Old 11-01-2008, 09:55 AM   #1
IsLNdbOi
IsLNdbOi's Avatar
Accessories for 5-door '09 LB?
Ok, so I was looking forward to installing my TYC tail lights on my new '09 5-door LB. Got one of the stock lights out and the TYC lights won't work. The tail light connector on the '09 5-door LB is different.
When can we expect to see some new tail lights for the '09 5-door LB?
Same question for fog lights. The fog light shrouds on the '09 non-S LBs is different than the shrouds on previous model year LBs.
Old 11-01-2008, 11:51 AM   #2
can you take a picture of the new stock taillight connectors?
Old 11-01-2008, 12:48 PM   #3
Is the shape of the taillight the same? Many people just wire up aftermarket lights by splicing the wires.
Hey Thomas, I wonder if they adopted the Thai spec for the harnesses? That would rock.
Old 11-01-2008, 12:49 PM   #4
my thoughts exactly... most unlikely though!
But based on pictures, the actual physical shape of the light is the same, just the layout changes
Old 11-01-2008, 06:21 PM   #5
IsLNdbOi
IsLNdbOi's Avatar
The tail lights are the same shape as the '08 and '07 LBs' tail lights. Connector is different though.
I'll take pics. when I get a chance to.
Old 11-01-2008, 08:41 PM   #6
They are actually a slightly different shape. I believe that they will fit, but the 08 flares out along the hatch and the 09 flares in. In the picture below you can see it. The 08 is on the left and 09 right. The hatch is identical, so you can see how the 08 sticks out a bit from the hatch, but the 09 doesn't. If the 08 light was installed on my 09, it would follow the bumper up the end of the back-up lens, then would stick out over the indent in my 09 bumper by about 1/2" - 3/4".
Is the 08 tail light connector a six pin one row connector as opposed the the U-shaped connector of the 09?
I ran into a pre-hack DIY on installing JDM lights on an 08 (which involved changing the connector on the car from the single row 6 to the U-shaped 6) and the pinout for my 09 is identical to the JDM lights shown in the DIY.
Old 11-01-2008, 09:00 PM   #7
IsLNdbOi
IsLNdbOi's Avatar
If yours is an '09 5-door LB, then you have the same connector I do for the tail lights.
Old 11-01-2008, 09:06 PM   #8
I meant the connector on the TYCs.
Old 11-01-2008, 09:12 PM   #9
IsLNdbOi
IsLNdbOi's Avatar
Oh, I don't know about the '08's tail light connector. I had an '07 LB and I know the tail light connector of the '07 LB is different than the '09 5-door LB's tail light connector.
The TYC tail lights I have, have connectors that match the connector on the '07 LB.
Old 11-01-2008, 09:19 PM   #10
That's the one-row six pin connector, right?
Old 11-01-2008, 09:34 PM   #11
IsLNdbOi
IsLNdbOi's Avatar
I don't know. The TYC tail lights I have are boxed up and in the attic since I cant use them.
There are pics. somewhere here though.
Old 11-01-2008, 09:50 PM   #12
You could either change the male connector on the car (by popping the pins and moving them to the 07-08 style) or change the female connector on the TYC's to the 09 style. Both types use the same pins, so you would not have to cut and splice wires...
Old 11-01-2008, 10:02 PM   #13
I wouldn't mind seeing a DIY about how to remove and and re-install those pins.
Old 11-01-2008, 10:09 PM   #14
IsLNdbOi
IsLNdbOi's Avatar
I could do that, but I want lights that follow the car's contours and curves. As you mentioned above, they would stick out on that part next to the hatch door that slopes inwards.
Old 11-01-2008, 10:09 PM   #15
Here it is:
http://www.yarisworld.com/forums/sho...DIY+Tail+light
Old 11-01-2008, 10:55 PM   #16
Meteorite_Marty
Drives: 2008 5-door Yaris Hatchback
FYI... I run TYC tails on my 2008 hatchback.
Meteorite_Marty is offline   Reply With Quote
Old 11-02-2008, 12:06 AM   #17
1NZYaris1
1NZYaris1's Avatar
Not Quite a diy but here is a blurry photo or too
one photo you will see the back off the plug marked in red lines ,
that is the pice you pop out ,then pull pins out the back of plug .
Real easy , pay my airfares and i will fly over and show you
The Official Toyota Thailand Accessories Order Thread eTiMaGo Items for Sale by private party 417 11-23-2009 04:19 AM
LF: Yaris / Vitz / Echo hatch accessories / parts! Keej_05RS General Yaris / Vitz Discussion 3 12-08-2008 09:43 PM
Toyota Accessories GrassrootsMS Cosmetic Modifications (Exterior/Interior) 2 09-28-2007 12:21 PM
Official Toyota Thailand accessories for Yaris Hatch & Sedan eTiMaGo Cosmetic Modifications (Exterior/Interior) 85 04-18-2007 07:53 AM
Canadian Toyota Dealerships with Yaris Accessories Online? Violin Canada 49 04-11-2007 08:50 AM
