Old 10-29-2008, 11:56 PM   #1
LtNoogie
LtNoogie's Avatar
Drives: '08 Bayou Blue LB AT
Most important guages for boosted engines?
Once I install the Blitz, what three guages are most important for monitoring the health of the engine?
I already have a ScanGuage so I can monitor water temp.
Old 10-30-2008, 12:19 AM   #2
not critical with supercharging, but I would say a boost gauge and oil pressure, since you already have water temp.
Old 10-30-2008, 12:31 AM   #3
battleversiontc
battleversiontc's Avatar
Drives: 08 vip yaris
boost, oil, pyrometer so if you hold it long you dont fry your pistons
i run all three for my turbod tc and water temp, and wideband,
my old supercharged delsol i ran those three and a wideband
08 junction produce belta almost done and ready for paint
06 junction produce tc 604 bhp 445tq ddriven still trying for 700+hp
90 crx sir ls vtec turbo 755 hp
mecp masters certified
battleversiontc is offline   Reply With Quote
Old 10-30-2008, 12:49 AM   #4
oh yeah, add a wideband A/F that one is fun to watch too
Old 10-30-2008, 01:23 AM   #5
LtNoogie
LtNoogie's Avatar
Ok, but other than fun to watch, will the A/F wideband warn me that something is about to blow up? I can see the point of oil pressure and water temp. Never knew the purpose of wideband.
Old 10-30-2008, 06:16 AM   #6
battleversiontc
the pyrometer will tell you if your pistons about to melt. a/f wideband would tell you if its to lean or to rich or right on the money
Old 10-30-2008, 10:14 AM   #7
Nexus1155
Bathroom + Laptop = <3
Drives: Audi
i would say boost/oil pressure/AFR.... any car that you plan on tuning correctly NEEDS a wideband... people think they can use the narrowband signal to tune... thats a bunch of hoohah, but the wideband will cost you a pretty penny over the others
Old 10-30-2008, 11:35 AM   #8
whooppee777
I used to have 1700 posts
whooppee777's Avatar
Drives: 2008 Yaris Hatch
who makes a good wideband AFR gauge
Old 10-30-2008, 12:06 PM   #9
largeorangefont
Break'em off some.
largeorangefont's Avatar
Drives: 07 Yaris LB, 04 Cobra
If you have a turbo you will want:
Boost, EGT, oil pressure, water temp
If you are supercharged you will want:
Water temp, oil pressure, EGT, boost if you have extra $.
Wideband is fine for both, but EGT is going to be more important, especially in a turbo car.
If you have a scangauge, I would not waste the cash on a wideband. The scangauge should be able to monitor fuel pressure, which will give you a window into the fueling system. Between fuel pressure and EGT you will be able to tell if you have a fueling problem. EGT is more critical to the health of the engine, especially with a turbo.
If you are doing your own tuning however, then you will definately want a wideband.
Old 10-30-2008, 12:08 PM   #10
largeorangefont
Break'em off some.
AEM, Dynojet, Autometer, Innovate, Dynotune. You can get one from $250-$350 it just depends on what features you want.
Old 10-30-2008, 12:10 PM   #11
largeorangefont
Break'em off some.
Originally Posted by kurokoma-kun View Post
where are the rest of you locating the wideband a/f O2 sensor? header or midpipe? i really hate to drill a new hole on my header if i can locate it on the pipe
It needs to be before any cats, and clocked above 9 and 3 on the pipe to avoid sensor damage.
Old 10-30-2008, 12:25 PM   #12
largeorangefont
Break'em off some.
on that nitto midpipe there's a few inches of pipe right behind the collector b4 the first resonator, that'll be a good spot... now if only i could weld
a muffler shop will be able to handle it.
Old 10-30-2008, 01:20 PM   #13
Nexus1155
Drives: Audi
i use innovate LM-1, but it is handheld and i have an extra one lying around somewhere... but on cars that people dont feel like getting a bung welded in, i use the exhaust clamp which gave me a steady 14.5 AFR reading at idle out of the Envoy i drive... and that was at the end of the tailpipe but the HPtuners scanner software read 13.06 :-/ whacky interfaces
Old 10-30-2008, 01:30 PM   #14
whooppee777
what should the AFR be on a blitz supercharged yaris?
Old 10-30-2008, 04:37 PM   #15
largeorangefont
Break'em off some.
I would not got higher than 12:1. Mid 11s would be a very safe compromise.
I run my Cobra at 11.3 to one to keep EGTs down on the track.
Old 10-30-2008, 05:28 PM   #16
whooppee777
i saw a pic of camelll's gauge reading 13.1 at 9 pounds of boost whats ur take on that?
Old 10-30-2008, 05:28 PM   #17
battleversiontc
i use plx
Old 10-30-2008, 07:19 PM   #18
largeorangefont
Break'em off some.
He said it dips to low/mid 11s after that though, which is fine. A second or 2 of 13:1 under boost after throttle tip in is not going to hurt anything.
NST (NonStopTuning) Pulleys. Info, Specs, User Data... NonStopTuning Performance Modifications 636 12-13-2013 09:47 PM
Gauges! Gauges! Gauges! at Blow Out Price. MC-BPT Sponsors Classifieds Area 5 06-07-2007 09:55 PM
