Old 10-30-2008, 12:05 PM   #1
Shroomster
'07 to '12:2 wipers to 1?
Shroomster's Avatar
Sedan owners
I have a question about your instrument cluster dimmer switch.
when you roll it all the way up it gets brighter, then when you pass the "click" at the top does it get fully bright or does it turn off?
I ask because I have seen three different sedans in the rental fleet that do this and I'm not sure if that is what they should be doing or not.
REMEMBER THIS IS FOR THE SEDANS ONLY NOT THE LIFTBACKS
thanks!
Old 10-30-2008, 12:19 PM   #2
RHDVIPbB
Right beside you, wave
Drives: 08 PBM Yaris Sedan
never looked. Will have to try this.
Although my friends tC did this before. Probably due to a load on the electrical circuit.
Old 10-30-2008, 12:21 PM   #3
CrazedEpidemic
The lights for mine turn off when it clicks
CrazedEpidemic is offline   Reply With Quote
Old 10-30-2008, 12:58 PM   #4
||)) (o) ||\||
- Donnie Demonic -
||)) (o) ||\||'s Avatar
Drives: '07 Yaris Sedan Sport
Mine turns off and lcd gets brighter.
||)) (o) ||\|| is offline   Reply With Quote
Old 10-30-2008, 04:02 PM   #5
Shroomster
Shroomster's Avatar
ok thats what I was wanting to find out....This is the first Toyota model I've seen (on the lot) that cuts the power after the click. usually the click makes the rheostat push the highest voltage setting to emit the most light.....meanwhile turning the dial all the way down is supposed to dim the instrument panel display....
weird.....
Old 10-31-2008, 01:18 AM   #6
CrazedEpidemic
Yea I thought that was weird too, when I push it up it gets brighter until it clicks and just turns off.
Old 10-31-2008, 03:28 AM   #7
id3379
§†ęĄ¶‡Ћ-NCP96
id3379's Avatar
After the click,The Tach & Speedo Cluster goes out, and the fuel gadge LCD screen goes super brite
id3379 is offline   Reply With Quote
Old 10-31-2008, 04:23 AM   #8
eii
Rides canyon walls
eii's Avatar
Drives: 1988 RX7 FC 10th AE
+1
OEM Style Wing Spoiler | TRD Axle-Back Exhaust | Megan Lowering Springs (1.5 f/r) | Simota Carbon Charger Intake | Python 871XP Alarm System | Aluminum Sports Pedal | 17x7 +42mm Enkei J10 Black w/ Silver Lip | 205/40 Falken Ziex-912 | NST Lite Crank Pulley Red | 1ZZ-FE Throttle Body | AMK Racing Header
eii is offline   Reply With Quote
Old 10-31-2008, 10:14 AM   #9
MUSKOKA800
MUSKOKA800's Avatar
I'll have to check that out. I've never needed to turned it up full bright.
Old 10-31-2008, 02:09 PM   #10
Herbicidal
Just a Herbicidal maniac.
Herbicidal's Avatar
Drives: 2008 Yaris S Sedan Flint Mica
Originally Posted by eii View Post
+1
+2
2008 Toyota Yaris (Vios) 'S' sedan, Flint Mica, dropped on TRD springs, TRD anti-sway bar. Tinted rear windows. Lenso Samurai SC02 hyper black 17" x 7" rims, wrapped in 205x40x17 Federal ss595's. Color matched eyelids. Vios badge. Body color trunk trim (was chrome). Lamin-X tint on rear tails. Custom center exit exhaust. Tanabe front strut tower brace.
Herbicidal is offline   Reply With Quote
Old 11-02-2008, 02:42 PM   #11
captainm27
Drives: 2008 Sedan A/T Silver
Well, what happens is this: Because the instrument panel is covered, there are times when it's cloudy and the day is not that bright, so you turn on your headlights, this turns your instrument guage into 'night mode' by dimming the fuel gauge light panel and turning on the light on the guages. However, sometimes I find it that the fuel gauge light is too dim during these times when it's not yet night, but it's not bright outside. So once you pass the click on the dial, it allows you to have your headlights on, but also have your guage on regular mode, not night mode.
I use this very frequently, and then you can tell that you your lights are still on because you will see the little headlight bulb on your dash turn on.
captainm27 is offline   Reply With Quote
Why people choose a 5dr Liftback instead of a Sedan?? SimmZ General Yaris / Vitz Discussion 53 05-29-2007 10:28 PM
Yaris Sedan owners please look in! eTiMaGo Cosmetic Modifications (Exterior/Interior) 9 03-19-2007 06:01 PM
