Old 11-03-2008, 02:34 PM   #1
gid
Drives: '08 Yaris sedan , '08 Liftback
QUAKER STATE : Full Synthetic motor oil ( Horse Power or Torque Power ) : $19.99 ...
for 5 quarts and STP oil fliter at AUTOZONE . You could skip the oil filter and just use the Q.S. syn-oil at the cost of $4 a quart .
gid is offline   Reply With Quote
Old 11-03-2008, 04:42 PM   #2
aca72
aca72's Avatar
Drives: '07 Yaris S Sedan M5
Additional product information:
Q synthetic motor oil is manufactured by SOPUS (Shell Oil Products U.S.).
Product Data Sheets: Q HP & Q TP
STP oil filters are manufactured by Champion Laboratories, Inc.
aca72 is offline   Reply With Quote
Old 11-03-2008, 09:57 PM   #3
gid
Thumbs up thanks
for the extra info .
Old 11-04-2008, 12:54 PM   #4
TheSilkySmooth
TheSilkySmooth's Avatar
This is bad stuff GID. Go to European formula AECA spec a3/b3 you can obtain on the Web. UOA do not start to tell the whole story on what is a good lubricant.
Old 11-04-2008, 12:58 PM   #5
SilverGlow
Drives: 2007 Yaris Hatchback
Not true again. The QS syn oil is great stuff and will not harm a Yaris motor.
As long as an oil's rating is SM, it is great oil and will provide all the protection a motor requires, REGARDLESS OF BRAND.
If you take the worse SM rated oil and use it in your Yaris, the engine will last just as long as if you used the most expensive special brand also at SM rating.
There is no better way to determine the goodness of an oil then a UOA.
Too much religion on oil brands....and often one's bias toward brand X is based purely on emotion, the cool purple color, etc and lacking any scientific data.
Buy the SM rated synthetic that is on sale regardless of brand and your motor will last 300,000+ miles.
SilverGlow is offline   Reply With Quote
Old 11-05-2008, 05:35 PM   #6
TheSilkySmooth
Wrong Again - Do you need me to go through the SM spec line by line to show you where it is WORSE than SG? N.A. API oil is inadequate except in the most MILD driving conditions eg: moderate ambient climate, complete warm up, low rpm operation.
Old 11-05-2008, 05:36 PM   #7
TheSilkySmooth
No religion for me - they ALL are inadequate.
Old 11-05-2008, 07:25 PM   #8
aca72
aca72's Avatar
What is adequate? Enlighten us.
Old 11-07-2008, 12:56 PM   #9
TheSilkySmooth
Just look into AECA A3 specification and run against API SM. Other than polar nature of base oil and having a well cracked base stock (which is a production quality issue not unlike the "Vodka Wars") Oversimplified specification of HSRV (hths) beyond 3.2 centimetre gram second (cP,CEC L-36-A-90) and a well designed metal-salts additive at 3-4X what is allowed in API SM. Note: As you may know, I prefer coconut-derived oil base stocks as a superior molecule. Please, you may study this at nauseum on the WWW.
Old 11-07-2008, 12:57 PM   #10
TheSilkySmooth
Try this: http://www.swri.org/4ORG/D08/global/...HS/default.htm
Old 11-07-2008, 01:28 PM   #11
aca72
aca72's Avatar
Thanks for the link Silky. That's very informative.
So, if I put the Q Synthetic in a Yaris engine, would that destroy the engine? What oil brand would you recommend with ACEA A3/B3 that is readily available in retail stores?
Old 11-07-2008, 07:20 PM   #12
gid
PENNZOIL Platinum 5w-30 is B rated as well , the 5w-20 is not . The SHELL synthetic is not , but many conventional ( regular ) oils are not . Been using those for years without an issue . I'm sure QUAKER STATE synthetic be fine as well , seen good USED OIL ANALYSISes for Q.S. syns at www.bobistheoilguy.com under U.O.A.s ( Gasoline ) . Check it out for yourself .
Old 11-07-2008, 07:21 PM   #13
Black Yaris
der Zeck
Black Yaris's Avatar
Thanks for plug for us at Autozone!
Old 11-07-2008, 09:57 PM   #14
RagnaCaT
HacKers WanTed!
RagnaCaT's Avatar
Drives: Yaris S HB & Yaris S SD
I DON'T UNDERSTAND ANYTHING! uFF!
R-CaT
Project Yar 2ZR
RagnaCaT is offline   Reply With Quote
Old 11-07-2008, 10:08 PM   #15
gid
here's a QUAKER STATE 5w-30 synthetic Used Oil Analysis - Gasoline Engine ( U.O.A. ) with very good results , http://www.bobistheoilguy.com/forums...67#Post1204267 . These oils can be bought at WALLY WORLD for cheap or on sale at many auto part stores , such as AUTOZONE ( another plug ) , A.A.P. ( sorry ) , etc..
Old 11-10-2008, 12:13 PM   #16
TheSilkySmooth
mr. Gid, you are the oil man! I am in wilmington, MA area are you near the socialist commonwealth of massachusetts?
Old 11-10-2008, 02:42 PM   #17
gid
across the border . So , nearby . That'll keep you in suspense .
Old 11-10-2008, 03:33 PM   #18
firemachine69
School'er of hard knocks
Drives: Silver Yaris 4dr. HB
All that synthetic is good for, is extended drain intervals.
firemachine69 is offline   Reply With Quote
How to Be a Street Racer - General Life Guide MDF Off-topic / Other Cars / Everything else Discussions 7 03-19-2007 12:49 PM
