Old 11-21-2012, 10:46 AM   #145
tooter
play every day
tooter's Avatar
Drives: 2012 Yaris L 2dr 5sp
Originally Posted by xnamerxx View Post
Depends on how they are designed, but if both are designed correctly there should be almost no difference.
The 1NZ FE engine's firing order is 1-3-4-2.
A 4-2-1 tri Y header pairs up sequentially firing cylinders 2-1 and 3-4 so that the exhaust pulse from one helps to draw exhaust from the other.
Then the combined 2-1 and 3-4 pairs join to help scavange each other...
Practically speaking, the headers are too short to make a lot of difference.
But that's where namer comes in...
Old 11-21-2012, 12:08 PM   #146
1.5
Form>Function
1.5's Avatar
Drives: 07 Flint Sedan
The 4-1 is supposed to delay the power increase until higher in the powerband. The 4-2-1 is supposed to give a midrange bump. On our tiny cars you probably would never notice a difference. I love my DC header. Anytime I'm above 4k I'm just roaring and pulling hard for a yaris lol.
Old 11-21-2012, 12:20 PM   #147
tooter
play every day
tooter's Avatar
I actually did notice a difference...
...as I climb a steep 1/4 mile hill in 2nd gear to get to my house. It's always the same hill, so that's constant. And driving up it everyday I have a good feeling for the resistance. The header definitely helped the engine make it up the hill easier. If you start climbing under 2,000 rpm, the engine labors sluggishly. But anything over 2,000 and it gains rpms much easier and climbs more easily than the stock header which feels like it's holding back at the same rpms.
Old 11-21-2012, 12:36 PM   #148
^ An aftermarket header will certainly make a difference over stock, but I doubt you can feel any difference BETWEEN aftermarket headers. You just can't feel 1-2 horsepower, in my opinion.
Old 11-21-2012, 12:36 PM   #149
TRYaris is that your car in your avatar?
Old 11-21-2012, 01:32 PM   #150
xnamerxx
0-60 in slow
xnamerxx's Avatar
Drives: light blue liftback
Basically what Cali said.
There is a maximum of about 12" to work with and an ideal length of about 35" so most of the ots headers compensate by increasing the volume of tube which in essence give some of the same effect as increasing length but reduces scavenging at lower rpms. Now this motor is relatively small displacement with a good torque management system going to a larger diameter tube won't hurt you as bad as it would on a larger engine.
So not wanting to give up anywhere in the powerband while still gaining some up top is the reason I decided to design and build my own header.
As far as header type is concerned both a 4-2-1 and a 4-1 will accomplish the same goal but each design has its own advantages but both of them can produce near the same power and torque so there isn't a real advantage to choosing either one aside from packaging constraints, and a 4-1 is simply easier to package with the effecting lengths required.
Old 11-21-2012, 02:05 PM   #151
TrYaris
TrYaris's Avatar
Drives: Racin' yaris :D
No it's not :P would be nice but I don't have that much money !
TrYaris is offline   Reply With Quote
Old 11-21-2012, 03:01 PM   #152
1.5
Form>Function
1.5's Avatar
This
Tr that pic I think is sporting a MI Hood visor.
Old 12-01-2012, 09:33 PM   #153
tooter
play every day
tooter's Avatar
That's one thing I really like about the Weapon R. It's precise. You could cut your finger on that sharp knife edge where the two main tubes are joined...
But as far as performance, it doesn't matter.
Old 12-01-2012, 10:20 PM   #154
xnamerxx
0-60 in slow
xnamerxx's Avatar
That's not a good thing, air doesn't like sharp edges.
Old 12-01-2012, 10:56 PM   #155
tk-421
tk-421's Avatar
Drives: 5D-07-LB
I don't think it would make that much of a difference in our case either way.
Any aftermarket header should prove to be at least slightly better than stock, right?
Old 12-01-2012, 11:07 PM   #156
xnamerxx
0-60 in slow
xnamerxx's Avatar
the slight knock it causes in flow won't make much of a difference.
Old 12-02-2012, 12:49 AM   #157
tooter
play every day
tooter's Avatar
... especially when its just a trailing edge with alternating pulses coming through each runner.
Old 12-02-2012, 01:55 PM   #158
xnamerxx
0-60 in slow
xnamerxx's Avatar
I wouldn't worry, all of the aftermarket headers lack a ventur,i so the collector looking bad wol make almost no difference.
Old 12-02-2012, 04:50 PM   #159
tooter
play every day
tooter's Avatar
Originally Posted by TOLMACH View Post
Mine looks nothing like this inside (build quality wise) ((
Hopefully, will still do its job
It will work just fine.
The DC is a time tested design. And in my opinion, trailing edges don't matter. Those are the edges that point in the direction of the exhaust flow.
Old 12-02-2012, 05:04 PM   #160
1.5
Form>Function
1.5's Avatar
Tolmach yours also does not have the ceramic coating. I thought all DC headers for the yaris came coated.
Is it a replica? Poor build quality, alteration of branding, and lack of ceramic coating... sounds like a Rep.
Old 12-02-2012, 10:00 PM   #161
Golddeenoh
Takes corners too fast!
Golddeenoh's Avatar
Tolmach, your pipes look kind of small as well but then again my Megan Racing header is 3mm larger diameter but i wouldn't think that i could tell the size difference in a picture with out side by side comparison.
Old 12-02-2012, 10:55 PM   #162
NJ Drive
Drives: 2012 Yaris SE
Can someone measure the I.D. on one of the primaries on this header? It looks similar to the OEM and somewhat smaller than the Weapon R header.
NJ Drive is offline   Reply With Quote
