Old 01-21-2015, 05:30 PM   #1
spookybathtub
Drives: 2007 Yaris HB
Socket set with flat side outside?
I came across this image on some other forum. It looks like they have a deep socket that's flat on the outside instead of round, so it can be grabbed with a wrench. Looks perfect for the bolt on top of the front struts. Anyone know what this is called or where to buy?
spookybathtub is offline   Reply With Quote
Old 01-21-2015, 05:36 PM   #2
shepd
Drives: 2007 Yaris 5 door RS
Looks like a spark plug socket.
And finding the original forum post, it's a 13/16" spark plug socket. Available at all finer auto parts stores. :) Don't know what size ours would be, though.
shepd is offline   Reply With Quote
Old 01-21-2015, 05:50 PM   #3
Kar98
Drives: 2011 Scion tC
Looks like a tool enabling tools to strip nuts.
Kar98 is offline   Reply With Quote
Old 01-21-2015, 06:33 PM   #4
nortonfb
Drives: 2007
Very common. Try Sears or JC Whitney if you can't find local.
I have them in SK, Snap On, Craftsman and Husky. Of course my tools are
old and most were used when I got them.
Norton
nortonfb is offline   Reply With Quote
Old 01-21-2015, 10:08 PM   #5
Ours are 17mm, so a standard spark plug socket will not work. Instead, just get yourself and offset box wrench.
Old 01-21-2015, 10:14 PM   #6
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
^ This. Harborfreight or Northern Tool will be your best friend. An offset box wrench means that you don't have to remove the wipers and cowl to change the struts. As an alternative, can I suggest a through-hole socket set? Frequently on sale, often with a 20-25% off coupon: http://www.harborfreight.com/hand-to...set-67974.html
Old 05-21-2016, 03:07 AM   #7
jcboy
Drives: Sedan 07
I know this is an old thread, but if Im correct I happen to have come across this type of socket for the first time just recently. I think it was called an open/pass through socket set. The ratchet drives it from the outside although IIRC its like a standard ratchet inside out--meaning the driver is four-sided (square) as opposed to a hexagon in the OP's pic.
Back seats don't fold flat? harda toenail DIY / Maintenance / Service 12 09-23-2013 05:06 PM
Kawasaki 750 Side by Side StreetGlow OPTX LED fnkngrv Off-topic / Other Cars / Everything else Discussions 7 08-26-2010 08:56 PM
Are the optional airbags worth it ? avenno2g7 General Yaris / Vitz Discussion 46 12-07-2008 02:40 AM
DIY - HID Retrofit Violin DIY / Maintenance / Service 57 06-11-2007 06:17 PM
