Old 12-28-2008, 11:56 AM   #1
The Architect
Give Me Resonance
The Architect's Avatar
Drives: 2007 Yaris HB
Exclamation Wires Inside the Yaris & What They Do
This is for the 2007 2DR Hatch Back
Wire/Function - Color - Location/Description
12 Volts - Yellow - Ignition Switch Harness
Ignition - Pink - Ignition Switch Harness
Accessory - Green - Ignition Switch Harness
Starter - Black - Ignition Switch Harness
Tach Signal - Light Green - At Diagonal Plug Under Drivers Side Dash
Lock - Brown - In Drivers Kick Panel
Unlock - Dark Green & Dark Blue - In Drivers Kick Panel
Driver Door - Red - Drivers Kick Panel In Harness to Rear
Passenger Door - Light Blue - Drivers Kick Panel In Harness to Rear
Rear Driver Door - Light Green - Drivers Kick Panel In Harness to Rear
Rear Passenger Door - Light Blue - Drivers Kick Panel In Harness to Rear
Trunk Pin - Light Blue - Drivers Kick Panel Harness to Rear
Brake Switch - Light Green - At Switch Above Brake Pedal
Park Lights - Gray - In Drivers Kick Panel
Park Lights (-) - White - At light switch harness
Hand Brake - Light Green - At DRL Module on right of steering Column
Horn - Black - In White plug on steering column
Clutch Switch - Black - At switch on clutch pedal bracket
Headlights - Light Blue - At light switch Harness
PG TLD22 8V Line Driver
Old 12-28-2008, 09:37 PM   #2
The Architect
Give Me Resonance
These are highly necessary to know for any remote start / security alarm set-up, hope it can be of use in the future.
Old 12-29-2008, 07:26 PM   #3
AlexNet0
AlexNet0's Avatar
Drives: '07 Yaris 3dr
haha, nice, I installed a remote start day before yesterday and you post it yesterday, awesome info to have, if only I had waited another day!! Would have saved myself time.
Old 02-09-2009, 09:22 AM   #4
Over40
Over40's Avatar
Drives: SilverYaris
Thanks man,
but it would be nicer if you could put some pics along to show where the locations are at....
Over40 is offline   Reply With Quote
Old 03-08-2009, 08:02 PM   #5
anubisx99
here again..
anubisx99's Avatar
Drives: 2008 toyota yaris LB
speed signal cable for GPS units???
Don't be threating me with a good time!!!
anubisx99 is offline   Reply With Quote
Old 03-08-2009, 09:23 PM   #6
On your 08, you can grab it at the TPWS ECU, behind the lower passenger glove box:
Old 07-06-2011, 03:13 AM   #7
IsLNdbOi
IsLNdbOi's Avatar
Anyone know which of those wires is switched / ignition power? I tried the other red one, (the red one that's not labeled), but it's not working.
Heatware:
http://www.heatware.com/eval.php?id=35947
Old 03-08-2009, 10:08 PM   #8
The Architect
Give Me Resonance
I recall someone having had an issue with tapping the purple/violet wire for some other electrical project. perhaps he was just unlucky or did something wrong.
Let us know so that this thread stays accurate.
Old 03-17-2009, 05:14 AM   #9
another useful tidbit for those wishing to wire in LED mirror covers, you can get the signals from each side here. This is for the big relay/junction box in the driver's footwell area.
This way you don't have to go into your engine bay to wire them up
Old 12-05-2009, 01:33 PM   #10
zuberio
Joined 3/08 ... really
zuberio's Avatar
Drives: '07 Sedan
Thankyou ThankYou THANKYOU!!!
zuberio is offline   Reply With Quote
Old 07-11-2009, 05:02 PM   #11
areithan1980
areithan1980's Avatar
Drives: 2007 Yaris Hatchback
how about for installing tach in the future woudl this be the same loc. to tap
areithan1980 is offline   Reply With Quote
Old 07-29-2009, 01:40 AM   #12
toyota
SRacer
toyota's Avatar
Drives: Toyota Yaris 2007
Send a message via Yahoo to toyota
WOW! thanks man!
yeah, pictures would be helpful.
thanks though...
"If I go down, I do time. I do real time. I don't know about your other drivers but when I see flashing lights in the mirror I don't stop."
- Dominic, Fast & Furious
Learn The Truth about Six Pack Fast!
toyota is offline   Reply With Quote
Old 08-01-2009, 09:47 PM   #13
yarhead
yarhead's Avatar
Drives: 07 hatch
yeah, what areithan1980 said! where would be go for a tach?
YARHEAD
yarhead is offline   Reply With Quote
Old 08-01-2009, 10:05 PM   #14
Tach wire location at pin 9 of DLC3 connector:
09 (Beige wire):
07-08 (Green Wire):
Old 08-28-2012, 09:46 PM   #15
mamun22s
Drives: Toyota Vitz
09 (Beige wire):
07-08 (Green Wire):
Can any one help the abt the chip on the pic coloured red and blue. what is there function?Be cause one of them getting hot. What actually they do? and also the function of the fuse? How do i know whether they functioning or not.
mamun22s is offline   Reply With Quote
Old 08-28-2012, 09:56 PM   #16
They are relays. The left one is the IG1 relay and the right one is the HTR relay. The left one gets warm when the ignition is on and the right gets warm when the blower is running. That is normal.
The fuse above it to the left is for the power windows and the one above it to the right is for the defogger.
Old 08-17-2009, 12:57 PM   #17
47_MasoN_47
What I thought I'd do was
47_MasoN_47's Avatar
Drives: 09 Yaris Sedan
I'm looking to add a few lights under the dashboard that are on the same circuit as the dome light (so they turn on when the door opens) and was wondering which wires they are. I have the 09 sedan, does anyone know which wires I could use?
Old 08-17-2009, 01:04 PM   #18
The connector (4K) on the upper left in this picture, is the feed to the map and dome lights. White with a black stripe ground, Pink is the "door open" switched ground, and blue is 12V fed from the DOME fuse.
2012 Yaris at SEMA Jason@SportsCar Third Gen Yaris General Discussion 5 09-23-2013 03:55 AM
New Yaris race car Jason@SportsCar Tracking, Racing, Auto-X Forum 83 11-01-2012 02:32 PM
