Old 05-02-2012, 10:31 PM   #1
ggrieco
Drives: 2008 yaris aero
FOG LIGHTS
Does any one know how to re-wire the OEM fog light switch so that I can turn on my fog lights with-out having to turn on the head lights. If I could turn on just the parking lights and be able to turn on the fogs, that would be cool too.
I also noticed on a post that you can dis able the DRL by removing the relay under the steering column, maybe that`s a start.
BTW my car is a canadian model.
Thanks,
ggrieco is offline   Reply With Quote
Old 05-03-2012, 02:40 PM   #2
1.5
Form>Function
1.5's Avatar
Drives: 07 Flint Sedan
Did this come from factory? I wasnt aware that stock fogs are only operable with headlights. That doesn't sound right. You can always just draw one wire to power and the switch wire into the cabin and control them that way no need to rely on anything but a power source. May need some longer wires to move into the cabin for the switch.
Also this is the wrong thread section.
Old 05-03-2012, 05:12 PM   #3
jpmck03
jpmck03's Avatar
Drives: 2018 Volkswagen GTI
OEM fog lights only come on if you have your headlights on and automatically turn off with your high beams...
There was a thread about this a month or so ago and CTScott answered that it's doable. I wasn't able to find it on here using the search though... Hopefully he can point you in the right direction or give you an answer...
(Mods: can you put this thread in the right place, please?)
Old 05-03-2012, 06:31 PM   #4
The picture below shows the headlight switch connector. To allow you OEM fogs to turn on any time, clip the orange wire in pin 4, cap off the harness side of the cut wire and tap the connector side of the cut wire to the white wire with the black stripe in pin 7 (6 to the right of the marked pin 13).
Old 05-04-2012, 08:40 AM   #5
ijose 845
ijose 845's Avatar
Drives: 07 Toyota Yaris
dont they come pre wired with the yaris? Aint it just plug and play?
Angry Bird Crew #1
ijose 845 is offline   Reply With Quote
Old 05-04-2012, 09:00 AM   #6
The question was how to re-wire the OEM ones.
To answer his other questions sent in PM:
The connector pictured is located under the steering column cover at the base of the headlight stalk. Search for my "headlights off with the key" DIY for a pictorial guide to getting the cover off.
The second question was explaining the wiring more. You are simply going to cut the wire, far enough away from the connector to give you a 2 inch or so piece of wire attached to the connector to work with. That side of the cut you will attach to the wire in position 7. A "tap splice" connector, available at any auto parts store, is the easiest way to do so.
The other side of the wire you just need to cover with tape or a butt splice
Old 05-04-2012, 08:17 PM   #7
ggrieco
Got it, will let you know how things turn out.
Thanks,Gary
Fog lights, or parking lights stopped working sylvermagyk DIY / Maintenance / Service 4 03-24-2011 05:13 PM
How to turn on the running lights and fog lights @ same timewhile/headlights off ...? Moratiya DIY / Maintenance / Service 8 12-11-2010 06:40 PM
my Projector Fog lights project ezhacker1 Cosmetic Modifications (Exterior/Interior) 3 01-10-2010 05:21 PM
Fog Lights Poll Reeves360 Cosmetic Modifications (Exterior/Interior) 14 12-27-2009 02:00 AM
Sedan Fog Lights, few questions!(where to get) ( make into HID Fog Lights!!!) Lafiro Cosmetic Modifications (Exterior/Interior) 2 06-12-2009 03:56 PM
