014 LE Hatch
Stock...
now: 18's, 215/35-18, almost identical to stock diameter.
v
RWJC is offline   Reply With Quote
Old 05-17-2015, 12:23 AM   #1562
willieG
Drives: 09 hb 2nzfe m
18 x 7.5 et 42
lowered 30mm and rear sway bar
and because why not
willieG is offline   Reply With Quote
Old 05-27-2015, 02:08 AM   #1563
WorkTL
WorkTL's Avatar
Drives: 2013 Yaris LE
SSR MK III custom
WorkTL is offline   Reply With Quote
Old 05-27-2015, 02:11 AM   #1564
WorkTL
WorkTL's Avatar
Just need rear camber shims to get these bad boys on....if anyone one has a set of realcamber style shims please PM me. Need them asap.
Old 05-27-2015, 01:34 PM   #1565
33OH
Drives: '08 Yaris
Those SSR's are awesome. More pics!
Old 05-27-2015, 05:03 PM   #1566
WorkTL
WorkTL's Avatar
Will do....
Im mounting the tires on Friday.
