Old 11-02-2008, 01:41 AM   #1
Trilixia
Trilixia's Avatar
Drives: Black Sand Pearl Liftback
Thumbs down KNOCKING/CLICKING NOISE
When I am driving in reverse and then I step on the brake, the car makes one knocking/clicking noise. What could it be? axle? suspension?
Please help
"That's Corny, Dude!!"
Trilixia is offline   Reply With Quote
Old 11-02-2008, 08:55 PM   #2
john21031
Drives: '10 Fit Sport MT and 2012 Fit
could be many things... the body, the door hinges, the brakes, the udnerbody panels... etc.... look carefully to try to locate the source, or ask someone to back up for you while you look and listen (out of the way).
john21031 is offline   Reply With Quote
Old 11-02-2008, 11:32 PM   #3
floydisrock
73 Centurion droptop 455
floydisrock's Avatar
Drives: 2009 S Sedan
Most likely brakes,IMHO.
"THIS SITE HAS BEEN HACKED BY www.bimmerfest.com. YOU FUCKERS!"
floydisrock is offline   Reply With Quote
Old 11-02-2008, 11:52 PM   #4
Altitude
Altitude's Avatar
Drives: '08 LB MT Bayou
Yep - sounds like the brakes - more specifically the auto-adjusters.
Old 11-03-2008, 11:50 AM   #5
Trilixia
Trilixia's Avatar
Are the brakes under warranty?
Old 11-03-2008, 11:53 AM   #6
Tamago
Tamago's Avatar
Drives: UZJ100
the pads/rotors are not.. mechanical parts are.
Old 11-03-2008, 03:21 PM   #7
it's normal after a while that rear brakes make noise when you are going in reverse.
try rubbing a mop stick on a block of wax for a while. then go in the other direction after. the same effect happen to drum brakes.
Old 11-04-2008, 01:44 PM   #8
SilverGlow
Drives: 2007 Yaris Hatchback
Do our Yaris have auto-adjusing brakes? I hope so....and if so when do they adjust? During braking in reverse? This is my first Toyota...all my Hondas had auto-adjusting....
SilverGlow is offline   Reply With Quote
Old 11-11-2008, 05:53 AM   #9
gboezio
gboezio's Avatar
Drives: Yaris 4dr 2008
Check everything with a pry bar, ball joints, tie rods, subframe bolts (most likely), if all nice and tight, crank up the volume
gboezio is offline   Reply With Quote
Old 11-12-2008, 08:37 AM   #10
bakrazero
Drives: Yaris 2009
I had a clicking sound occur when I am reversing. I had it checked by the dealer and they found some heat shield plates underneath to be loose and now the noise is gone.
bakrazero is offline   Reply With Quote
Noise coming from rear end! tfman716 General Yaris / Vitz Discussion 15 10-28-2008 12:37 PM
Werring Noise in automatic yaris yaris_auto General Yaris / Vitz Discussion 0 09-24-2007 10:48 AM
Air Conditioner Noise Cathy General Yaris / Vitz Discussion 16 05-08-2007 02:08 AM
2007 LB Auto-Trans NOISE in Reverse Pavel Olavich General Yaris / Vitz Discussion 4 03-22-2007 07:42 PM
Clicking noise in center console? devinlamothe General Yaris / Vitz Discussion 8 09-16-2006 11:03 AM
